Spring rate question?
Discussion in 'Long Travel Suspension' started by jalsum, Sep 5, 2011.
  1. Sep 5, 2011 at 5:53 PM
    jalsum
    jalsum [OP] Member
    reno nv
    97 tacoma S/C LT
    I'm planning on making my Tacoma LT. I was looking into getting the total chaos package. I'm planning on keeping it 4X4. Also I will be running a Fox's 2.5 coil over with fox's 2.5 double bypass. I was wondering what spring rate people are running, or what whats the proper way to see which i need? Thanks!
  2. Sep 5, 2011 at 7:15 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    600# . if you were 2wd id say 550#.
    550# would be ideal if your running a bypass but it may or may not give you the ride height you want without cranking it up too much. id just play it safe and go 600#
  3. Sep 11, 2011 at 9:22 AM
    jmoss13
    jmoss13 Well-Known Member
    Jeremy
    SOCAL
    03 Tacoma 4X4 LT
    TC LT w/King CO and Triple Bypass, Deaver 8 leaf
    im using 600 with my kings and it works fine for me.
