Spitting and Sputtering and CEL
Discussion in '1st Gen. Tacomas (1995-2004)' started by kevo1586, Aug 29, 2008.
  1. Aug 29, 2008 at 10:07 AM
    kevo1586
    kevo1586 [OP] New Member
    My tacoma was off the road for about three months and I went to use it the other day and when I started to drive it, it was spitting and sputtering and it had thrown a CEL for an O2 sensor.
    Things I have done to try and solve the problem:
    1. I put methyl hydrate in the gas because I thought there may have been water in the gas but that did not solve the problem
    2. I pulled the O2 sensor which also did not solve the problem
    3. Gas filter was pretty resricted so I replaced that
    Also the engine only really spits and sputters when it is under load e.g. When under light throttle under 2000 rpm it does not spit or sputter, but once over 2000 rpm it does. It also S&S under heavy throttle at any rpm. When revved in neutral it revs fine until about 2800-3000 rpm and then it S&S.
    Any ideas would be great or if anyone has encountered a similar problem and what they did to fix it would be greatly appreciated. Thx
  2. Aug 29, 2008 at 10:11 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try cleaning the maf sensor and throttle body. also....maybe give the spark plugs adn wires a check......sounds like you may have a cracked plug.
  3. Aug 29, 2008 at 11:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What he said ^^^^^^^^^^^^^^
  4. Aug 29, 2008 at 1:01 PM
    kevo1586
    would the cracked wires or MAF sensor explain the truck only S&S when it is under load?
  5. Aug 29, 2008 at 1:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    very, very possible, since its trying to work properly and cant do so......if that turns out to be it.
  6. Aug 29, 2008 at 1:27 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    It might be the MAF sensor, I changed mine two times on my 99 Tacoma over 222K miles. It would be hard starting then sputer run at high RPMs or low .
  7. Aug 29, 2008 at 5:38 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Fresh fuel might help. Just a thought
