SPIDERTRAX with 16" OEM steel wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Oct 16, 2012.
  1. Oct 16, 2012 at 5:14 AM
    TAC1
    TAC1 [OP] Well-Known Member
    Petros "Peter" AGE: 44
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    Hello Forum,
    I have been reading up quite a bit on the Spidertrax wheel adapters. I read that it is recommended to use "shank" type lug nuts but my OEM steel wheels use accorn style lug nuts. I don't remember for sure but I think someone on this forum is running the Spidertrax with steel wheels. I would like to know if it is posssible to do this.
    I normally would not have gone for wheel adapters but I have not read ONE bad review about the Spidertrax Hub centric adapters.
    BTW, do they come in 1" widths also? I only see them in 1.25" or 1.50"
  2. Oct 16, 2012 at 5:19 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Im on the hunt as well, bora i think its called caught my eye little cheaper and have good reviews... Im on the fence about it but worth a look... As for your question no idea.... Also when you go 1" spacer it becomes too short and you may need to put lug extentions on.... But dont quote me on that but time on tw will tell :p
  3. Oct 16, 2012 at 5:23 AM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    +1 for spidertrax. I ran them on my old 2004 4Runner and they were amazing.
    Great look and I kept the stock wheels (which I liked).
    I highly recommend them!
    Pay the price and do it right the first time, Spidertrax are the best spacers around.
  4. Oct 16, 2012 at 7:49 AM
    badger
    badger Well-Known Member
    07 SR5
    All Pro sells a 1" spacer and they work fine too. You need extended thread shank nuts to install the spacer to the truck. All Pro has them. I can't remember if they come with the spacers. Be sure to loc-tite and torque them. As for the wheel, you use the nuts designed for that wheel. The spacer doesn't change that.
