Speedo off due to larger tires and gas milage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Carlo, Mar 4, 2011.
  1. Mar 4, 2011 at 7:39 AM
    Carlo
    Carlo [OP] Well-Known Member
    CA
    2010 Taco Magnetic Grey
    5100's all around, front at 0 with Ebiach springs up front; Wheelers 3 leaf AAL rear, Spidertrax
    So, I calculate my milage and get pissed off all the time because I get about 14 to 15 in town and 17 on the highway. But, I just started to think that maybe my change in tires from the stock 245's to 265/75/16's may be effecting my milage calculation. I figured out the my speedo is off about 4% so does that mean that I am actually getting about 4% more miles to the gallon? Not that it's that much difference, but, around town I am only getting about 250 miles to a tank.
  2. Mar 4, 2011 at 7:44 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    You correct. I had to increase to 8-9.x% for mine(dont really remember). I get about 275 tank with my 33's. If you have the money you could get an ultragauge or scangauge and input the % difference and track your MPG.
  3. Mar 4, 2011 at 8:31 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Actually the miles you traveled was off by 4%. If your speedo said you went 100 miles, you actually traveled 104. Here is a good tire size calculator . According to this you are off 3.9%.
  4. Mar 4, 2011 at 8:45 AM
    tacoman007
    tacoman007 ignorance is bliss,
    Josh
    san diego
    07SR5ACCESSCABDEBAGED4X4
    alpine headunit,12'' rockford fosgate sub,ipod in g-box,drop in K&N, Marine decor,5100's front/rear,uniden pc68xl,radioshack PA speaker
    i bought a hypertech to fix the tire size problem. really easy to install
  5. Mar 4, 2011 at 8:50 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    First of all, separate your thinking from the speedo and odo. The speedo was off before you switched. It read about 4% fast with the stock tires and should be accurate with your new tire size.
    The odo is another matter. It was accurate before and with the new size will now read about 4% slow (3.9% according to the above post). So you need to multiply your miles by 1.039 to get your true miles, then divide that by the gallons to get your actual MPG.
  6. Mar 4, 2011 at 9:42 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Dealer can change the tire size settings with the scan tool. Usually 1hr labor.
  7. Mar 4, 2011 at 9:43 AM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    chris4x4 once told me, for 33s you have to multiply your speedometer by .0743 in order to get the correct mileage
  8. Mar 4, 2011 at 9:49 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    The miata.net one posted above is a good calculator. I think it has been around since the beginning of the interwebz.
    According to that site, I'm off 6.9% going from 265/70/16 to 285/70/17's.
    I guess I should slow down a little bit then...
  9. Mar 4, 2011 at 10:01 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    I heard that the dealer can reflash your ECU to correct your speedo. Try using www.fuelly.com to track your MPG.
  10. Mar 4, 2011 at 10:07 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    multiplying speedo to get your mileage makes no sense...
  11. Mar 4, 2011 at 10:12 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Neither does speedo being correct but odometer being off.
  12. Mar 4, 2011 at 10:14 AM
    The_Hodge
    SC
    that has to do w/ the digital/analog conversion....
    stock, the ODO will be correct and the speedo will be off. it's been covered in other threads.
  13. Mar 4, 2011 at 10:19 AM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    If that's the case, then why am I getting 14.5 or less with my stock tires. This tank im on, I have kept it under 2500rpms. I will fill it up and see. I hear all these tacomas kicking my ass with the fuel mileage they are getting... im jealous.
  14. Mar 4, 2011 at 10:21 AM
    The_Hodge
    SC
    2k rpms is the magic number on the 4.0 autos
  15. Mar 4, 2011 at 7:40 PM
    Superx2
    Joey
    Iowa
    so i filled my tank up after work tonight and did the mileage. 14.6 wtf? my wife thinks its great. that is using 89, average temp was prolly 35 degrees. guess it is what it is.
  16. Mar 4, 2011 at 7:46 PM
    The_Hodge
    SC
    i get better than that on 35s
  17. Mar 5, 2011 at 8:41 AM
    05Moose
    Jim
    I'd say something is wrong then. Is it all highway miles or short trips. If short trips, I can see it happening in the cold. I've been driving all week to a training class that's 60 miles each way. A lot of stop and go on the freeway in the mornings. I've been getting anywhere from 20 to just over 21 mpg...and that's running 265/70-16 Michelin LTX AT2 tires. Wider than stock for an SR5. Now if I travel just 20 miles to the bus, then I get around 18 mpg. Big difference on the short trips.
  18. Mar 5, 2011 at 8:49 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I would like to hear how the odometer and speedometer are not connected...
    If you travel 60 MPH on your speedometer (that is reading true per your GPS with the 32" tires [265/75-16]) then in exactly one hour your odometer should read 60.0 miles... yes???
  19. Mar 5, 2011 at 9:52 AM
    The_Hodge
    SC
    no. the easiest way to test this is to clear a trip meter while stopped with the nose of your truck at a mile marker, then drive to the next mile marker with your nose stopping at the same point. your ODO wioll read slightly slower. it can be better seen through a SG2 or UG as it will break it down into the hundredths of a mile.
    the ODO is spot on, but because of the digital to analog conversion to the speedo, that's why it's off. they are on seperate feeds. one goes digital to digital to the ODO, the other goes digital to analog to the speedo. anyone knows that if you put on a larger tire, the ODO and speedo will read slower if there hasnt been a recalibration to correct the size difference.
  20. Mar 5, 2011 at 10:08 PM
    David K
    So Toyota on purpose fixes the speedometer to read too fast with 265/70-16 (31") tires... but the odometer is spot on. Is there some adjustment for each model that has different size tires so they all have perfect odometers?
    Now, with the new 265/75-16 (32") tires my speedometer is spot on... but you say the odometer will read slower than the speedometer because they are not connected? If they are not connected, what turns the odometer if not the speedometer/ tires/ transmission???
    Any easy fix if I want the odometer to be as good as the speedometer with accuracy?
    Thank you!
