speedometer issues
Discussion in 'Technical Chat' started by Stout890, May 12, 2011.
  1. May 12, 2011 at 12:09 AM
    Stout890
    Stout890 [OP] Well-Known Member
    Palmdale ca
    99 prerunner sr5
    Navigation, 10" sub, ome881 on billies 3" all-pro leaf springs with billies, taneau cover, k&n intake,axle swap with a E locker. 31" BFG A/T on premium wheels, hoola girl air freshener and a broadie knob!
    well guys i have a 99 ext cab that i picked up a week ago, it has some odd issues. one being that it has a dang ol spedo issue. so basically its 20mph off...
    i have 31x10.5 tires on it with a 2 inch body lift...so as far as i can think it should read a few miles to slow right...since i am covering more ground per revolution?
    but my trucks spedo problem seems to be the opposite way im about 20 miles off the other direction. so when im doing 70 it reads 90??? and the governor kicks in early at 80 mph now because it thinks its doing 100mph
    also the trip meter reads wrong it calculates milage way to fast when in reality it should be under calculating...wtf guys?
    anyone have this issue and how can i start to try and correct this?
    any ways thanks in advance for any input.:confused:
  2. May 12, 2011 at 2:59 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    there is a thread on here someplace that gives tire sizes and itll show how much that size will effect speedo readings.
  3. May 12, 2011 at 3:11 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Sounds like the truck has been regeared. I'm having that problem right now since i have regeared my truck.
    To fix it you need a new speedo gear. It goes in the transmission output where the drive shaft meets the tranny.
  4. May 12, 2011 at 3:14 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
