Speedo/odo Hypertech 730107 calibrator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jan 15, 2015.
  1. Mar 4, 2017 at 3:15 AM
    evskie53
    evskie53 The Problem Child
    Denver
    2011 DCSB Sport
    How was the install?... can't seem to find details about how this is installed. Do you have to pull the dash apart?
  2. Mar 4, 2017 at 9:26 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Yes, you have to pull the dash apart. You have to remove the instrument cluster and the calibrator plugs into the factory harness, and the calibrator plugs in to the cluster where the factory harness did.
    On a scale of 1-10, based on difficulty of install, I'd say it is a 3...pretty straight forward and easy.
    evskie53[QUOTED] likes this.
  3. Dec 5, 2017 at 3:51 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Hi guys, I’m getting 285/70 17 and I would like to correct the speedo. Is this something that you have to leave plugged in? Or you programmed it and remove it?
    I’ve seen this, are they the same?
    http://www.hypertech-inc.com/SpeedometerCalibrator.aspx
    I have an UltraGauge plugged in that I would like to keep.
  4. Dec 6, 2017 at 4:18 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    It stays installed behind the cluster.
  5. Dec 6, 2017 at 4:22 PM
    rheath08
    Russell
    Bakersfield, CA
    I installed one in my truck and had nothing but problems with it. I would start the truck up and drive off, the Speedo would not work and stay at 0 mph. It would set a check engine light every time that happened. Sometimes a couple times a day. I exchanged it with 4 wheel parts where I got it. The new one did the same thing. Hypertext tried to update the unit before I exchanged it. I have just keep in mind that at freeway speeds I'm 3 mph faster than stated.
    It's good to hear that people have them work.
    El Tano likes this.
  6. Dec 6, 2017 at 7:08 PM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    Auto trucks read speed via wheel speed sensors. Gears do not affect speedometer, only tire diameter.
  7. Aug 19, 2018 at 1:27 PM
    Tacomoto23
    Tacomoto23 Well-Known Member
    Carey
    Torrance,CA
    21’ TRD 4x4
    Just installed this unit on my truck last night... My truck with the regar and bigger tires was 5 mph faster than it was reading. After the install it now reads 10mph slower.
    Any tips on what I should do from someone that had this same problem? I left the USB plugged into the black box for easy access when I change tire size.
    Did anyone unplug their battery at the time of install?
  8. Aug 24, 2018 at 5:56 PM
    briscoe53
    briscoe53 Well-Known Member
    jesse
    Apex, NC
    2015 Toyota Tacoma
    I was told by hypertech to hook my computer up and change the tire size till I got the correct speed. I was about 10mph off when I did all the measurements they say you need to in order for it to get the correct speed. It doesn't work that easy and the tech seemed to know the issues and that was his fix. I just drove around till I got it correct.
    Tacomoto23[QUOTED] likes this.
  9. Aug 24, 2018 at 6:49 PM
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    The "speedo" gear you are talking about is the transmission output speed sensor. And the 2 different part numbers are for 2 different transmissions. Dont swap that out unless you want your abs to freak out.
  10. Aug 26, 2018 at 1:11 AM
    Tacomoto23
    Carey
    Torrance,CA
    21’ TRD 4x4
    Right on. So what I came to realize from emailing Hypertech is that our trucks read the speed from sensors in the wheels rather than the trans. I had input my gear ratio change into the app which showed for the 10mph slower. They told me to leave the gear ratio un-touched and just input your tire size. So I went back and corrected it and it’s only 2 mph off now!
    I’m sure I can get it more dialed in if I measure the tires as they are worn
