Squeaky OME Dakar Leaf pack fix/solution?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Leo4x2, Apr 21, 2017.
  1. Jun 24, 2019 at 7:05 PM
    #121
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    i fixed the squeak by removing the leafs all togther
  2. Jun 25, 2019 at 2:35 AM
    #122
    lynyrd3
    Bill
    East Central Upstate NY
    :rofl:
  3. Jun 25, 2019 at 10:03 AM
    #123
    Sclarpepplar
    Sclarpepplar Your raptor lights look like braces.
    Corey
    2016 TRD sport
    BFG KO2's Fuel rims SPC uca's Arb OME lift Arb on board air Prinsu designs roof rack
    Guess you'll have to spend the $30 or so to fix it.
    lynyrd3[QUOTED] likes this.
  4. Jun 25, 2019 at 2:13 PM
    #124
    lynyrd3
    Bill
    Just crawled under to look at Dakar’s . Looks like only one hole in the rear and one in the front for grease gun with needle injector . Is this all there is ?
  5. Jun 25, 2019 at 4:27 PM
    #125
    Sclarpepplar
    Corey
    2016 TRD sport
    They were all greasable. They are also all useless. Absolutely useless. Don't grease them, throw them away.
  6. Sep 15, 2019 at 8:57 AM
    #126
    Toyojo
    Toyojo Well-Known Member
    Joe
    Erie,pa
    2010 mgm dcsb TRD offroad
    I'm in the process of rebuilding a set of dakars to anyone who used the speedway leaf liner how is it holding up, pics ect. Thanx
  7. Sep 15, 2019 at 11:38 AM
    #127
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Just a helpful hint: if your OME leafs (or any leafs) squeak, get some Motorkote. Mine squeaked horribly. Every speed bump was an annoyance. I'd pressure wash and Fluid Film - that worked for a few days, then squeaking again. I sprayed Motorkote on the pads and on the bushings. No squeaks at all for 7 months and still squeak free. Mulitple washings, rain, mud, towing 3500lbs, still no squeak. An I mean literally no squeaking at all :thumbsup:
    61ragtop, Bigmo and Toyojo like this.
  8. Sep 15, 2019 at 1:54 PM
    #128
    Toyojo
    Joe
    Erie,pa
    How are these working out I'm rebuilding my dakars and thinking of using it full length on each leaf and using the anti friction pads to hold them in
  9. Sep 16, 2019 at 9:13 AM
    #129
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    Zero issues even after several years. I'm running full length liners. I don't ever think about them because they are quiet.
    Toyojo[QUOTED] likes this.
  10. Sep 16, 2019 at 9:26 AM
    #130
    Toyojo
    Joe
    Erie,pa
    Thanx for the info
  11. Oct 8, 2019 at 12:44 PM
    #131
    Dryvah
    Dryvah Well-Known Member
    MA
    2019 Tacoma TRD
    I dont know if this is known or not. I have not read through this whole thread. I know..
    But anyway, mine have be squeaking and groaning more and more. Ive had them on for 3 months or so. Its gets much worse as they get dirty. Especially after a wet day on the trails. It got so bad, to the point I could here it at every bump, every stop, every go. Even over the radio.
    Today I had enough. I took the wheels off and started experimenting with 1/16 plastic shims. I started putting them in different spots to narrow down where the noise was coming from exactly. I finally pin pointed where the noise was coming from. The yellow insulators between each leaf at the ends. I put a shim between each one and the noise is gone!
    Im not sure if the shims will stay there, but im happy I found where the noise is coming from.
  12. Oct 8, 2019 at 12:53 PM
    #132
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    You should be able to grease those inserts from the bottom. That would help with the squeak but obviously need to be done regularly.
  13. Oct 8, 2019 at 12:55 PM
    #133
    smw62891
    smw62891 Well-Known Member
    Stephen
    Santa Fe, NM
    09 Tacoma DCSB
    I just installed different isolators mentioned in this thread. Got rid of the shitty yellow ones. Have worked great for me as well as others. 30 dollar fix
  14. Oct 8, 2019 at 12:59 PM
    #134
    Toyojo
    Joe
    Erie,pa
  15. Oct 8, 2019 at 1:51 PM
    #135
    Toyojo
    Joe
    Erie,pa
    My yellow pads were in bad shape that's why I replaced them with the dormans which seem to be of better quality most of my noise was from the poly bushings that's why I went to factory
    Crikeymike likes this.
  16. Oct 9, 2019 at 8:05 AM
    #136
    GreyComa
    GreyComa Well-Known Member
    OKC
    2010 Grey Tacoma TRD Sport Double Cab Short Bed
    OME CS047R Dakar leaf springs, OME 2885 coils (3/8" spacers, and 1/4" on driver side), Bilstein 5100s, Light Racing UCAs, ToyTec sway bar relocate, N-Fab 2" nerf steps, Bestop Supertop, BlackRhino Glamis wheels 17x9, extended diff breather mod.
    Does anyone have experience with black energy suspension bushings versus the red or yellow? I know the black ones are supposed to be 'self lubricating', but wanted to see if anyone can confirm that they actually squeak less than the other colors. Seems that most of my squeaking comes from the front bushings.
  17. Oct 9, 2019 at 8:11 AM
    #137
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    https://www.tacomaworld.com/threads...pack-fix-solution.487394/page-5#post-18894436
    https://www.tacomaworld.com/threads/change-the-front-bushings-in-your-dakars.479071/
    https://www.dobinsonsdirect.com/pro...x4-single-cab-extra-cab-dual-cab~yr_2005-2015
  18. Oct 9, 2019 at 8:12 AM
    #138
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Does this actually work? I have a hard time believing the grease gets between each leaf.. and anywhere near where the actual movement/ squeaking would be taking place (towards then outward ends of each leaf.)
  19. Oct 9, 2019 at 8:15 AM
    #139
    geekhouse23
    The issue is that the front eye on the leaf pack was rubbing on the leaf spring mounts on the frame of the truck. You get an idea of where it rubs from this picture:
    New bushings from Wheeler's and those greasable bolts and everything was silent for me. Really worked well.
    GHOST SHIP likes this.
  20. Oct 9, 2019 at 8:38 AM
    #140
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I just lubed up my leafs last weekend and this is what I noticed. The yellow isolator pads were pretty much shot. Worn really unevenly and absolutely packed full of dirt.
    I pulled out the isolators and cleaned ou tthe dirt and then lubed them up with fluid film. It's been quiet so far.
    But next time it gets to squeaking I'll be swapping them out for dorman or Toyota OEM isolators.
