Speedo calibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sky65, Oct 17, 2013.
  1. Oct 17, 2013 at 11:57 AM
    Sky65
    Sky65 [OP] Well-Known Member
    Is there a way to recalibrate the speedo and odometer to compensate for larger tires?
    Thanks
  2. Oct 17, 2013 at 3:02 PM
    BradyT88
    BradyT88 Well-Known Member
    You only real option is one of these:
    http://www.autoanything.com/perform...ngid=274x331&gclid=CP6V44bvnroCFa9fQgodV3gAHQ
    but at that price it's not really worth it... I'd just use a GPS, like on your smart phone and learn what is what basically. I chose to get an Ultragauge and have it calibrated to read correctly. Doesn't fix the speedo, but you can put it near your gauge cluster and use it as one, plus it tells you a lot more than the gauge cluster and can even read codes if needed. About a 1/4 the price of the calibrator too.
    http://www.ultra-gauge.com/ultragauge/
  3. Oct 17, 2013 at 3:08 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    This one works great, super easy install and re calibrates your existing speedo so it reads properly. the software is incredibly easy to use all you do is enter stock size tire and new tire size. http://www.hypertech-inc.com/products-results.aspx
    The software is so easy to use if you run the USB cable down to your coin pocket you can plug it into your laptop and easily re calibrate as your tires wear.
  4. Oct 17, 2013 at 6:21 PM
    Sky65
  5. Oct 17, 2013 at 6:26 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    A larger tire actually may fix the too fast speedo with stock tires?!
    Stock tires (265/70-16) will read 65 mph, but be going a true 63 (per GPS)... With a 1" taller tire (265/75-16), 65 will be what the speedo reads when you are going 65 (per GPS)!
  6. Oct 17, 2013 at 6:28 PM
    Large
    Large Red
    I've read that also, I am going to need to buy one of these anyway from just getting done re-gearing though ;-\
  7. Oct 17, 2013 at 7:56 PM
    BradyT88
    I didn't know we were talking about such a smaller change in tire size. Like DavidK said, I'll bet your speedo is actually pretty close to spot on right now. I'd check it with a gps and see.
  8. Oct 17, 2013 at 8:02 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    newer tacos, you can move the speedo sensor to the tcase if i recall correctly. wyatt (awsumdc) did it.
    as for older, i put 31.5's on mine, and it became MORE accurate. so i ahvent messed with it.
  9. Oct 17, 2013 at 8:10 PM
    BradyT88
    2nd gens with the manual tranny already have the sensor in the tcase. Only autos have it at the wheels.
  10. Oct 17, 2013 at 8:15 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    so just change little gear?
  11. Oct 17, 2013 at 8:31 PM
    BradyT88
    The manuals can do that, but from what that other thread said, not many fit and even then he was still like 7 mph off at 70 and I think he said he was only about 10 mph off at 70 before so not much gain. I don't think it was worth the trouble for him.
  12. Oct 18, 2013 at 7:34 AM
    Sky65
    According to my gps, a 6 mo old Nuvi 2555 the speedo was correct with the stock tires and now is about 3 mph slow at 65 gps speed. Not much I agree but I'd like to have it right in or a little fast. Guess I should verify my gps speed indication.
  13. Oct 18, 2013 at 11:10 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Per GPS? I have two GPS units and they read 2 MPH difference between each other. Both are Garmin's. Speedometer may not be exact on the Tacoma but also the GPS's are not always perfect either.
  14. Oct 18, 2013 at 5:35 PM
    David K
    I had a Mio GPS first, and now have a Tom Tom... it says I am going the same speed as the Mio did... ? I think I also checked with my handheld Garmin eTrex...
  15. Oct 18, 2013 at 6:10 PM
    WV150
    South Carolina
    Did you set them side by side to see if they were the same? I could go maybe ten miles with them both the same and then two MPH difference then one MPH and then back to the same. One of them was changing and not staying accurate.
  16. Oct 18, 2013 at 8:03 PM
    Sky65
    I checked the speedo again with my phone using Waze. It agreed with the Niuvi 2555 speedo is showing a little slow. According to the Toyota parts guy and my vin, my truck has 3:72 rears and used a driven 28:11 gear. He wanted $40 for a 29:11 gear. I took the part number to a friend at a Lexus dealer. $22 from him. Apparently the Toyota guy was behind on his house payment. I ordered the gear from Lexus. I'll post how I make out when it comes in next week.
  17. Oct 23, 2013 at 10:26 AM
    David K
    No, as one replaced the other... I drive to 65 on the Tacoma speedometer and look at the GPS... and compare. With stock tires (265/70-16), the GPS showed I was going 63 (ie. the truck speedo read too fast). With 265/75-16 tires they matched. The new GPS reads the same as the old when the truck speedo says 65.... ie. 65.
  18. Oct 23, 2013 at 10:39 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I also have the speedo reading +2 mph compared to the GPS but oddly enough, the trip/odometer is right on the money with the mileage markers. It was dead on the tenth for over 10 miles coming to work every day checking it out and also out on road trips for longer distances than that along I-10. Oh, running 265/70/16s..............guess I'd rather have the mileage correct rather than speedo if both can't be. That way the mpg math works out and there's a 2 mph cushion that could possibly keep you from getting pulled over.
  19. Oct 23, 2013 at 10:49 AM
    BradyT88
    I have also found this. I am running 33's and have a 9% difference on the odo compared to gps but only a 6% on the speedo. I think the factory set the odo to match up and intentially set the speedo to read 1 to 2 mph high so you have that cushion.
  20. Oct 24, 2013 at 10:22 PM
    David K
    Interesting!!!
