Sport won't climb...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by David McGinnis, May 23, 2022.
  1. May 25, 2022 at 7:01 AM
    #61
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If you were in 4L climbing a hill and killed the engine I don’t think TRAC/VSC was your issue. VSC is not enabled in 4L. See the 1st post in the thread about traction control modes.
    What I think happened is that you started to loose traction, TRAC engaged to prevent uneven wheel spin, you lost speed, the truck abruptly found more traction, the rpm dipped too low and the engine died.
    If this is the case, you could have prevented it with better throttle and clutch control.
    I recommend reading the thread on traction control modes and then going out and practicing with them. It will become 2nd nature after a while. I'll relink it here for convenience.
    https://www.tacomaworld.com/threads/3rd-gen-traction-control-modes-explained.530695/
    My 2016 Tacoma was my first experience with traction control. Shortly after buying it, I was playing around in some sand. I was intending on drifting through a corner. I slid the truck into the corner and applied some throttle, but the truck refused to accelerate and instead came to a complete stop leaving me stuck. I had to put it in 4HI to get out. Later that day I read about traction control in the manual. Live and learn!
    Chew and Canadian Caber like this.
  2. May 25, 2022 at 7:40 AM
    #62
    Tacomatrd420
    Tacomatrd420 Well-Known Member
    2018 tacoma trd sport double cab 6 spd
    Ome heavy duty rear leaf springs. El112r. Canopy is semi camperized, pull out tool storage , solar power with rear agm deep cycle battery. Light bars. Front rear sides. Roof basket.
    Doing this makes a noticeable difference. I do it alot. Definitely lets the tires go alot more
  3. May 25, 2022 at 7:12 PM
    #63
    David McGinnis
    David McGinnis [OP] Well-Known Member
    David
    Sierra Vista, AZ
    2021 4X4 Sport AC 3.5L MT - OME lift with Dakar leafs. 10x33 Coopers. ARB Bumper. KDMax Tune. 2017 SE AC 2.7L 2WD AT - OME lift with Dakar leafs, BA bumper, tooter manifold spacer, header, OVTuned. LED lights. Does not run like your average 2.7; this truck pulled a broken down HMMWV out of a wash. 2008 PreRunner 4.0L - 3" spring lift with Bilstein 5100s, ARB bumper, rear sway arm. Old Reliable, been around, beat up, and still runs like a beast.
    I don't disagree with you.
    As for TRAC and VSC, I understand they are both systems that use microprocessor control of the breaks to affect traction in certain circumstances. VSC is for driving on roads, TRAC is for off road, TRAC is on in 4L, VSC is off in 4L, or both VSC and TRAC are off in 4L depending on what option package you have (not sport), and in the end it all needs to be turned off to drive the tuck in the conditions I encountered.
    I'm fairly confident that, given that it is now clear to me that some of the VSC/TRAK "stuff" (I am kind of purposefully lumping this together as one thing) remains turned on while in 4L, until you turn it off with a long press, my throttle/clutch control would have been just fine. I now understand I need to long press a button each time I encounter this kind of situation.
    Thank you TacomaWorld.
    tonered, Junkhead and hiPSI like this.
  4. May 25, 2022 at 7:16 PM
    #64
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You.are.welcome. signed, Tacoma world.
  5. May 25, 2022 at 7:20 PM
    #65
    bonifacio_629
    bonifacio_629 Well-Known Member
    Walther
    Virginia
    2018 Tacoma TRD Sport, 6MT 4x4 DCSB, Inferno
    Predator steps, TRD cat-back, lots of orange stickers.
    HMMMM wait a sec. TRAC is for traction control on the road as well. All Toyota's cars come with VSC and Traction control. A-TRAC, aka Active Traction Control, is for off-road. You don't get A-TRAC in the Sport, unfortunately.
    Canadian Caber and gudujarlson like this.
  6. May 25, 2022 at 7:21 PM
    #66
    gudujarlson
    Minnesota
    TRAC is definitely not intended for off-road. That’s what ATRAC/MTS are for. But TRAC is slightly better than open diffs as long as VSC is disabled. It works okay for taking off from snowy intersections.
    Semi-related, I did some experiments with AutoLSD vs TRAC in 2wd. Details are posted in the traction control thread, but the summary is that TRAC/VSC will not get your 2wd truck unstuck, but AutoLSD might.
    bonifacio_629 likes this.
  7. May 25, 2022 at 7:22 PM
    #67
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    it sounds like that you were trying to get closure on this with that thank you. You most likely will not.
  8. May 25, 2022 at 7:23 PM
    #68
    bonifacio_629
    Walther
    Virginia
    I got SO hyped last winter, I found a super steep driveway at a really messed up angle and got to use the Auto LSD for the first time. The first time I pulled up it was an ugly one-tire fire, the second time I tried it with Auto LSD and it climbed up smooth as can be.
  9. May 25, 2022 at 7:30 PM
    #69
    David McGinnis
    David
    Sierra Vista, AZ
    Okay okay. How about this: Magic computer shit that does things with the brakes - whatever that is.
    tonered and LooneytuneSR5 like this.
  10. May 25, 2022 at 7:36 PM
    #70
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Ummm... traction control?
    shakerhood and Rock Lobster like this.
  11. May 25, 2022 at 7:45 PM
    #71
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    random persons driveway ??? get off my lawn!
  12. May 25, 2022 at 8:04 PM
    #72
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I’m gonna fuken cry
    it’s so beautiful…
    Canadian Caber and hiPSI[QUOTED] like this.
