Spicer xc OEM carrier bearing alternative (4wd ONLY)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Mar 27, 2018.
  1. Oct 12, 2018 at 7:46 AM
    #41
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    luh you too bae *rolls eyes, kissy face*
    @ChadsPride Being 2wd, like my buddy above stated, you are going to wanna stick with the OEM sloppy doughnut due to not having a slip joint in the rear section of the drive shaft. Rear driveline extension and contraction is done via the slip yoke at the trans so the driveshaft actually moves forward and back through the OEM CB quite a bit and is why the OEM CB is so sloppy.
    Now if you wanted to stiffen things up you could easily have a driveline shop add in a slip joint on the rear section of the shaft and get one of these ford ranger CB's that everyones using (including myself)
    BassAckwards likes this.
  2. Oct 12, 2018 at 8:03 AM
    #42
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I've got one for you if you need. Modified stock.
    ChadsPride[QUOTED] likes this.
  3. Oct 12, 2018 at 8:10 AM
    #43
    ChadsPride
    Sponsored by TacomaWorld.com
    Interested in this. I'd like to buy a nice one, but having trouble finding the correct one for my pr
  4. Oct 12, 2018 at 8:36 AM
    #44
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Still going strong with this carrier bearing. Much better than oem
  5. Oct 12, 2018 at 4:01 PM
    #45
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I accidentally bought the Pre Runner version and injected the empty space with polyurethane to stiffen it up. If you wanna get me the 4wd spider version, you can has the 2wd version I have.
  6. Oct 30, 2018 at 5:37 AM
    #46
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    So is this solution the real deal??? I know you've been fighting this issue for years.
  7. Oct 30, 2018 at 8:13 AM
    #47
    anthony250f
    Anthony
    San Diego, CA
    Yup
  8. Oct 30, 2018 at 11:26 AM
    #48
    nd4spdbh
    SoCal
    It will help. But i cant guarentee a solution. I sitll have driveline vibes mainly due to axle wrap.... a double cardian joint in the center might be the end solution, but with the new OME dakar medium packs driveline vibes are well under control now.
  9. Oct 30, 2018 at 1:45 PM
    #49
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    So can anyone in here explain the benefits of a poly CB vs the stock OEM one? is this mainly beneficial for lifted applications to reduce vibes?
  10. Oct 30, 2018 at 1:56 PM
    #50
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Rubber or poly makes no difference in vibrations, it's your pinion angle that makes a difference. The poly vs OEM style is the stiffness in the bushing. Poly will last longer than the rubber bushing as we've seen in other applications.
    BassAckwards[QUOTED] likes this.
  11. Oct 30, 2018 at 2:08 PM
    #51
    BassAckwards
    Gotcha! So the main benefit here is the increased longevity of the bearing. Thanks Chris! :fistbump:
  12. Oct 30, 2018 at 2:30 PM
    #52
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    More the bushing than the bearing. The rubber bushing wears much quicker than the bearing does.
  13. Oct 30, 2018 at 3:58 PM
    #53
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Which increases the longevity of your u-joints which increases the longevity of your pinion gear seal and bearing which increases the longevity of your whole rear axle so if neglected too long it can cause a cascade of repairs
  14. Nov 5, 2018 at 7:22 AM
    #54
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    After going through a couple OEM Spicer CBs, I decided to go this route thanks to this thread. Put it all on this weekend, still need to pull it and paint it but results are good, I have a slight, slight stutter at 10-15 MPH but it's so much better than the stock units were. My setup, with a 2"-2.5" lift is just under a 2" drop spacers to make this setup work. I used 1" square tube, some 1/4" bar stock for the base and 90 MM long M10 x 1.25 pitch class 10.9 metric bolts.
    DrFunker and TireFire like this.
  15. Nov 21, 2018 at 4:42 PM
    #55
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Those of you that have done this. What was the thickness of your square tubing? Wanna make sure I dont eff this up
  16. Nov 21, 2018 at 5:02 PM
    #56
    anthony250f
    Anthony
    San Diego, CA
    I think it was 1/8”
  17. Nov 21, 2018 at 5:06 PM
    #57
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Only seem to be finding 1/16" thickness. Think that would be fine? Just placed an order for the spicer CB. Hoping to knock this out this weekend. My current cb is trashed
  18. Nov 21, 2018 at 5:12 PM
    #58
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Mine is 16 gauge which is 0.065".
  19. Nov 21, 2018 at 5:16 PM
    #59
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Okay and thats ever so slightly thicker than 1/16". Yours holding up fine?
  20. Nov 21, 2018 at 5:21 PM
    #60
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    So far, so good.
