Speedytech7's 95.5 - Going nowhere fast build
Discussion in '1st Gen. Builds (1995-2004)' started by Speedytech7, Mar 19, 2014.
  1. Feb 13, 2016 at 1:52 PM
    #41
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well I might as well restart this build thread since stuff is happening again. Here is the front torn down to get ready for the new bumper.
    MadTaco461 likes this.
  2. Feb 13, 2016 at 3:33 PM
    #42
    Blues0010
    Blues0010 Well-Known Member
    Ben
    Boise, ID
    2001 Tacoma SR5
    Awesome truck. What bumper do you have going on there?
    How did you decide on the color of your SCS F5s? I'm stuck between gunmetal and bronze also for a Jade Mica truck.
  3. Feb 13, 2016 at 3:59 PM
    #43
    Speedytech7
    Thank you! I have a relentless fab bumper going on hopefully tonight.
    I thought the gunmetal would look good and I had painted some other Chrome bits on the truck with ruatoleum gunmetal and liked that. But that bronze does look really good too and would look great I think.
  4. Feb 14, 2016 at 9:58 PM
    #44
    Speedytech7
    It's on!
    jjsul, Blues0010, m3bassman and 2 others like this.
  5. Feb 14, 2016 at 11:35 PM
    #45
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I need me some headlight hoops like that!
  6. Feb 15, 2016 at 9:12 AM
    #46
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  7. Feb 20, 2016 at 9:08 PM
    #47
    MatthewMay1
    Matthew
    Lone Star Republic
    I think it is time for a sig pic update
  8. Feb 20, 2016 at 9:15 PM
    #48
    Speedytech7
    I do believe you're right! New members probably think I'm talking out of my ass after looking at my stock truck in my sig :laugh:
    MatthewMay1[QUOTED] likes this.
  9. Feb 20, 2016 at 9:45 PM
    #49
    Speedytech7
  10. Feb 20, 2016 at 9:48 PM
    #50
    MatthewMay1
    Matthew
    Lone Star Republic
  11. Feb 24, 2016 at 10:58 PM
    #51
    EastWaTaco
    EastWaTaco Well-Known Member
    Angelo
    82 4x4 with a 3rz
    That things sweet! I'm in the Wenatchee area, gunna go check out a 95 taco that's for sale
    Speedytech7[OP] likes this.
  12. Feb 25, 2016 at 1:04 AM
    #52
    Speedytech7
    Thank you, are you having a look at the one in Oroville? Just make sure to check the frame, preferably with a ball peen hammer to make sure it isn't sitting from the inside out. Good luck post pics if you get it.
  13. Feb 25, 2016 at 7:06 AM
    #53
    EastWaTaco
    Angelo
    82 4x4 with a 3rz
    That's the one haha. And yeah I'm gunna go through it pretty good and see if he'll take $5800
  14. Feb 25, 2016 at 10:52 PM
    #54
    EastWaTaco
    Angelo
    82 4x4 with a 3rz
    Picked her up today! A few rattles, and runs a little cold but I should be getting it all worked out. If I really needed to, I'm sure I could sell it for a bit more than I paid for it. Frame is free of rust other than usual light surface stuff around the rear.
    She won't be stock for long :goingcrazy:
  15. Apr 5, 2016 at 9:45 PM
    #55
    EastWaTaco
    Angelo
    82 4x4 with a 3rz
    did you use any axle shims or a carrier drop after installing the leaf packs? I've got some pretty good vibrations going on around 20mph.. About to pull the $70 trigger on a carrier bearing drop but figured I should get a second opinion before hand.
  16. Apr 5, 2016 at 10:50 PM
    #56
    Speedytech7
    I used 3 degree axle shims, no vibes here!
  17. Apr 6, 2016 at 5:08 AM
    #57
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    You can buy a handful of washers and try that instead of dropping $70
    aeok18109 likes this.
  18. Apr 15, 2016 at 11:01 AM
    #58
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Hi,
    You menioned that you had installed axle shims on your truck. Can you give me some info? After my AP expo leaf install I have driveline shutter. Thanks.
  19. Apr 15, 2016 at 11:08 AM
    #59
    Speedytech7
    Yup, I certainly did. I got 3 degree shims on the suggestions I received from a member named @presto who is no longer very active. My lift was a bit extreme in the beginning at over 4in in the rear. But with the 3 degree shims there were no vibrations. I would consider trying something a little less if your lift is around 2.75in like most here, maybe a 2 degree shim. They are super easy to install but make sure to buy new u bolts and have center pins that are long enough to accommodate the added height of the pack. I believe Low Range OffRoad sells them and so does Wheeler's Offroad. If you have any other questions feel free to ask.
    quetzal[QUOTED] likes this.
  20. Apr 15, 2016 at 11:10 AM
    #60
    quetzal
    Mario
    Long Beach, CA
    Thanks for your response, mine is at around 3" of lift so I think I'm going to get the 3 degree shims too.
