Squeaky Penguin's 2nd Gen Build - Take 2
Discussion in '2nd Gen. Builds (2005-2015)' started by Squeaky Penguin, Jan 7, 2021.
  1. Apr 17, 2021 at 7:50 PM
    #61
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ooo I like that. 1st gen kits too. Nice.
  2. Apr 18, 2021 at 8:54 AM
    #62
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Sway bar eh? . . . What rate springs in the front?
  3. Apr 18, 2021 at 9:01 AM
    #63
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Yeah, I helped @Night Eagle install a set on his truck. They were solid and fit nice and tight.
    I think for peace of mind I'm going to swap back to the factory cams today, throw the bison ones in the garbage, and order Taco Tabs if/when I have problems holding an alignment.
    Sticking with the sway bar for now.
    600lb springs. Tim and a discussed and we'll see how they do, and swap to 650s if needed.
    Wishbone Runner[QUOTED] and TMFF like this.
  4. Apr 18, 2021 at 8:07 PM
    #64
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Alignment is still holding strong with no issues. Might do a quick Alignment check here soon because I through my new maxxis 35s on the truck and it favors the left a bit and make sure things are still happy.
    Blackdawg[QUOTED] likes this.
  5. Apr 18, 2021 at 9:52 PM
    #65
    Blackdawg
    Monte
    Wyoming/St. Louis
    what UCAs your running with them? I have some SPC's on Igor that these might be perfect on, despite the pain the ass it will be to adjust them..
  6. Apr 19, 2021 at 9:11 AM
    #66
    Squeaky Penguin
    Brett
    He has TC heimed uppers.
    I just aligned my truck yesterday after swapping the cams back to stock and cranking up the coilovers, and it couldn't be easier with SPCs. Just more or less max the cams out for caster, same regardless of the type of cams, and then dial in camber with the uppers.
    Also built a hilift mount, it's a tight fit but makes use of otherwise wasted space, and started organizing shit. Lots more organizing and optimizing storage to go for this summer.
  7. Apr 19, 2021 at 12:07 PM
    #67
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah i just imagine if you want to rotate the plate on the SPCs you'll have to jack the truck up and remove the wheel to have a chance at getting it apart and back together right.
  8. Apr 19, 2021 at 3:01 PM
    #68
    Night Eagle
    Leo
    2014 TDR Off Road
    I am running total chaos uniball/heimed uppers.
    Matic and Blackdawg[QUOTED] like this.
  9. Apr 26, 2021 at 4:29 PM
    #69
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    can you measure how much room is between the top of your cab antenna, and the bottom of the GFC ?
    I just put on the kb voodoo rails yesterday, and have a GFC V2 coming in June
  10. Apr 26, 2021 at 4:34 PM
    #70
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    hopefully he's still out exploring... might be delayed
    fatfurious2[QUOTED] likes this.
  11. Apr 26, 2021 at 4:37 PM
    #71
    fatfurious2
    David
    Ashburn, VA
    No worries. I am 98% sure that the kb voodoo caps and my little antenna will fit fine. I believe its only 3/4" tall, so I should be good. Ive just been doubting myself
  12. Apr 26, 2021 at 4:47 PM
    #72
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    have you checked the gfc forum (not in TW)? question might already be answered over there... good source for gfc related items.
  13. Apr 26, 2021 at 4:55 PM
    #73
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Have you had any issues with your TC uppers squeeking? When I had mine installed a few years ago they squeaked like crazy. Took em back to the shop and the over greased the zerk a shit ton. Removed a bunch of grease which unloaded the pressure against the rubber grommets and they went silent.
    The reason I ask is a girl up the street has an XPS X? Tacoma and she runs TC uppers and asked me about squeaking noises upfront.
  14. Apr 26, 2021 at 4:56 PM
    #74
    Squeaky Penguin
    Brett
    Unfortunately not still out adventuring, but I'll fix that problem for a much longer duration in a little over a month. :D
    I'm with Bob, check the GFC forum. Not sure how valuable any info I give you would be given I don't have a sharkfin, and they've certainly made plenty of changes since my #18 build.
  15. Apr 26, 2021 at 5:10 PM
    #75
    fatfurious2
    David
    Ashburn, VA
    I have, but nothing specific about my antenna
    I don't have a shark fin either. I have the weird 09-11 one..
  16. Apr 26, 2021 at 5:30 PM
    #76
    Squeaky Penguin
    Brett
    First proper trip in this rig was a great success. I did forget the DSLR at home, so phone pics will have to suffice. Very pleased with how everything came together and performed. Few more things to address, but the truck is just about ready for a summer of non-stop adventure.
    [​IMG]20210422_110334 by Brett Bjorgum, on Flickr
    [​IMG]20210422_152237 by Brett Bjorgum, on Flickr
    [​IMG]20210422_160000 by Brett Bjorgum, on Flickr
    [​IMG]20210422_175923 by Brett Bjorgum, on Flickr
    [​IMG]20210422_193900 by Brett Bjorgum, on Flickr
    [​IMG]20210422_194357 by Brett Bjorgum, on Flickr
    [​IMG]20210423_103212 by Brett Bjorgum, on Flickr
    [​IMG]20210423_103428 by Brett Bjorgum, on Flickr
    [​IMG]20210423_132525 by Brett Bjorgum, on Flickr
    [​IMG]20210423_141200 by Brett Bjorgum, on Flickr
    [​IMG]20210424_084148 by Brett Bjorgum, on Flickr
    [​IMG]20210424_121349 by Brett Bjorgum, on Flickr
    [​IMG]20210424_130136 by Brett Bjorgum, on Flickr
    [​IMG]20210424_155313 by Brett Bjorgum, on Flickr
    [​IMG]20210424_201002 by Brett Bjorgum, on Flickr
    [​IMG]20210424_183833-Pano by Brett Bjorgum, on Flickr
    jubei, boostedka, BYJOSHCOOK and 8 others like this.
  17. Apr 26, 2021 at 5:35 PM
    #77
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    @Squeaky Penguin have you already announced a tentative route/plan for this summer? Or is the wind going to guide your free spirit?
    JasonLee likes this.
  18. Apr 26, 2021 at 5:40 PM
    #78
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i miss that area
  19. Apr 26, 2021 at 5:42 PM
    #79
    fatfurious2
    David
    Ashburn, VA
    That area looks amazing!
    Squeaky Penguin[OP] likes this.
  20. Apr 26, 2021 at 6:59 PM
    #80
    Squeaky Penguin
    Brett
    I have zero roof antenna. Looks like 1 1/4" at the front of the overhang. Maybe a touch more at the back of the roof where it slopes down.
    Definitely the later. I don't have a clue.
    Just need to decide on where to start, being the areas I would like to head to first won't be accessible at the start of June. Then just jump between fishing and biking spots, places that look interesting to explore on the map, and whatever else I find in between. I did decide to sorta continue working to the tune of about 5 hours a week, so while I'm grabbing wifi in whatever town I end up in, I'll research the area a little too. That's about as much of plan as I can currently come up with. :rofl:
    I was soo nice to be back. It's been 5 years for me, and the 1st trip wasn't long enough. Will need to head back again in a couple years.
