Springs with stock shocks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05RedTaco, Nov 7, 2011.
  1. Nov 7, 2011 at 8:40 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I want to level out my truck and was wondering if I can use OME 884 springs with stock TRD OFF Road shocks... OME 884's or 885's should give me about 1" of lift which "should" level the truck out... Also which springs would be the best fit for leveling the truck out? 884, 885 or 886?
    Also the other question is, will new springs get rid of the infamous "Taco lean"?
  2. Nov 7, 2011 at 10:17 AM
    05RedTaco
    Tony
    Scottsdale
    Anyone?
  3. Nov 7, 2011 at 10:18 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    you're going to get at least 2 inches of lift with those springs. and I don't know exactly, but I wouldn't trust the stock shocks to handle those springs well.
    and as for the taco lean, a 1/4 top plate spacer on the driver side will get rid of it (so I've been told)
  4. Nov 7, 2011 at 10:19 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    also I put on my lift over two days, I did the front first with 884 springs and no top plate spacer and I was nose high.
  5. Nov 7, 2011 at 10:22 AM
    05RedTaco
    Tony
    Scottsdale
    Toytec sells 883's which are stated to "level out the truck" I wonder if the springs alone would get rid of the lean :confused:
    Would my stock shocks handle these springs?
  6. Nov 7, 2011 at 10:24 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    No, springs alone wont get rid of the lean. 1/4" top plate spacer or OME trim packer.
  7. Nov 7, 2011 at 10:42 AM
    05RedTaco
    Tony
    Scottsdale
    UGH!
    Front Bilstein 5100's are the same price as pair of ome 883 springs...
    The question is whats better, run 883 with stock shocks or run 5100's with stock springs :confused:
  8. Nov 7, 2011 at 10:51 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I have a trim packer and still have taco lean.
  9. Nov 7, 2011 at 11:37 AM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    Life must suck.
