spindle lift
Discussion in 'Suspension' started by kalix, Oct 29, 2012.
  1. Oct 29, 2012 at 8:48 AM
    kalix
    kalix [OP] Member
    Virginia
    2012 DC PreRunner
    Have a question from a nubie!!!! can you add 4" spindles to a leveling kit on a 12 PreRunner?
  2. Oct 29, 2012 at 8:52 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Define "leveling kit."
    If it's a spacer block, no. Just remove the spacer block and run the spindles.
    If it's coilovers, lower the coilovers back down to 0 lift and run the spindless.
    If it's bilsteins, change the ring to the lowest setting (0) and run the spindles.
  3. Oct 29, 2012 at 11:13 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    Why? You are going to have 4"inches from the spindle+the leveling kit. So If you have a 2"leveling kit that will give you 6" lift in the front and your truck will still ride like crap defeating the purpose of spindles. I have my billies set at 1.75 with stock O/R coils and the truck rides nice. A little stiffer than stock but still rides great. Ditch the spacers. You will be happier in the long run. IMHO
  4. Oct 29, 2012 at 11:16 AM
    k9cop
    Farva
    Hogwarts
    maxtrac spindles. Allpro expo pack. Billies all the way around.
  5. Oct 29, 2012 at 11:20 AM
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    2011 Ford Raptor (I'm a traitor)
    Are your billies set at 0? And are you still running stock coils and everything?
    Edit: Nevermind, just saw that you were at 1.75"... So you did 5.75" in the front at 4" in the back?
  6. Oct 29, 2012 at 11:21 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    VVVVVVV
  7. Oct 29, 2012 at 11:21 AM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    who cares. just do it! put'em in! let us know how it turns out :)
  8. Oct 29, 2012 at 11:22 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    Ya... I quoted too soon...
    :facepalm:
  9. Oct 29, 2012 at 1:34 PM
    k9cop
    Farva
    Hogwarts
    here's another pic you can see how level it looks.
  10. Oct 29, 2012 at 1:37 PM
    k9cop
    Farva
    Hogwarts
    It really depends on which spindle you go with as to how much lift you get in the front. With spindles you can keep everything stock in the front.
  11. Oct 29, 2012 at 1:39 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    I was just gonna ask you for a side shot of your truck... I like it!!! I think I might try my billies at .85 and see if I like a little bit of rake... I do enjoy the fact that they're adjustable so I can kind of adjust it until I like it...
  12. Oct 30, 2012 at 5:30 AM
    kalix
    kalix [OP] Member
    Virginia
    2012 DC PreRunner
    ok, so im gathering that the front will retain the stock ride and shocks with spindles?? Also what is the best lift for the rear? Not hauling just to keep a good ride.
  13. Oct 30, 2012 at 5:37 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the "best" would be up to your definition of best.
    If I was to pick the "best" I would do spring under axle flip with a new leaf pack, shock hoops and external resi shocks.
  14. Oct 30, 2012 at 6:33 AM
    kalix
    kalix [OP] Member
    Virginia
    2012 DC PreRunner
    Whats the purpose of the remote res shocks if your not doing any wheeling (cont. cycling)? Would blocks and longer shocks retain the stock ride?
  15. Oct 30, 2012 at 6:38 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    you said the "best" but did not define what you meant so I stated what I thought was "best".
    if you are just driving around town then get a 2" aal and probably a 1" block, longer U bolts, extended 5100's, and extended brake lines.
  16. Oct 30, 2012 at 11:04 AM
    k9cop
    Farva
    Hogwarts
    More or less yes should be close to stock with the spindles and all stock equipment. I like the all pro standard or expo pack for the back. I have the expo's and don't haul anything. I like my truck to ride as such and when I do put something in the back I don't have to worry about the back sagging. A lot of folks on here like the dakar's. They are kick ass too from what I've read. It all (suspension in general) depends on how much you want to spend. In the end you get what you pay for. Just don't be an idiot like me and do it twice.
  17. Oct 31, 2012 at 4:18 AM
    kalix
    kalix [OP] Member
    Virginia
    2012 DC PreRunner
    Thanks for the reply!!! Should I have a problem clearing 33x12.5/18 with 4" lift?
  18. Oct 31, 2012 at 7:59 AM
    k9cop
    Farva
    Hogwarts
    I am running 295/70/17's. I can rub occasionally on trails. If you don't hit it hard get whatever. If an occasional rub or grind don't bother ya on the trails stay somewhat conservative. If you are airing it out may wanna stay conservative or consider LT. I am also running Nitto terra grapplers. It's an A/T tire so not super aggressive on tread. So to answer your question you may have to do some chopping even a cab mount chop. but you could probably squeeze them in depending on the tire.
  19. Oct 31, 2012 at 8:19 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    depends on the back spacing. you will probably have to trim some plastic and maybe a cab mount chop. a lot depends on the wheels you run. if you offroad then you will need to trim more.
