Spindle Gusset Install ??s
Discussion in 'Long Travel Suspension' started by cccrockettt, May 14, 2014.
  1. May 14, 2014 at 8:56 AM
    cccrockettt
    cccrockettt [OP] Well-Known Member
    David
    central california
    Mid travel front and rear Fox w/ all pro
    Okay truck suspension is to the point that I need to gusset the spindles. My question is do I have to remove the spindle to weld it on or is there an easier way.
    If I do have to pull it off what tools do I need and does anyone know of a forum that has a good step by step pictorial that I can refer to if I have questions?
    If I can I would prefer to not have to fully remove it if at all possible. Just seems like that would be a lot of work just to do a simple job. I do have my own welder and plan on doing it myself just if I can would prefer that it not be a full day job for ten minutes of welding.
  2. May 14, 2014 at 9:05 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Encinitas/San Diego
    You can weld it on the truck. Just unbolt the upper arm from the spindle so you can move it around to get access. Done a lot this way.
  3. May 14, 2014 at 9:10 AM
    cccrockettt
    David
    central california
    That's a big relief. Looked like a lot more work than I wanted for just welding that thing on. You don't by chance have any pictures of how you do it do you?
  4. May 14, 2014 at 9:13 AM
    cccrockettt
    David
    central california
    Do you still remove the break rotors and all that or just loosen it from the upper control arm and cover everything to protect it from sparks?
  5. May 14, 2014 at 9:16 AM
    Supermoto
    Landon
    Encinitas/San Diego
    Didnt even take the brake rotor off and was able to reach everything. I used a ratchet strap to keep the spindle from falling down.
  6. May 14, 2014 at 2:52 PM
    cccrockettt
    David
    central california
    Awesome that's exactly what I needed. Thank you.
  7. May 14, 2014 at 2:54 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    this is how we did it.
    personally i removed the rotor for better access to it but it doesnt relaly matter.
  8. May 14, 2014 at 2:57 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    doesnt even take long to remove it...id rather do that
  9. May 23, 2014 at 1:31 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    0 double cab taco
    yea, i took mine off also, easy to do, and allows you to weld it on the bench.
