Squeaking noise from rear suspension
Discussion in 'Suspension' started by jerysan, May 14, 2012.
  1. May 14, 2012 at 12:03 PM
    jerysan
    jerysan [OP] Well-Known Member
    San Diego
    09 PreRunner TRD Off Road SB
    Flowmaster 40 Delta Flow, K&N Air filter, TSB Rear AAL with 1" Block & 5100's, OME 885x with OME Nitrocharged and Toytec Top spacers, Built Right UCA's , Satoshi Grille, HID's, Bull Bar,
    Have a 09 DCSB Off Road Prerunner with the rear TSB leaf spring recall done. I have noticed a lot of noise coming from the rear suspension. I pressured washed it and sprayed some dry silicone in between the leafs but the noise sounds like it comes from the shocks or bed. It's more noticeable going over bumps alt low speed, and sounds like an old truck. Any input would help..
  2. May 16, 2012 at 10:32 PM
    DevL
    DevL Well-Known Member
    For me with stock springs, TSB springs, and TSB plus 3 leaf... the squeaking was always on the brackets holding the springs and heavy application of spray white lithium grease would give me several squeek free months.
  3. May 16, 2012 at 10:34 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
  4. May 17, 2012 at 1:44 PM
    jerysan
    San Diego
    I can assure you its not the leafs. I crawled underneath and had someone push down on the bumper. Sounds like its coming from the shocks. Will make sure this weekend. I will still spray them just to be sure.
  5. May 17, 2012 at 2:05 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Its a truck if you drove my truck youd go crazy because I noises coming out of every spot
  6. May 17, 2012 at 2:06 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    i have to spray the shackle pivot points as well. they like to squeek
  7. May 17, 2012 at 2:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Do that again , but this time rest your hand on the top of the leaf pack , if it's the leafs binding you can kinda feel it when the squeak happens .
  8. May 17, 2012 at 4:45 PM
    jerysan
    San Diego
    Thanks for the tip, will do this weekend and spray the shackles with white lithium.
  9. May 17, 2012 at 4:48 PM
    blitton08
    blitton08 Well-Known Member
    Brandon
    Georgia
    06 XSP White 4D 2WD
    Maxtrac Spindles, Bilstein 5100s set 0 in front with Eibach Springs, 2.5" block in rear with OME Dakar Leaf Springs
    This happened to me ... i just WD40 everything and then jumped up and down in the bed until it stopped squeaking. I looked like an idiot but it no longer squeaks.
  10. May 31, 2012 at 12:31 PM
    jerysan
    San Diego
    So, I sprayed all the leafs pretty heavily with Dupont Dry Teflon, the same as I use on my uniballs and all the squeaks went away. Now I have a new sound coming that I cant figure out. I only hear it when the truck rocks going over bumps at an angle. Its not a creak or squeak, sounds more like a thump. I also re-tightened my bed bolts which they were loose, cleared my bed and took off my hitch receiver ball to try to isolate the noise. Any ideas/input will help.
  11. Jun 1, 2012 at 1:33 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    I have become an expert at ignoring the noises my Coma makes. Pretty much all the noises are from the rear. I did make an attempt once. I think it mostly went away for a day or two then came back like they always do. Life is too short to chase noises in a 4x4 truck.
  12. Jun 7, 2012 at 3:02 PM
    jerysan
    San Diego
    Did further diagnostic and found my lower ball joints were torn at the boot. When I drive at low speeds through rough terrain, I hear like a clunk noise. Need to verify to make sure. Sounds like something might be loose on the front suspension, either the A-arm or something but I can't pinpoint it. Right now, I'm trying to find aftermarket ball joints just in case.
  13. Jun 11, 2012 at 2:33 PM
    jerysan
    San Diego
    Bump for edit
