Speedo calibration on 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by roggs01, May 5, 2018.
  1. Apr 8, 2022 at 7:09 AM
    #181
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    Thanks for that, id honestly be happy with that since, you're right, it'll just hold whatever you set it at I'll just have to remember that if I bump/lower the cruise displayed mph that the main speedo is the real speed.
    What about mpg display? Does that get recalibrated?
    Monster0Frankenstein likes this.
  2. Apr 8, 2022 at 7:57 AM
    #182
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    Do these things adjust transmission shift points to match real speed, or will it still be wonky? Trying to decide if I need this *and* 4.88s to get the transmission to use 5th & 6th gear on the highway.
  3. Apr 8, 2022 at 10:42 AM
    #183
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    MPG and shift points are corrected. The only thing I've noticed that's not corrected is the cruise control set speed display number.
  4. Apr 8, 2022 at 12:49 PM
    #184
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    I installed the rough country calibrator a few months ago, shifting and MPG's slightly improved. Are you tuned? I got the Nexus +P Premium tune a few weeks ago and the truck holds 6th gear great on the highway, even up slight inclines. I'm on 33's with stock gearing and my MPG's are also barely less than they were with stock tires.
  5. Apr 8, 2022 at 1:11 PM
    #185
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    This affects shift points too? I thought it just adjusted input voltage to the instrument cluster.
  6. Apr 8, 2022 at 1:24 PM
    #186
    mlr69
    South Carolina
    It did on my Taco. I assume once the speed issue was corrected, the shift point issue fixed itself. The Hypertech calibrator recalculates the data coming off the vehicles computer - I'm pretty sure it's more than just a voltage adjustment.
  7. Apr 8, 2022 at 2:19 PM
    #187
    CAG Gonzo
    2018 OR DCLB BarRed
    Huh. I did not know that. I figured if it was doing anything more meaningful then the cruise control speed would also get the update since it's likely feeding to the ECU or some other computer.
  8. Apr 8, 2022 at 2:45 PM
    #188
    mlr69
    South Carolina
    I talked to Hypertech a few years ago, back when I installed mine - they told me the cruise control data was coming from a different location, one that their calibrator was not talking to. True or not, I have no idea.
  9. Apr 8, 2022 at 3:07 PM
    #189
    758_Moto
    I'll have to double check, but I'm pretty sure my cruise control speed is accurate
  10. Apr 8, 2022 at 4:14 PM
    #190
    pltommyo
    Tom
    Yes, I have the OV 91 Octane tune with adjustments for 33s.
  11. Apr 8, 2022 at 10:10 PM
    #191
    CAG Gonzo
    2018 OR DCLB BarRed
    It's definitely not accurate for mine. Off by about 2mph. But I have the Rough Country model though I'm pretty sure I've read that it's the same thing, different brand.
  12. Apr 9, 2022 at 12:28 PM
    #192
    mlr69
    South Carolina
    It is the same - the Rough Country unit is a re-branded Hypertech.
  13. Aug 10, 2022 at 9:31 PM
    #193
    CBAD18Taco
    CBAD18Taco Well-Known Member
    Carlsbad, CA
    2018 MGM TRD OR 4X4
    Eibach Pro-Truck 2.0 front Coilovers Eibach Pro-Truck rear Sport Shocks JBA UCA Cali-Raised LED Rock Sliders 4WP Front Bumper w/wings Pro-Comp lights OB ARB compressor 265/75R16 General Grabber ATx tires
    I am not sure why, but I have had an almost completely different (backwards??) experience with the Hypertech inline calibrator than most on here.
    I have 285/75R16s on my 2018 TRD OR DCSB (stock tires were 265/70R16, so theoretically a 1" difference between stock and current tires). I have stock gearing.
    I set the unit up using the metric tire sizes and it gave me a correction factor of 1.034. My tires are pretty new so there is not much wear. (I don't have my old tires so I can't say what the actual tire size was. Bottom line is they are about 1" different so that is the best I can do).
    Before I installed the Hypertech unit (i.e. stock/factory settings) the following was true at 65MPH:
    1. CC and speedometer matched perfectly (i.e. when I have my CC set to 65 on the center cluster the speedometer was steady at 65MPH)
    2. Actual GPS speed measured with my phone was about 2.5 mph faster at 65mph (i.e. when my CC/speedometer showed 65 my actual GPS speed is steady at 67.5)
    After installing the Hyptertech (with latest firmwear) this is now true at 65MPH:
    1. CC and actual GPS speed (measured with same app and same phone) match perfectly (i.e. when my CC is set to 65MPH my actual GPS speed is steady at 65MPH)
    2. Speedometer shows 67MPH (speedometer shows 2 MPH faster than CC/GPS at most all speeds (55MPH to 75MPH))
    Conclusions:
    1. My speedometer is now 2MPH faster than actual speed when it was 2MPH slower than actual speed
    2. My CC was 2MPH slower than actual speed and now it is the same as actual speed
    Not sure why this is happening. Anyone have any ideas?
    I am going to call Hypertech tomorrow to see what they say.
  14. Aug 10, 2022 at 9:38 PM
    #194
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Just have it shipped to a UPS store just across border then swing by and pick it up.
  15. Aug 10, 2022 at 9:48 PM
    #195
    CBAD18Taco
    Carlsbad, CA
    2018 MGM TRD OR 4X4
    I bought my Hypertech about 3 weeks ago and I live in SoCal and had no problems/restrictions buying it or receiving it.
  16. Aug 10, 2022 at 10:06 PM
    #196
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    I am wondering when will Hypertech have their calibrator available for the '22s. It's been a while since the '22s has been out.
    The main thing is that I want the odometer to stay accurate whenever I add bigger tires.
  17. Aug 11, 2022 at 9:40 PM
    #197
    CBAD18Taco
    Carlsbad, CA
    2018 MGM TRD OR 4X4
    So I zeroed out the unit and reset it to the same correction factor as before (1.034).
    Now it seems to be dialed in correctly. CC, Speedo and GPS are all pretty close +- .5 mph. Must have been a glitch in the download/setting or something the first time. I will run it some more for verification.
  18. Aug 11, 2022 at 9:44 PM
    #198
    CBAD18Taco
    Carlsbad, CA
    2018 MGM TRD OR 4X4
    Also, I am thinking about Velcroing the unit to the top of the dash cluster so I only have to pop off the plastic vent covers if I ever have to access it again.
  19. Aug 11, 2022 at 10:20 PM
    #199
    CAG Gonzo
    2018 OR DCLB BarRed
    I velcro'd mine to the outer wall of the air duct to the left of the head unit and routed the USB cord down by the middle kick panels so I can snake it out easily.
  20. Aug 12, 2022 at 4:36 AM
    #200
    OldCity
    OldCity Well-Known Member
    St Augustine Florida
    2022 Tacoma TRD Offroad DCLB
    Icon Stage 3, 285/70/17 KO2/Fuel Tech 17x9 +1 Offset, Cab mount chop, DiamondBack Tonneau, KDMax Pro+XT,
    The current calibrator works for a 22 even though the 22 is not listed.
    RicerRabbit[QUOTED] likes this.
