Spring info.....
Discussion in 'Technical Chat' started by chris4x4, Feb 3, 2011.
  1. Feb 9, 2011 at 7:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    http://www.cruiseroutfitters.com/tech_OME_coils.html
    I found this. It's very helpful in explaining the differences between OME coils. It's all metric though, the USCS chart is lacking a lot of info, but I'm sure all you smart fellas will be able to figure it out.
  2. Feb 9, 2011 at 7:29 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, To convert N/mm to Lbs/in. You multiply the N/mm rate by 5.7099. Thats not "precise", but it gives you a close enough idea of the spring rates.
  3. Feb 9, 2011 at 4:58 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    i'm curious how much of a difference there is between the 883s and the eibachs. size wise they are almost the same but what strength and ride quality?
  4. Feb 9, 2011 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Eibachs have spring rates from 600# and up.
  5. Feb 9, 2011 at 5:19 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Chris4x4 what additonal lift will i get from the OME 884-885 with 5100 set at .085?
    or should i put the 5100 at 0 as the .085 setting and OME would bring me over 2.5 which isnt good......nevermind i figured it out
  6. Feb 9, 2011 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Welp....The 885's give 3" after settling (approx), so you'll get almost 4", or right at 4" before they settle in. Not a good idea.
  7. Feb 9, 2011 at 5:27 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    It doesnt matter what works with what, the most important issue is liability.
  8. Feb 11, 2011 at 3:54 PM
    Tunafish778
    Tunafish778 Well-Known Member
    Spring (Houston)TX
    Tacoma
    Okay, i'm confused. I just bought a set of 5100's and i'm worried about coils and lift. I would like to get a 2.5 in lift out of them; do I stick with the coils I have on there now? Do I need to buy something else before they're installed? Can I get a full lift out of them and will the back shocks level out the rear of the truck? I've read every thread I can find and still can't find an answer.
  9. Feb 11, 2011 at 4:06 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You can use the 5100's with the stock coils if you like.. The rear shocks do not provide any lift. You would need an add-a-leaf to lift the rear.
  10. Feb 11, 2011 at 4:20 PM
    Tunafish778
    Spring (Houston)TX
    Tacoma
    Ya, I was just reading another post and saw that the AAL's or blocks would be the way to go.... Now the question is; AAL's or blocks? Is there a difference between them as far as reliability, strength or installation cost?
    thanks.
  11. Feb 11, 2011 at 5:49 PM
    TexasTacoma37
    Cost is roughly the same. AAL's are all around a better choice though.
  12. Feb 11, 2011 at 10:11 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Edit: Crap didn't realize I was posting in Toyotec's forum. Sorry
  13. Feb 11, 2011 at 10:28 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    in between the 5100 and the ome shocks which ones have a longer travel length? and what would make the ome shocks more qualified to be ran with the ome coils?
  14. Feb 11, 2011 at 10:33 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    FWIW i'm running ome 881 with 5100 set to 0. No problems yet.
  15. Feb 12, 2011 at 6:30 AM
    #35
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It's the R&D concept....The OME springs were made to go with the OME shocks- Much like Toytec said the Eibach springs are made for 5100's. The company made the fit together and where they are a system with very specific interactions....Probably makes sense to keep them paired.
  16. Feb 12, 2011 at 6:32 AM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dimensionally, The only differences is the length of the springs. The ends of each spring are the same, as are the tops of each spring. The OME shocks fit the 5100's no differently than the Toytecs.
  17. Feb 12, 2011 at 6:36 AM
    #37
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Really the "fit" is more the OME shock to the spring. The valving and the shock style for the spring...Not that they can't work together.
    Plus I'm a huge fan of keeping the parts together on a personal level...
  18. Feb 12, 2011 at 6:39 AM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, I understand what your sayin, but being as the spring rates arent that far off from each other, and after driving in a few trucks with the mixed combo, They seem to drive nice. Now....I cant give input on the new OME 90000 shocks, but if they made them more firm that the N142's, then they should ride dam near identical to the same spring with the 5100 shock.
  19. Mar 17, 2011 at 9:23 PM
    #39
    socal4x
    socal4x Well-Known Member
    CA
    '16 MGM DCSB OR 4x4 6MT
    Thanks for this. I have been looking around the net for it.:)
  20. Mar 21, 2011 at 1:40 PM
    #40
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    Been running the 5100's at 0 with the OME 882's for over a year and i've had no problems, my truck actually handles and rides way better then it did stock.
