speedo off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by old dad, Mar 7, 2011.
  1. Mar 7, 2011 at 10:58 AM
    old dad
    old dad [OP] Well-Known Member
    mark
    sc
    tacoma pickup
    n/a
    My 2010 totally base 2.7 manual reg cab tacoma was passed on the interstate yesterday by my wife,,Mrs. "I always drive the speed limit." I had my cruise set on 70mph and the wife went around me and off she went. We got home and she stated that in following me on the road her lumina speedo was showing me only doing 66mph,,she said when she passed me that her cruise was on 70. I can believe it as I get passed all the time when I am supposedly doing the speed limit.
    Is this a common thing on our speedo's reading faster than what is the actual speed.
    mark
  2. Mar 7, 2011 at 11:01 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    According to my TomTom, my speedo was 3 mph fast at 70 with my factory size tires. There is a lot of talk about this on here.
  3. Mar 7, 2011 at 11:01 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    yup, pretty common.
  4. Mar 7, 2011 at 11:03 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    According to my GPS/ friends, my speedo is off by 12mph at 70 :(
  5. Mar 7, 2011 at 11:09 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Yes. It's quite common for all makes, with Stock wheels/tires, for speedos to read are up to 10% faster than actual speed. I'm not sure if it's the 'nanny' factor or just anticipating that people go oversize tires.
  6. Mar 7, 2011 at 7:29 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    That's funny. That's kind of how I discovered it years ago before I was even on any of the forums. My wife was following me home after getting new tires and called me on my cell. She wanted to know why I was only doing 61 in a 65 zone. Then we started checking it against radar. The '05 Highlander we had at the time was 100 percent accurate. The Tacoma speedo reads 4 mph fast at 65, 3 mph fast at 40, etc. Interestingly enough, while our old '05 Highlander was spot on, our '10 Highlander reads fast just like the Tacoma (by the same amount). Oh, and don't confuse the speedo reading fast with the odometer. Two separate processes. The odo will be accurate.
    Here's a link to the acceptable error Toyota allows at each speed if you're interested:
    http://i292.photobucket.com/albums/mm7/05Moose/Technical/Acceptible_Speedo_Error.jpg
  7. Mar 7, 2011 at 7:48 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    My 70 is close to 65/66 mph. Checked it to a GPS , had to recalculate my mpg even. My KLR 650 did the same thing. I dont recall the precise wording , but feds allow a speedo to read slightly high but never low, so , that with liability , you end up with a sort of safety error.
