Squeaky noise from engine bay as soon as I start truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco Egghead, Mar 28, 2025.
  1. Mar 28, 2025 at 9:22 AM
    Taco Egghead
    Taco Egghead [OP] Well-Known Member
    I first noticed this noise last week. Any idea what it could be? I'm at 82k miles. Could not upload a video. It stops after the truck runs for about 5 minutes and it's not a constant squeaky noise but intermittent.
  2. Mar 28, 2025 at 9:53 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    Serpentine Belt?
    :popcorn:
  3. Mar 28, 2025 at 10:14 AM
    shoeshineninja
    shoeshineninja Active Member
    2018 Cement DCSB TRD Sport
    What ^ said. Or idler pulley? If the noise, chirp, squeal etc., seems to be coming from the belt and/or idler pulley, you can check to see if the idler pulley has any play by trying to wiggle it. When the engine is off of course.
  4. Mar 28, 2025 at 10:17 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Post a video and try to see if it’s from the front or rear of the engine. My bet is on the high pressure fuel pump.
    Taco Egghead[OP] and Kolter45 like this.
  5. Mar 28, 2025 at 10:18 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Remove the belt see if the noise goes away just don’t run the engine long enough to overheat. If noise goes away while belt is still off with engine not running spin the pulleys by hand and you should find the bad one.
    Video with audio would help.
    Taco Egghead[OP] likes this.
  6. Mar 28, 2025 at 10:27 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Spray some belt dressing on the drive belt and see if the noise goes away. Even if the noise goes away, I would still change the belt.
    https://www.autozone.com/greases-and-gear-oil/lubricant-grease/p/crc-belt-conditioner-7-5oz/55909_0_0?cmpid=LIA:US:EN:AD:NL:1000000:pER:19488533498&gclsrc=aw.ds&gad_source=1&gbraid=0AAAAADkcoVsfakUXqVNbCW4g3SQrhHIXS&gclid=EAIaIQobChMI59LN1aStjAMVfR-tBh3o2Q3BEAQYASABEgIKVvD_BwE
    If you think the noise is coming from the high pressure fuel pump, see if you also smell fuel in the engine bay. 2016-2022 Tacomas are covered for 10 years regardless of mileage on the fuel pump recall.
    https://static.nhtsa.gov/odi/tsbs/2023/MC-10236191-9999.pdf
  7. Mar 28, 2025 at 10:28 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Or DIY ghetto it with comet powder- works! But unlike what some people do, I’d only do it to test- rinse it off and fix the real issue like a bad water pump or idler pulley as others posted above^^^
    Edit: (I just remembered that spraying it with just a bit of water also sometimes works).
  8. Mar 28, 2025 at 10:36 AM
    Taco Egghead
    Thanks guys, I'm a little busy now but I will try to upload a video by tomorrow.
    t0p_d0g likes this.
  9. Mar 28, 2025 at 12:50 PM
    TA2016
    Oregon
    There are many ghetto DIY. Here is a guy using Old Spice deodorant. I did not originally post this video because I don’t like the idea of anyone having their hand close to a running fan.
    https://www.youtube.com/watch?v=Ax-qffy9OIA
  10. Mar 28, 2025 at 8:51 PM
    OnHartung'sRoad
    my grandfather couldn’t flip a bird with his right hand, guess why?! :rofl:
  11. Mar 29, 2025 at 11:22 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Rubbing a little white hand soap from a soap bar on the belt sometimes works. Reduces friction and gives the belt some grip. If noise stops change belt asap. White bad soap does no harm.
  12. Mar 31, 2025 at 11:24 AM
    Taco Egghead
    Well I couldn't replicate the noise this weekend :annoyed:
  13. Mar 31, 2025 at 11:27 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Your mileage suggests it's the belt. Mine is also due and making the same noise on startup, but only when it's damp out... belt is slipping until it dries off.
  14. Mar 31, 2025 at 11:56 AM
    Taco Egghead
    How safe is it to drive?
  15. Mar 31, 2025 at 5:43 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Perfectly safe... just annoying and evidence that the belt is due for replacement. If you ignore it long enough, the belt could break. If that happens, I imaging your truck will go into limp mode... but I would recommend replacing it sooner than later and not risk the potential inconvenience of having it break at a bad time.
  16. Mar 31, 2025 at 5:47 PM
    BLtheP
    Plano, TX
    There have been a lot more high pressure fuel pump chirp noises than there have been belt drive related noises. We don’t really know what his issue is, especially not without a video and him listening closer to different areas under the hood.
    shakerhood and Taco Egghead[OP] like this.
  17. Mar 31, 2025 at 5:47 PM
    Taco Egghead
    That settles my nerves a little but :). Do you guys replace the serpentine belt yourself or do you have a mechanic do it?
  18. Mar 31, 2025 at 5:48 PM
    Taco Egghead
    I'll try to get a video once I can replicate the noise.
  19. Mar 31, 2025 at 5:49 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Im @122K and thought I heard a belt noise this morning for the first time..
  20. Mar 31, 2025 at 6:07 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
