Spray In Bed Liner in Composite bed 2007??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by v1perone, Apr 2, 2008.
  1. Apr 2, 2008 at 10:48 AM
    v1perone
    v1perone [OP] Member
    PreRunner
    Its a work in progress
    Can you use a spray in bed liner(Rhino, LineX, [FONT='Times New Roman','serif']Inyati )[/FONT] in the 2007 composite beds? If so which brand?
    Any help or idea's would be great.
  2. Apr 2, 2008 at 11:10 AM
    flavalk
    flavalk 2-Broke 2-Care
    Orlando, Florida via Huntsville, Alabama
    '07 PreRunner SR5 Double Cab 2WD - Short Bed - Automatic- Silver Mica
    Not much. Toyota bed mat, Toyota step bars, tinted windows, Toyota seat covers, Toyota all-weather mats, quart of Wild Turkey in the glove box, KelTec PT3AT in the center console, backseat full of old speeding tickets
    Why would you want to do that? The composite bed is tough as hell. If you need to prevent stuff from sliding around, get a bed mat. Toyota has a good one for about $80 and others are available cheaper than that.
  3. Apr 2, 2008 at 11:18 AM
    v1perone
    PreRunner
    I am slowly turning it into a show truck and need to have the bed color match the truck color. Can the be liner that is in it be removed? I've gotten so many different answers, I don't know where to turn.
    Thanks for your help and suggestions
  4. Apr 2, 2008 at 11:21 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    The tacoma bed is NOT a liner.
  5. Apr 2, 2008 at 11:27 AM
    flavalk
    If you remove the liner, yer gonna be missing a bed :D The liner is the bed.
  6. Apr 2, 2008 at 11:33 AM
    v1perone
    PreRunner
    So the liner can't be removed right???
  7. Apr 2, 2008 at 11:37 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's not a liner. The composite material you see is actually the bed itself. Crawl underneath you truck and you'll see what we mean.
    You can Rhino-line just about anything. As for the do-it-yourself stuff, I've had a lot of success with Durabak. Easy to apply and comes in many UV-resistant colors.
    If you're just looking to keep things from sliding around, buy the Toyota bed mat.
  8. Apr 2, 2008 at 11:38 AM
    v1perone
    PreRunner
    I know I'm a newbie and this may be a stupid question but help if you can
  9. Apr 2, 2008 at 11:52 AM
    flavalk
    There are no stupid questions (except those regarding oil :D) so, ask away! Somebody here will help you out.
  10. Apr 2, 2008 at 11:54 AM
    v1perone
    PreRunner
    Thanks for the input. I'm still lost but I'll figure it out.
    Thanks
  11. Apr 2, 2008 at 11:59 AM
    mjp2
    NJ
    No worries. Like I said, crawl under your truck and you'll see what we're talking about.
    Since most people install some sort of bedliner in pickups to keep the paint from wearing away and the metal from rusting, Toyota did away with the metal all together. What you see is what you get -- you have a plastic truck bed. (not really plastic, but you get the idea) The fender skins are the only metal back there.
    I guess the real question is...what's your question? Will a spray-in/roll-on bedliner stick? Probably, if you scuff up the bed with 40-grit sandpaper first. Most of those products are meant to protect the metal and keep it from rusting, so realize that you'll be rust-proofing something that already can't rust.
    If you're doing it for looks, it's your call. If you're doing it to protect the bed, it's a lot of effort for a net-zero gain. If you're tired of stuff sliding around in the bed, the Toyota bed mat is the fastest, cheapest, and easiest route to take.
  12. Apr 2, 2008 at 12:00 PM
    mjp2
    NJ
    I'm thinking of switching to synthetic. Is this a good idea? :rolleyes:
  13. Apr 2, 2008 at 12:05 PM
    v1perone
    PreRunner
    Thanks, I appreciate your patience. I'm doing it for looks
  14. Apr 2, 2008 at 12:13 PM
    mjp2
    NJ
    Then by all means, have at it and post pictures of the finished product! :thumbsup:
    I noticed you don't have any pictures posted in your gallery. Get some up there so we can follow the progress from stock to show-ready!
    And keep your sarcasm detector turned on when cruising these boards. We're really not mean or impatient -- you may just catch us in a snarky mood from time to time. ;)
  15. Apr 2, 2008 at 12:20 PM
    v1perone
    PreRunner
    No worries... I will get some pics up and I have a thick skin.
    This voyage into what seemed a simple project has consumed me... yikes!!
  16. Apr 2, 2008 at 12:25 PM
    mjp2
    NJ
    You're not alone. Check my pics. :p
    Enjoy the descent into madness!
  17. Apr 2, 2008 at 12:53 PM
    sawdust
    sawdust Unapologetic Texan
    Frisco, TX
    07 TRD Offroad Radiant Red V6 Auto DC
    Homelink mirror, tailgate lock, 2ndary air filter removal, Access LE tonneau, Bugflector II, hitch-based bed extender, vent visors, suspension TSB, stall mat
    I think you got the answer. That's not a bed LINER. That's the BED. It's plastic all the way to the frame. Crawl under your truck to verify.
    That being said, sure you could put a spray-on liner on it. But aesthetics is the only reason. You might also want to look into a good paint that works on plastics if it's just looks your after.
  18. Apr 2, 2008 at 1:05 PM
    v1perone
    PreRunner
    Thanks Mjp2 and Sawdust.
    I will look into "other" suggested avenue's.
    I really appreciate this forum, it has been a godsend into helping me modify my truck.
    thanks much
  19. Apr 2, 2008 at 1:19 PM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    Yeah I agree if it's just looks your after, just get a good plastic paint. Make sure you prep the plastic good though.
  20. Apr 2, 2008 at 3:26 PM
    CrashTest
    CrashTest Member
    2008 Access Cab V6 MT TRD Offroad
    1. Prep Plastic
    2. Apply desired paint color
    3. ???
    4. Profit
