Sqeaky belt or something else?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CBDaddy, Jan 20, 2008.
  1. Jan 20, 2008 at 5:03 PM
    CBDaddy
    CBDaddy [OP] New Member
    04 Tacoma Xtra cab 4WD TRD 6cyl
    Since the arrival of winter, I notice a squeaking noise coming from under the hood when I first start my truck until it warms up. It sounds like a squeak or whistle, I suppose what a slipping belt would sound like. The noise is faint, and I can really only hear it when I throw in the clutch and let off the gas as the RPM's fall from 2200-1500 RPM's. Like I said, the noise goes away once the engine is warm.
    I just inspected my belts, and they look okay, but I'm not sure how tight they should be. I can twist over each of the 3 belts 180 degrees. Is that normal? Would a squeaking sound from a loose belt go away when the engine warms up?
    Has anyone else had this problem? Does it sound like a loose belt or something else? Sorry I spelled squeaky wrong in the post subject!
  2. Jan 20, 2008 at 5:11 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    It's a good place to start, seeing that your truck is an 04, replace the belts, should not have a lot of play, find the middle of the longest stretch between pulleys, pull with fingers, no more than an inch.
  3. Jan 20, 2008 at 5:16 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    sounds like a belt to me but i have herd of pully bearing going bad
  4. Jan 20, 2008 at 5:30 PM
    concrete jedi
    Rochester N.Y
    Yeah, I had a tensioner go south on me on a V-8 with about 200,000 miles on it, but it was making a hell of a racket that never went away until replaced.
  5. Nov 24, 2008 at 4:04 PM
    eyball
    eyball Well-Known Member
    Dudley, MA
    20 Double cab TRD Sport Voodoo Blue
    Hey CBDaddy,
    Did you ever get this fixed? I have/had the same type noise as you describe. I changed my belt at the end of last winter and it went away. Now that the cold weather is back so is the squeak. I am guess an idler pully..? How hard are these to change out?
    Thanks
  6. Nov 24, 2008 at 5:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They are not that hard at all, but you need to remove the radiator shroud to clear room to work. Its easy as the shroud is 2 peices. When I did mine, I removed the radiator as well. :)
  7. Nov 24, 2008 at 5:41 PM
    eyball
    Dudley, MA
    How did you know which one to replace or did you replace all 3? Also couldnt it be the tensioner making the noise? I just sprayed mine with silicone lubricant and the noise stopped.
    Thanks for the info!:)
  8. Nov 24, 2008 at 6:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I replaced my tensioner.
  9. Nov 25, 2008 at 7:21 PM
    eyball
    Dudley, MA
    How many miles did your truck have when you had to change it?
    Do you need any special tools to do the job?
    Thanks!
  10. Nov 26, 2008 at 3:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think mine was bad right off the bat. Started makeing the sqeak at about 5,000 miles. Since I was planning a supercharger for it, I just put it off untill I put the blower on. No special tools were needed.
