Speaking of Tang Band
Discussion in 'Audio & Video' started by 07TacoRidah, Jan 16, 2010.
  1. Jan 16, 2010 at 2:37 PM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    http://www.youtube.com/watch?v=QqrG4IDldRk
    So, I read in a post on here (Youtube) that the bass from the 5 1/4" was due to the box being long which gives off the resonance. I have an access cab, in that little storage area where the jack and tire iron is, would it be okay if I made something like this but with 6.5" subs in there? do I need to have a vent? will it work better or just the same with/without the port? Not being in an open area like in the video, will being in an enclosed area lower the bass response? if you add in say three more 6.5" subs, will this shorten the resonance the box will be projecting if it had only one sub?
  2. Jan 16, 2010 at 2:53 PM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    Yes you will need a vent, that the whole point behind the t-line box. Realistically you can see how BIG the boxes are in a T-line, look at the size of that one for just a 5.25" driver. Interesting you posted this...I have a friend building me a one for a JL 8" driver, I wanna experiment with it and see if I can impress a few people with it. :D I will let you know.
  3. Jan 16, 2010 at 3:40 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I have 4 (ok really 6) of the 6.5" versions in my room right now. I've been working on my box for them slowly but I'll make some REALLY good progress this week since I have no plans.
    A T-line (as I understand it) is just a box that is 1/4 as long as the wavelength you are tuning to. So for a T-line tuned to 30hz you would need to make the vent 9.25 feet.
  4. Jan 16, 2010 at 8:10 PM
    07TacoRidah
    damn, this is getting harder, post up when you guys get progress. I'd really like to know how it turns out, getting mighty tired of the stock system, not really into getting the Boss driver anymore either. Rather have something more concealed.
