Squeaky Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hakabo, Sep 9, 2012.
  1. Sep 9, 2012 at 6:44 PM
    hakabo
    hakabo [OP] Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    I just noticed this the other day, but when i get in and out of my truck there is a squeak in the rear of the truck around the bed. (im only 150lbs) i got out, and just pushing sideways on the bed will make it squeak, and i can get a LOT of movement jumping/ bouncing on the back bumper. i bought the truck used and dont think the tsb was done.
    any ideas as to what this could be/ how to fix?
  2. Sep 9, 2012 at 6:59 PM
    hakabo
    Jacob
    Concord, NC
    08 urban runner 4x4
    should i be concerned about the leaf pack failing? i rarely haul anything, and haven't yet since i got the truck, but id hate to eff something up...
  3. Sep 9, 2012 at 8:27 PM
    seric007
    seric007 Well-Known Member
    my question is what are you doing to make it squeak... hmmmmmmmmmm???
    :wink:
  4. Sep 9, 2012 at 8:31 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    Its the leafs...........Just use whatever tech you want to lube the leafs and bushings on shackles. I've used WD40 and Dupont Teflon spray both work for weeks if not months then you just do it again. Takes 5 min every 3 weeks at most.
  5. Sep 9, 2012 at 9:34 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    It's the leaf pack, if your truck is still under warranty I'd advise getting the TSB done, the stock leafs can't even hold 400lbs without sagging to the bump stops. This eliminates the squeak entirely and you can actually haul a load comfortably. Plus it kicks the back end of your truck up a few inches and makes it look cooler, at least I think it does.
    FrechTaco likes this.
  6. Sep 9, 2012 at 9:36 PM
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    On mine when it was same situation, it was the gas tank skid(plastic) that got caught on one of the bolts on the leaf spring.
  7. Sep 9, 2012 at 9:57 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Check the bed bolts sometime they come loose happened to me and I tighten them up and there good now
  8. Sep 10, 2012 at 8:28 PM
    hakabo
    Jacob
    Concord, NC
    08 urban runner 4x4
    def not under warranty. Thanks for the help...
  9. Sep 11, 2012 at 3:19 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    For the record: My truck came from the factory with the "upgraded" 4 leaf pack, and I also get the squeaks. It's case of the bushing in between the leafs not being adequate. My started squeaking at 16,000 km, had the dealer check it out and lube it. And it did it again at 30,000. So they fixed it under warranty and put the new upgraded bushings in.
    If you're out of warranty, I suggest checking out this sticky.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/98055-diy-squeaky-leaf-fix.html
  10. Sep 11, 2012 at 4:19 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    this...
    how did we go from squeaky bed to leaf springs?
    Everyone needs to check their bed bolts and cab bolts. The cab bolts come loose especially if you wheel allot and so can the bed. Heck I think it even tells you to check the torque in the service manual. Luckily mine are seized so that's not an issue.
