squeaky dakars!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ross123, Mar 22, 2012.
  1. Mar 22, 2012 at 10:55 AM
    ross123
    ross123 [OP] Well-Known Member
    fort bragg
    ive had my dakars on for about 1500 miles and about 500 miles into having the leaf pack they started to squeak ALOT. i sprayed the bushings with grease but that only worked for about a day. they sound terrible. any idea what i can do to fix it?
  2. Mar 22, 2012 at 11:00 AM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    My stock leafs do the same thing, buy a can graphite lube and spray them down. After you clean it of course. The graphite lube works really will last about 60 days or more depending on how much junk gets up in there. Its the best fix I found so far.
  3. Mar 22, 2012 at 11:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Jack up the truck and pressure wash between leaves and into the bushings. Use a good dry flow type lube. You can take the whole pack apart and put bike tube or any other rubber type isolator in there if you want too.
  4. Mar 22, 2012 at 11:08 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    My experience is that the squeak doesn't come from the front bushing but from the leaf that wraps around the front bushing , pay extra attention to cleaning this area , I then installed a strip of EPDM rubber between the leafs here , this ended my squeak
  5. Mar 22, 2012 at 11:08 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    I have been using graphite lube, is that a good dry flow type?
  6. Mar 22, 2012 at 11:09 AM
    OZ-T
    Peter North
    British Columbia
  7. Mar 22, 2012 at 11:10 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I did this when I bought my leaf pack used I changed out the bushing and it was fine but I dont wash the leaf they tend to squeak
  8. Mar 22, 2012 at 2:00 PM
    ross123
    fort bragg
    thx for the tips im gonna try to clean them real good and spray them down with grease first. i really dont feel like taking them apart lol
  9. Mar 22, 2012 at 2:08 PM
    OZ-T
    Peter North
    British Columbia
    I didn't take mine apart , I just pried the leafs apart with a big screwdriver and worked the EPDM strip in , see the link I posted .
    FWIW , I will be doing something similar to what Anthony did when I pull my pack to add the d29xl OME AAL .
