Spiker Engineering Ultimate Lift Hood Struts now on Amazon
Discussion in '3rd Gen. Tacomas (2016+)' started by SpikerEng, Jun 13, 2021.
  1. Jun 13, 2021 at 7:18 AM
    SpikerEng
    SpikerEng [OP] Well-Known Member
    Leon
    Palos Verdes, CA
    antlab67, Skydvrr, rmreid20 and 4 others like this.
  2. Jun 13, 2021 at 7:25 AM
    stay_tuned
    stay_tuned Well-Known Member
    Bryan
    DMV
    2021 Tacoma OffRoad DCSB 6SPD BRM
    does this affect hood mounted ditch lights since it goes higher?
    Mark77 likes this.
  3. Jun 13, 2021 at 7:41 AM
    betrayus
    betrayus Milk steak connoisseur
    Denver
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    It can, but usually you just have to angle them slightly from videos I've watched. They both still fit maybe just not at the orientation you wanted to ditch lights at. If you look at install videos a lot of guys will also have ditch lights and comment about em.
    ndoldman59 likes this.
  4. Jun 13, 2021 at 8:01 AM
    SpikerEng
    Leon
    Palos Verdes, CA
    Not at all - our hood struts have the unique ability to set the hood height wherever you want it, between stock height and up to 8" higher. So you choose the height you want, and if you have ditch lights, you just set the hood to where a small gap remains between the lights and the windshield. Here are a couple of examples:
    eurowner, Bertw192 and Devious6 like this.
  5. Jun 13, 2021 at 12:51 PM
    wornandtorn
    wornandtorn Well-Known Member
    2020 Cement Tacoma TRD Sport 4x4
    @SpikerEng Howdy, brother! I purchased a set of these from you earlier in the week and you had these to me in GA in just a few days. Thanks for the fast ship! Now on to my question: I don’t have ditch lights yet but will likely go for a set of BD Squadrons on a low profile mount, likely Cali Raised. With that in mind I know the range is 0-8” beyond the stock rod provided height. Is there a max height/distance you would recommend to ensure the ditch lights clear the windshield once mounted. I’d rather be safe than sorry.
    Congrats on picking up distribution on Amazon! Hopefully the additional customer reach you pick up will more than offset the hit to your margin. Absolutely incredible product! Great build and design - US engineered and built and it shows!
    SpikerEng [OP] likes this.
  6. Jun 13, 2021 at 4:19 PM
    JZinNM
    JZinNM Well-Known Member
    Southlake, TX
    2016 TRDOR DCLB
    I have a 1999 land cruiser as well as my Tacoma. I’m on my third set of hood struts. Do you make them for land cruisers?
  7. Jun 13, 2021 at 8:19 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    Just a plug, After a series of rigs with hood props, The Spiker lifts are a treat. Now I tend to forget there was the other way ;-)
  8. Jun 14, 2021 at 5:21 AM
    rmreid20
    rmreid20 Well-Known Member
    Bob
    Western TN
    2020 TRD
    Thinking of buying the Spiker struts, but don't have a rivet gun, any recommendations?
  9. Jun 14, 2021 at 5:54 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    Gilbert, AZ
    Black '17 OR
    I still need to get me a set of these! :( Good job on Amazon buddy!
  10. Jun 14, 2021 at 7:08 AM
    SpikerEng
    Leon
    Palos Verdes, CA
    Thank you for the kind words :thumbsup:.
    As for the ditch lights. "better safe than sorry" rule definitely applies, and the safest approach would be to have the ditch lights and mounting brackets on hand when setting up the hood height. That way you'll know that you'll have the needed clearance. Or you can look around to see if someone has the combo you want, and ask them how much higher then can raise the hood. Finally, you can always relocate the hood brackets if you end up needing to change the hood height. Having said all that, some low profile ditch lights out there allow the full 8" above stock height.
    wornandtorn likes this.
  11. Jun 14, 2021 at 7:11 AM
    SpikerEng
    Leon
    Palos Verdes, CA
    Sorry, we don't make replacement struts. You can pick up some Strongarm 4361 struts (I believe that's right for the LC100).
  12. Jun 14, 2021 at 2:09 PM
    JZinNM
    Southlake, TX
    2016 TRDOR DCLB
    Thanks for the recommendation.
  13. Jun 15, 2021 at 12:36 PM
    SpikerEng
    Leon
    Palos Verdes, CA
    You can add a basic rivet gun for ~$15 to your Amazon order :). Or you can use rivnuts and screws instead of rivets.
    rmreid20 likes this.
