Spindle gussets, uca supports, and more
Discussion in 'Long Travel Suspension' started by evansa22, Jan 9, 2011.
  1. Jan 9, 2011 at 2:43 PM
    evansa22
    evansa22 [OP] Member
    Aaron
    SD
    04 trd 4x4
    front fg, aem cai, total chaos long travel front suspension with SAW coilovers
    just got my spindle gussets, uca supports, and secondary shock hoop for my tc long travel system. I'm goona have my friends dad put this stuff on cause he's a great welder/fabricator and knows what he's doing. Had a few q's though to aid in the process. To weld on the spindle gussets, does the entire spindle need to be removed? or is it simpler? Second, to weld on the uca supports, should we just unbolt the uca and thats it? Lastly, when welding the shock hoop to the frame, welding plate to the frame, then the hoop to the plate would be best? Just some thoughts in my head and wanted to get it all straight before we get started. Thanks in advance for any helpful advice!
  2. Mar 6, 2011 at 11:57 PM
    evansa22
    Aaron
    SD
    04 trd 4x4
    got this stuff on there two weeks ago, holding tough for now after a little testing in ocotillo. Spindle gussets and uca supports came with some instructions that helped in the installation. However nothing beats having a great fabricator who knows there stuff.
    spindle gussets
    upper control arms/ coilbucket brackets
    gusset for shock hoop
    assembled
    after a little testing.
    neone have any questions on install just hit me up.
    Aaron
  3. Mar 7, 2011 at 7:43 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    looking good man, i need to get some secondary shock hoops for my TC kit
  4. Mar 7, 2011 at 3:20 PM
    03aztaco
    03aztaco Well-Known Member
    adam
    lake havasu,mesa
    03 prerunner
    tc lt kit, king shocks, deavers, tc hangers,tc 12" shackels, king double bypasses, cab caged, beefed taco carrier bearing drop bracket, soild motor mounts,some more to lazy haha
    looks good bro
  5. Mar 7, 2011 at 3:25 PM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    yeah buddy!
  6. Mar 7, 2011 at 10:41 PM
    evansa22
    Aaron
    SD
    04 trd 4x4
    thanks guys.
    Both shocks are gooing to be revalved once i can get ahold of sway a way to get a baseline for shims. Been trying to for about 2 weeks now with no luck. Both shocks are valved to work by themselves so they r way to stiff
  7. Mar 8, 2011 at 7:02 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    i'm going to be getting new spindles and heim steering in a few weeks. i currently have the TC heim steering upgrade that i wont be needing anymore, would you maybe be interested in taking it off my hands for a low price?
  8. Mar 8, 2011 at 2:35 PM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    if he dosnt let me know matt!
  9. Mar 8, 2011 at 2:47 PM
    StatutoryAPE
    StatutoryAPE Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    looks very nice man.
  10. Mar 8, 2011 at 6:43 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    will do!!!
  11. Mar 8, 2011 at 9:28 PM
    StatutoryAPE
    Joey
    Phoenix,AZ
    where does the second shock bolt to the bottom? did you have to add a spot for it?
  12. Mar 8, 2011 at 9:31 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    no, the TC kit comes with dual shock tabs alredy on the LCA
  13. Mar 9, 2011 at 12:03 PM
    evansa22
    Aaron
    SD
    04 trd 4x4
    ya matt is right, tc lowers come with two mounting tabs on the bottom. The second one on mine was used to mount the limit strap, so we cut a spacer to move it away from the shock and so it wouldn't rub through travel. I would b interested in the steering upgrade, let me know what u want for it, should b getting my tax return sooner rather than later
    thanks,
    Aaron
  14. Mar 9, 2011 at 3:05 PM
    StatutoryAPE
    Joey
    Phoenix,AZ
    so the limit strap still uses the same mounting spot, but shares it now with the second shock. thats awesome. doe sthe camburg kit have a second shock mount as well?
  15. Mar 9, 2011 at 4:12 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    yeah, it has 2 tabs
  16. Mar 9, 2011 at 4:12 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    cool man, i'll hit you up once i get them off the truck
  17. Mar 9, 2011 at 11:57 PM
    evansa22
    Aaron
    SD
    04 trd 4x4
    cool Matt, just let me know.
    StatutoryApe- If u want a pic reference of how we mounted strap and secondary shock let me know. I can take one once i get the secondaries back on but for now valving's too stiff to run them both. We changed the bolt out for a longer grade 8 bolt and longer nut to prevent ne bending.
    (I)=I , () r the shock mounting tabs, I's r shock shaft end and strap mount, = is spacer
    something like this
  18. Mar 11, 2011 at 1:39 PM
    StatutoryAPE
    Joey
    Phoenix,AZ
    you dont have to take a pic, its ok. i get it now
  19. Jan 16, 2015 at 12:34 PM
    austin62
    austin62 BushMaster
    austin
    california
    05 sr5 6-speed
    All the things
    Anyone ever made their own gussets ?
  20. Jan 16, 2015 at 12:50 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Just a few :p I did not make my spindle gussets but made just about every other one
