SQ amp less than 18" putting out 1k watts @ 4ohms?
Discussion in 'Audio & Video' started by Rhonx2, Nov 6, 2013.
  1. Nov 6, 2013 at 11:05 PM
    Rhonx2
    Rhonx2 [OP] Active Member
    My amp rack at its widest is approximately 18 inches, so I'm trying to find an amp that supplies at least 1000watts rms @ 4ohms that is less than 18 inches. I don't want to put an amp under my seat nor am I trying to power my subs at 1 ohm. I'm trying to power two JL Audio 10TW3-D4's with clean power with a good amount of head room. I've been through tons of searches and nothing comes up within my parameters. The JL Audio 1000/1v2 fits so PERFECTLY into my search with its regulated power from 11-15v, Lots of head room, but at its widest its already 20 inches. I've looked at the PPI Phantom 900.4, perfect size but at 4ohms bridged its doing 450rms at 14.4v and considering my truck doesn't run at 14.4v its probably not doing 450rms. more like 350-400 which isn't a lot of head room i'm looking for. Now, I have my eye on the JL Audio 1200/1 which fits all my parameters, its just that I feel that there is way too much head room and those extra rms watts would be wasted money. Now thats like the only amp I've come to find thats less than 18" putting out that kind of power and was wondering if anyone had other options.
  2. Nov 6, 2013 at 11:26 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
  3. Nov 6, 2013 at 11:26 PM
    blake5995
    Blake
    Truckee, CA
    best subs and amps on the market hands down
  4. Nov 6, 2013 at 11:46 PM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    All our trucks run at 14.4v when the engine is running
  5. Nov 6, 2013 at 11:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Voltage in cars changes a lot with loads too. Usually 14.4 but with subs can dip a lot. Mine made mine to as low as 10v till I upgraded.
    My question for you is
    Why the hell are you trying to power subs with a 4 channel amp?
    You'd be MUCH better off getting a mono D amp and wiring the sub right for 1 ohm.
  6. Nov 6, 2013 at 11:50 PM
    Rhonx2
    I wonder if you even read the post.
  7. Nov 6, 2013 at 11:55 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Why would he not have read the post…? He said its 16.5" which is what you're looking for, and its a high quality amp.
    x2 to what blackdawg said. And there are plenty of smaller amps out there, you just have to look. My kicker dx1000.1 is the size of an iPad and can put out 1142w rms.
  8. Nov 6, 2013 at 11:56 PM
    Rhonx2
    I asked myself that too, I was kind of desperate. Still, I'd prefer running the subs at 4ohms with a mono D amp.
  9. Nov 6, 2013 at 11:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hell my SSL mono amp is 2100w rms and pretty sure it's less then 18"
  10. Nov 6, 2013 at 11:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why 4 ohms?
  11. Nov 7, 2013 at 12:03 AM
    Rhonx2
    better on my electrical, higher efficiency, longer amp life, less heat.
    dc audio 1.2k @ 4 ohms 350rms x1
    kicker dx1000.1 @ 4ohms 550rms x1
  12. Nov 7, 2013 at 12:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well hate to break it to you..but your subs are dual voice coil..you can't wire them to 4 ohms anyways.
    Not as efficient yes but more power. Plus new amps handle the low impedance's very well.
    Here is something to explain the wiring for you.
    http://knowledge.sonicelectronix.com/tools/subwoofer-wiring/
  13. Nov 7, 2013 at 12:15 AM
    blake5995
    Blake
    Truckee, CA
    dc 1.2 will put more watts to your system i can gurantee that. that kicker on a amp dyno wont touch 550. And yes i read your post
    and higher efficiency? really so more resistance is more effecient? why are all cars aerodynamic then? dc amp will run for ever. less resistance means less heat....
  14. Nov 7, 2013 at 12:16 AM
    Rhonx2
    According to crutchfield I can either wire them at 4ohm or 1 ohm.
  15. Nov 7, 2013 at 12:17 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    On a mono amp yea..not a 4 channel tho.
  16. Nov 7, 2013 at 12:17 AM
    blake5995
    Blake
    Truckee, CA
    4 ohm is a waste. use the less resistance and more watts of 1 ohm
  17. Nov 7, 2013 at 12:19 AM
    blake5995
    Blake
    Truckee, CA
    i think he has already made up his mind and doesnt want to listen....
  18. Nov 7, 2013 at 12:20 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really a waste.
    Not everyone wants to rattle the mirrors off the car next to them. Having a well balanced and great sounding system doesn't take 8000w of bass.
  19. Nov 7, 2013 at 12:22 AM
    blake5995
    Blake
    Truckee, CA
    so why does 1 ohm mean 8000w window rattling?
    at 1 ohm the amp is much more efficient.
  20. Nov 7, 2013 at 12:25 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No it's not actually.
    This is always a hard concept for people to understand.
    Yes more power is outputed but the amp is having to work 2-4x harder to make that happen. It's efficiency goes out the window. More heat is generated and strain on the amp.
