Speed sensor wire?
Discussion in 'Audio & Video' started by CLVol1255, Feb 1, 2020.
  1. Feb 1, 2020 at 9:49 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You definitely can use the included GPS antenna if you want. It doesn’t even need to be outside the dash.
    For the USB adapter I posted, that will let you retain the factory USB port down by the cig lighter. The extensions included with the radio need to re routed to an accessible location like the glove box. That just leads to sloppy wiring when you plug your phone in
  2. Feb 1, 2020 at 9:56 AM
    CLVol1255
    CLVol1255 [OP] Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    Ok yeah I tried to order it but not available for pickup until February 7
  3. Feb 1, 2020 at 2:42 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    So I’ve got the idatalink maestro rr and the TO2 in possession. This will get me up and running until I can get the other harnesses in later this week?? @destin_meeks
  4. Feb 1, 2020 at 2:44 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Heck it looks like the harness I bought with the pac unit may fit and work on this maestro too
  5. Feb 1, 2020 at 2:55 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Won’t need the PAC at all with the maestro
    -As far as the needed pieces, the maestro brain and harness are essential.
    -The mounting kit is pretty important. If you don’t have it yet, you can take the brackets off the factory radio and use them, and just have a gap around the radio.
    -The antenna adapter is needed for AM/FM radio. Probably not “essential” for the time being if you didn’t get it
    -the USB adapter can be made due without for now. Run one of the USB cables the alpine came with over to the glove box (or pop out a blank switch down low by the factory USB and run it there)
    CLVol1255[QUOTED][OP] likes this.
  6. Feb 1, 2020 at 3:08 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    @destin_meeks you're the man. So I have the maestro brain and TO2 hrn rr TO2 the TR1 best parts by pac but think it may be universal and able to use it to bypass emergency brake the alpine has in system and a couple more harnesses that are best parts brand by pac that seem to be universal as well but I don’t know for sure. On my way home as we speak to get this install done so I can listen to my music again. I’m gonna test out the Steve Meade distortion detector when done as well. I’m getting fired up thinking about it
  7. Feb 1, 2020 at 3:12 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I ordered that Metra mounting kit you linked this morning. Should be here Tuesday
  8. Feb 1, 2020 at 3:13 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Oh yeah I forgot you had the PAC brake bypass. I was still thinking of the CP2
  9. Feb 1, 2020 at 3:19 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Is this maestro the unit that gives you different gauges?
  10. Feb 1, 2020 at 3:21 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    yes
  11. Feb 1, 2020 at 6:00 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    @destin_meeks im working on soldering TO2 and alpine main together now. I’ve noticed the alpine doesn’t have an orange illumination wire to solder in. Am I missing something? The orange dimmer wire. It has an orange white wire but it says that’s the reverse illumination lights. Is this it?
  12. Feb 1, 2020 at 7:40 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Alpine has a light sensor on the face, no illum trigger
  13. Feb 1, 2020 at 7:44 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Ok why I’ve got you here. It’s also wanting me to connect into foot brake wire? @destin_meeks
  14. Feb 1, 2020 at 7:45 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Not parking brake or emergency brake but foot brake. All 3 actually but I’m not finding foot brake
  15. Feb 1, 2020 at 7:46 PM
    #35
    destin_meeks
    Destin
    Tuscaloosa, AL
    It will get foot brake data from the maestro
  16. Feb 1, 2020 at 7:47 PM
    #36
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Ok which wire would foot brake be? Do you know? I’m 3 wires away from finding before installing this bad boy
  17. Feb 1, 2020 at 7:48 PM
    #37
    destin_meeks
    Destin
    Tuscaloosa, AL
    Don’t need to wire it. The maestro will tell it through the data harness (little black 4-pin plug)
  18. Feb 2, 2020 at 7:19 AM
    #38
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Ok I’m back at it again. Lasted until about 130am last night. I got it hooked up and tested. Backup camera isn’t functioning and gps doesn’t seem to be picking up. It’s reading Houston Texas on the screen. I’m in Tennessee.
  19. Feb 2, 2020 at 7:37 AM
    #39
    destin_meeks
    Destin
    Tuscaloosa, AL
    Might need to move gps antenna to a different location.
    If yours had factory NAV, the factory antenna is just up and to the left of the radio. Try putting the new antenna there.
    for the camera, is the radio switching to the input when in reverse, and just not showing the camera image?
  20. Feb 2, 2020 at 7:43 AM
    #40
    destin_meeks
    Destin
    Tuscaloosa, AL
    I just realized a very odd thing... that Alpine (as expensive as it was) doesn’t support the Maestro data features (gauges and all that)
    which is crazy because $250 pioneers and Kenwood a support that...
    that means the foot brake wire DOES need to be hooked up (yellow/black according the the install guide)
    Also, did to flash the maestro on the computer?
