Spindle lift help
Discussion in 'Suspension' started by XIGUNHAWKIX, Apr 25, 2013.
  1. Apr 25, 2013 at 12:56 PM
    XIGUNHAWKIX
    XIGUNHAWKIX [OP] Just a desert dude.
    Luke
    Taos, NM
    SR5 4WD Base Project Truck
    Entune touchscreen display, JBL system, blacked out, Icon 2.5 Remote Resis, TC UCA's, 50" LED LightBar. Pelfreybilt bumper.
    Hey fellas, I know there's a million different threads about this subject and I've done alot of digging but still need some help.
    My truck is a '12 DCSB 4x4
    (Note: I dont need wheel spacers on my KMC Enduros as the backspacing is fine)
    Im planning on ordering parts this week:
    Front:
    Camburg Spindles and UCA's
    Fox 2.5 coilovers
    Rear:
    AP expo rear leafs
    Bilstein 5100's
    Also extended brake lines and 285's.
    Is there anything else i will need to make this happen? I know everyone's got a different setup, but Im trying to avoid blocks and Im looking for a somewhat level lift (a LITTLE bro lean is fine)
    Just wanna make sure I'm not missing anything before I spend my money.
    Thanks in advance guys, your help is greatly appreciated.
  2. Apr 25, 2013 at 12:58 PM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    Spindles - 2wd
  3. Apr 25, 2013 at 12:59 PM
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    ummm, if your truck is 4wd then you cant do a spindle lift....might wanna start your list over :eek:
  4. Apr 25, 2013 at 1:00 PM
    XIGUNHAWKIX
    Luke
    Taos, NM
    Fuhck, didn't know that. What are my options then?
  5. Apr 25, 2013 at 1:11 PM
    YotaMatt
    West Point VA
    you can order everything on your list except the spindles and run the 285s....just crank the coilovers up to about 2.5" of lift and youll be fine
  6. Apr 25, 2013 at 1:16 PM
    XIGUNHAWKIX
    Luke
    Taos, NM
    Cool, thanks for the response man. Will cranking up those coilies give me as much height as the spindle lift or will still be less? I really like the look of the trucks that the spindle lift guys have..
  7. Apr 25, 2013 at 1:31 PM
    YotaMatt
    West Point VA
    The spindles give you 4" of lift....the coilovers are adjustable from 0-3.5" i believe...with 285s around 3" of lift is perfect
