Speedometer troubleshooting
Discussion in '1st Gen. Tacomas (1995-2004)' started by tonymhouts, Mar 4, 2018.
  1. Mar 4, 2018 at 2:53 PM
    tonymhouts
    tonymhouts [OP] Active Member
    Wisconsin
    97 Toyota Tacoma
    low profile front/rear bumper, coil overs, 3 inch lift.
    Does anyone have a tried and true method for troubleshooting the speedometer?
    It has completely stop working. Sometimes when I smack the dash while driving it will go a little but not much.
    Is there anyway I can rule out the cable because that looks like it is going to make me cry if I have to replace that.
  2. Mar 4, 2018 at 3:11 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The gears in the odometer go bad. You can buy replacement nylon gears online.
  3. Mar 4, 2018 at 3:22 PM
    tonymhouts
    Wisconsin
    97 Toyota Tacoma
    Got a link on hand by chance?
  4. Mar 4, 2018 at 3:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I don't. Tried googling it but couldn't find someone who sells it. I know some Toyota truck part website sells it but I forget who.
  5. Mar 4, 2018 at 3:34 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Something like this but that isn't the correct one I believe
  6. Mar 4, 2018 at 8:49 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Done the cable twice on my 97, it's not that bad of a job. Getting the cluster out is probably the most time consuming.
    P.s. if you do a new cable, make dam sure it doesn't touch the exhaust or you get to do it again in the near future.
  7. Mar 5, 2018 at 5:30 AM
    1997tacomav6
    Denver
    How do you know it's the cable or the gears in the speedo unless it stops?
    Mine has a howling sound that comes and goes from behind the dash.
  8. Mar 5, 2018 at 4:21 PM
    vern650
    brandon
    hyrum, ut
    I unhooked the cable from the transfer case end first and made sure it wasn't broken on that end. Everything looked fine down there so I pulled the cluster and the cable was broke off right at the gauge. There's really not much to the speedo, not really any gears in there. It works more off of friction I think. Either way if it's not broke at the tranny end, the clusters gotta come out to diagnose.
    1997tacomav6 likes this.
