Spindle lift questions?
Discussion in 'Suspension' started by DoubleYotaBoy, Feb 17, 2013.
  1. Feb 17, 2013 at 12:36 PM
    DoubleYotaBoy
    DoubleYotaBoy [OP] Well-Known Member
    Jonathan
    Clinton, NC
    06 tacoma prerunner
    Bull Bar, Chrome grille, JDM Chrome Headlights, 5000k HIDs headlights and fogs, Chrome Door handles, Ready Lift 2.25 inch front spacer, BFGs 265 75 16
    Im new to this page so please take it easy on me. I have an 06 tacoma prerunner and have 2.25 ready lift leveling spacers which I regret every day, and I am heavily considering the Maxtrac 4 inch spindles. I have read alot of posts on here about spindles and different advice on each. I want to run 285 75 16s on factory rims with this lift, will this work without wheel spacers? I dont off road so it is just for looks and road travel. Will I need anything other than the spindles for the lift, such as after market coil springs, there is 70,000 miles on the truck and springs are factory. I also like a little bit of a "lean" on it so I was thinking just a 1 inch lift in the back, but I dont want blocks, any advice? Thanks
  2. Feb 17, 2013 at 12:43 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Well.. I have the 4 inch spindles and they are great. It doesnt affect the ride and makes it better, because you will be getting rid of the spacers up front. Im not sure about the wheels, but the spindles push the wheels out 3/4". You will have bro lean if you dont have anything in the rear. I would recommend an AAL, which was what I had and it had a slight bro lean. The spindles come with everything you need for the install including the extended brake lines. You dont have to worry about the stock shocks, since spindle have nothing to do with shocks. I no longer have the add a leaf and have a 3 inch leaf pack in the rear.
    This is with my add a leaf. (this is the best picture I could find with the lean)
  3. Feb 17, 2013 at 12:52 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    The beauty of spindles is that you won't need anything other than what maxtrac will send you. Aftermarket coils will help with the ride quality but you don't need them.
    I know going bigger than like a 32" on first gens usually requires spacers or aftermarket rims so as to not rub the UCA.
    Rear lift get an AAL they'll give you a little stiffer ride but added load capacity and will extend the life of the leaves a bit longer
  4. Feb 17, 2013 at 12:56 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    As long as you have 4.5 back spacing on the wheels you will be ok to run w/o spacers. Instead of a 1" block I would run the 3 leaf pack by either icon or wheelers.
  5. Feb 17, 2013 at 1:00 PM
    DoubleYotaBoy
    Jonathan
    Clinton, NC
    06 tacoma prerunner
    thanks guys, if it pushes the front tires out 3/4 inch, does that look weird compared to the back tires or do most people put wheel spacers on the rear tires to match?
  6. Feb 17, 2013 at 1:04 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Its slightly noticeable, but I dont really care and I have not put wheel spacer on the rear.
  7. Feb 17, 2013 at 1:05 PM
    BORNWILDGUY
    Rich
    Florida
    I have seen alot of people running the 1.25 or 1.5 spacers on the back to compensate for the front wheels being pushed out. If you get spacers make sure you get the hubcentric ones
  8. Feb 17, 2013 at 1:07 PM
    DoubleYotaBoy
    Jonathan
    Clinton, NC
    06 tacoma prerunner
    Thanks man, truck looks good btw
  9. Feb 17, 2013 at 1:07 PM
    DoubleYotaBoy
    Jonathan
    Clinton, NC
    06 tacoma prerunner
    Preciate it! helps alot
  10. Feb 12, 2014 at 10:17 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    for it to fit without spacers is it 4.5 backspacing and smaller or 4.5 backspacing and bigger?
  11. Feb 13, 2014 at 2:42 AM
    BORNWILDGUY
    Rich
    Florida
    4.5 or less
  12. Feb 13, 2014 at 5:02 AM
    nammer
    Nam
    Bradenton, Florida
    thanks for the quick response,
    damn, so my enkei deep sixes, as big as they are, are gonna need spacers if i go with spindle!!! i think their backspacing is like 5.5 or somethin
  13. Feb 13, 2014 at 6:33 AM
    BORNWILDGUY
    Rich
    Florida
    I believe your wheels are 9.5 wide w a 15mm offset so your backspacing would be 5.84
  14. Feb 13, 2014 at 8:12 AM
    nammer
    Nam
    Bradenton, Florida
    damn, even worse, if i do go with spindle lift, with that backspacing, would 1.25'' even be enough? or would it need to be 1.5''? thanks for your help bornwildguy!
  15. Feb 13, 2014 at 8:16 AM
    BORNWILDGUY
    Rich
    Florida
    1.25 should be fine
  16. Feb 17, 2014 at 9:42 PM
    nammer
    Nam
    Bradenton, Florida
  17. Feb 18, 2014 at 2:45 AM
    BORNWILDGUY
    Rich
    Florida
  18. Feb 18, 2014 at 5:26 AM
    nammer
    Nam
    Bradenton, Florida
    so no need for spacers for me?
    thank ya thank ya thank ya!!!!
    :bananadance::broccoli::dancingbacon:
  19. Feb 18, 2014 at 5:30 AM
    BORNWILDGUY
    Rich
    Florida
    No 20's will fit but you still will need 4.5 to 4.75 backspacing so if using your wheels you have now you will need spacers. Just go with the 1.25 spacer if using your wheels you have now.
  20. Feb 18, 2014 at 5:35 AM
    nammer
    Nam
    Bradenton, Florida
    aww damn, ok, thanks, i really do appreciate the help, so before i attempt the install, tryin to hunt down a set now
