Speed sensor wire?
Discussion in 'Audio & Video' started by CLVol1255, Feb 1, 2020.
  1. Feb 2, 2020 at 4:45 PM
    #61
    JDattilio
    JDattilio Well-Known Member
    Jayson
    SR5
    You didn't leave the 8 speaker wires from the headunit connected to the factory wiring, and connect the amp into the same wires together did you? You want the headunits speaker wires isolated, capped off each one by itself, when your doing an outboard amp, like your JL.
  2. Feb 2, 2020 at 4:49 PM
    #62
    JDattilio
    Jayson
    SR5
    also you don't have the factory JBL system do you?
  3. Feb 2, 2020 at 4:51 PM
    #63
    CLVol1255
    CLVol1255 [OP] Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    No it’s non jbl unit stock but have had to replace the entune since trying to add the JL audio. Now I’m afraid the same has happened to this alpine I replaced it with
  4. Feb 2, 2020 at 4:52 PM
    #64
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I’m going to run speaker wire from JL straight to each speaker instead of behind head unit
  5. Feb 2, 2020 at 4:53 PM
    #65
    JDattilio
    Jayson
    SR5
    so you had the xd connected to the factory radio to start then added the alpine?
  6. Feb 2, 2020 at 4:54 PM
    #66
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    No I had the JL connected to head unit harness last. Then I pulled all wires from JL and my dq 61 and connected the alpine only
  7. Feb 2, 2020 at 4:55 PM
    #67
    JDattilio
    Jayson
    SR5
    and again you didn't have the alpines speaker wires connected to the harness as well as the JL correct?
  8. Feb 2, 2020 at 5:08 PM
    #68
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I connected the JL to the Toyota factory harness behind the alpine head unit via posi taps. Not the alpine speaker harness that it came with
  9. Feb 2, 2020 at 5:17 PM
    #69
    JDattilio
    Jayson
    SR5
    curious why you just didn't connect the wires coming from the jl to the harness that comes with the mastero, instead of tapping into the factory side of harness, and what is connected on those speaker wires on the other side of mastero harness?
  10. Feb 2, 2020 at 6:59 PM
    #70
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Nothing is connected to the maestro harness. It was new I got in a hurry wanted to get this thing over with and done. Been struggling with it going on a week and a half now and beyond frustrated. Girlfriend giving me hell about always messing with truck here lately and I have been. Idk man dumb move I guess. Believe me I’m not proud of it
  11. Feb 2, 2020 at 7:22 PM
    #71
    prone2xl
    prone2xl Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
    Chin up champ. You’ll get it. Hey man I was about to attempt something like this but am glad I pulled out my aftermarket pioneer that I bought 6 years ago just to look and boy I had a struggle even trying to get it back in place with all the wires behind. Still sticking out my dash now. Will def be taking it to the pros for install. And adding a few extra upgraded toys at the same time. Win win. Consider it
    CLVol1255[OP] likes this.
  12. Feb 2, 2020 at 7:32 PM
    #72
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Does anybody know which wire the foot brake is that the maestro TO2 harness needs to be soldered into?
  13. Feb 2, 2020 at 7:59 PM
    #73
    JDattilio
    Jayson
    SR5
    foot brake wire on rr harness is yellow/black but I'm pretty sure the w970hd doesn't have a foot brake wire only a parking brake wire, look at wiring diagram in owners book for your alpine, most of the current alpine radios only have parking brake now. so in that case you just cap off the yellow/black as it is not needed for your set up.
  14. Feb 2, 2020 at 8:10 PM
    #74
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Yeah my alpine doesn’t have the foot brake wire
  15. Feb 2, 2020 at 8:13 PM
    #75
    JDattilio
    Jayson
    SR5
    so no you don't need to hook up the foot brake wire then just make sure it has a cap or some tape covering the end to keep it from touching anything else
  16. Feb 2, 2020 at 8:14 PM
    #76
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I had the alpine power speaker harness soldered into the maestro harness then the Maestro harness plugged into factory speaker harness. I had JL Amp tapped into factory harness and I had alpine Rca harness running into JL amp rca inputs
  17. Feb 2, 2020 at 8:16 PM
    #77
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    So is there not a way to get the gauge functions of maestro with my ine 970hd? I really ain’t a fan of this thing. I figured it was badass as much as it costed me after plug n play harnesses ordered and bought used she not used I’ve got 1300 in it. Smdh
  18. Feb 2, 2020 at 8:20 PM
    #78
    JDattilio
    Jayson
    SR5
    so you have the alpine's internal amp connected alone with the JL amp to the same wires.... yeah that is a big no no, like I said earlier you don't want the alpines speaker wires connected if you are running an outboard amp. cut those speaker wires from the alpine off the maestro harness and tape each one off. no gauges for that alpine unit it doesn't support the data from the maestro unit
  19. Feb 2, 2020 at 8:25 PM
    #79
    JDattilio
    Jayson
    SR5
    and cut it at your solder joint were you connected the two harness together, that way each harness is still usable
  20. Feb 2, 2020 at 8:28 PM
    #80
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    You think it’s fried? I just followed the instructions that came with maestro for non jbl. I did the same thing with my oem unit and the Audio shop said it was fried. That’s when I bought this one
