Spring TSB on a certified used truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Metallikatz3, Nov 26, 2008.
  1. Nov 26, 2008 at 9:46 AM
    Metallikatz3
    Metallikatz3 [OP] Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Well i got my truck a few months ago and I think i need to have the spring TSB done, only problem is that its used with about 62k miles now. I bought the certified platnium warrenty through Toyota financial. Now does anyone know if this extended warrenty would cover me for the TSB?
  2. Nov 26, 2008 at 9:57 AM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    it will not cover the TSB.
    All TSB's are only covered under factory warranty 3 yr 36K
    They might due a "Good Faith" if you get your dealer on your side and call up toyota directly.
    Explain that you are part of a forum and didn't know about the issue until you bought the truck.
    Maybe someone on here can verify it they have had it done after the 3 yr 36K?
    Get all the ammo you can get before you call toyota. (I had a heater core replaced in good faith on a VW passat)
    It was not a recall or a TSB.
  3. Nov 26, 2008 at 1:19 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Shoulda asked for it when ya bought the truck.
    Go fish.
