Speedometer inaccurate (not just the usual complaint!)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SCFirefighter, May 1, 2010.
  1. May 1, 2010 at 7:01 PM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    My 2010 Taco, too, suffers from the often reported inaccurate speedometer. The faster I drive, the higher the inaccuracy of the needle.
    I called my dealership about this, and they told me that "if they were to measure the computer it would also show this inaccuracy. It's within tolerable levels and nothing we can do about."
    Well, this is not true. I recently received my ScanGauge and noticed that the MPH gauge is DEAD ON accurate reporting the speed of my vehicle as my GPS is, at all speeds. The speedometer needle, however, is still off.
    This leads me to believe it's something they can and should fix. Has anyone else noticed this ECM read-out as well?
  2. May 1, 2010 at 7:03 PM
    PreRunner
    PreRunner Well-Known Member
    sounds like good excuse for larger tires
  3. May 1, 2010 at 7:06 PM
    SCFirefighter
    Stephan
    Cary, NC
    That's the usual remedy I've heard, but doesn't that contradict the fact that the ECM, which drives the speedometer needle, is actually accurately reporting the vehicle speed?
  4. May 1, 2010 at 7:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    They probably could- but they aren't going to. There is error inherent in the digital to analog conversion and if that tolerance it met- Then there isn't a problem- just something you don't like.
    If you have a GPS and a scangauge- Who cares if the speedo read correctly or not??
  5. May 1, 2010 at 7:10 PM
    SCFirefighter
    Stephan
    Cary, NC
    It's the principal of the matter. I've driven my share of cars, and moved my GPS from car to car in the past years (rentals, friends, previously owned vehicles, mine, the wife's), and I have just never seen a misrepresented needle. In 2010 that shouldn't happen to a brand new $30,000 vehicle. You're completely right: it's just something I don't like :)
  6. May 1, 2010 at 7:12 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    get 32" tires...it'll put the needle damn close and give you a slightly extended warranty :D
  7. May 1, 2010 at 7:14 PM
    SCFirefighter
    Stephan
    Cary, NC
    Thinking about new tires, but I can't afford it just now. Haven't even made the first car payment yet and sunk over $2k into the truck already lol :)
  8. May 1, 2010 at 7:16 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If the scangauge and the GPS agree on the speed and the speedo is wrong- and then you put larger tires on it and the speedo shows correctly...You'll be speeding all the time. So like 5 mph over highway speeds will really be like 10 or 11 over....
  9. May 1, 2010 at 7:18 PM
    SCFirefighter
    Stephan
    Cary, NC
    Very true.
  10. May 1, 2010 at 7:18 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    U.S.A.
    2023 RAV4 XLE Premium
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Mine is off almost 3 MPH at 60. ..... Think of the money saved on warranty claims at 4%+ over-mileage on OD.
  11. May 1, 2010 at 7:22 PM
    SCFirefighter
    Stephan
    Cary, NC
    That thought really, really bothered me before I got my SGII, but now that's no longer a worry of mine. Since the ECM is accurately reporting the speed of the vehicle, it stands to reason it is accurately reporting the mileage displayed on the OD.
  12. May 1, 2010 at 7:33 PM
    The_Hodge
    SC
    from my 2 that i've had, the speedo has been off, but the ODO was dead on. now running 33s or 35s, both are off
  13. May 1, 2010 at 7:36 PM
    SCFirefighter
    Stephan
    Cary, NC
    That's exactly what Brunes posted earlier, and I suspected too. That will mess up your speed and odo readings, even though your needle might show a more accurate reading, your ECM is not.
  14. May 1, 2010 at 7:39 PM
    The_Hodge
    SC
    i use my HU/NAV for the accurate speedo and trip mileage anyways....the 33s put me about 2mph off and the 35s put me about 4-5 off @ cruising speeds. ODO is off about 30 miles a tank or so...maybe a tad more on the 35s
  15. May 1, 2010 at 7:42 PM
    SOSHeloPilot
    U.S.A.
    I am lost now ... how can the speedo be off and the odo be on target ??
    Maybe I am thinking of the cars in the old days with the spinning speedo/odo cable .. :confused:
  16. May 1, 2010 at 7:44 PM
    SCFirefighter
    Stephan
    Cary, NC
    So what kind of mileage based warranty did you buy? :rolleyes:
  17. May 1, 2010 at 7:47 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    What if my spedo and GPS agree and the ScanGauge is about 2-3mph slower?
  18. May 1, 2010 at 7:48 PM
    The_Hodge
    SC
    haha...i'm through my "36k" miles now and am out of all warranty
  19. May 1, 2010 at 7:49 PM
    SCFirefighter
    Stephan
    Cary, NC
    You're in good shape. I think you can calibrate your ScanGauge to properly display your speeds. Think of your GPS display as the true measure of your speed. Also, your odo readings will be slightly in your favor :)
  20. May 1, 2010 at 7:52 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    can somebody break my speedometer? :laugh:
