Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Apr 12, 2017 at 7:54 PM
    #2141
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'll mess with it and see what I can do. It will have to move out quite a ways, and inboard to clear the shock. Just barely enough width between the ubolt plates that bracket to fit the shock.
    TC. Better uniball angles and don't have to mess with silly proprietary hardware.
    All that other crap, and ball joints with a different name, and covers are a gimmick IMO.
    Deathbysnusnu[QUOTED] likes this.
  2. Apr 12, 2017 at 7:55 PM
    #2142
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea don't bother with the Icon cover things..actually worse for the joints
  3. Apr 12, 2017 at 7:55 PM
    #2143
    Blackdawg
    Monte
    Wyoming/St. Louis
    curious as to why you say this? vs Camburg and well any.
    Although...honestly id probably got TC as well...
  4. Apr 12, 2017 at 7:58 PM
    #2144
    Jacob032
    Jacob032 Well-Known Member
    Jacob
    I wanted to go with Camburg but I have read negative things about them not aligning properly/fixing caster camber issues but I guess everyone has something to say about everything.. I think I will just go with TC..
  5. Apr 12, 2017 at 8:00 PM
    #2145
    Jacob032
    Jacob
    And they are on sale for 706$
  6. Apr 12, 2017 at 8:10 PM
    #2146
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Brett how much flex do you have in the hose. Is there anyway you can mount the resi at an angle on the inner part of the frame so the hose is pointed down.
  7. Apr 12, 2017 at 8:25 PM
    #2147
    Squeaky Penguin
    Brett
    I'm babbling more unsubstantiated opinions. My uniballs are perfectly flat at ride height, seems like this isn't the case for the others. I am also nowhere close to maxing out the uniball travel within my shock travel. I've seen others who's uniball cups are hitting the misalignment spacers at full droop.
    Don't think so. Hose can't go any higher cause it would hit the bed, and the resi would end up below the frame.
    First thought is to weld some tubing at a 45 degree angle to the frame and rear crossmember and mount them to those.
  8. Apr 12, 2017 at 8:35 PM
    #2148
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Perfectly ok in your own build thread. Just can't take it out to the 'floor of the house'. :rolleyes:
  9. Apr 12, 2017 at 9:35 PM
    #2149
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well considering ads apparently doesn't make extended travel coil over unless special requested...no wonder your not using all your travel haha :p
    Can't remember where that came up though..maybe it was cody.. @Bennett707
    And you don't run as much lift as some...so...yeah haha :luvya:
  10. Apr 12, 2017 at 9:38 PM
    #2150
    Squeaky Penguin
    Brett
    Do you have Icon UCAs? :p
    I'll continue to babble unsubstantiated opinions.
    Who's opinions do you care to value? I'm not concerned with the majority rule on the 'floor of the house'. They've steered me wrong too many times.
    I gained like 3/4" of droop with the coilovers, any more and the CVs will bind. Extended travel enough. At least I'm not using my uniball through bolt as a limit strap.
    alee891 and Blackdawg[QUOTED] like this.
  11. Apr 12, 2017 at 9:45 PM
    #2151
    Digiratus
    Roaming the PNW
    The RedHead
    Haha... Touche` No, I drank the camburg koolaid.
    Were there marks/indentations on the through bolts or the uniball cups on these mystery icons?
  12. Apr 12, 2017 at 10:22 PM
    #2152
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    So I talked to someone recently that got them and they said they do them now. Idk. I talked to ads directly and they indicated they build them to what others Call extended. It was impossible to get travel measurements. I insisted on them maximizing travel and he said he would. Whether it actually happened or is any different...
  13. Apr 13, 2017 at 4:13 AM
    #2153
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    I don't think you understood what I said. But the 45* will be better. It will help as a gusset and hold your resi. Also keep the hose free and not binding by the curves I was thinking about. So if you have a good spot for that 45 then that will be your best bet. But you already know this. Going back into the shadows. Carry on. :thumbsup:
    jubei likes this.
  14. Apr 13, 2017 at 8:29 AM
    #2154
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    If you want to change the resi hoses, I can do that for you. So if you want to find a temp solution like attaching to the body or on your cross tube in the center for now, we can change where and how they mount later.
  15. Apr 13, 2017 at 9:05 AM
    #2155
    Squeaky Penguin
    Brett
    I figure with a couple 90°s we can get the resis to mount on the outside of the frame so I can show off my Kings. :cool:
    :D
    If I can't find a permanent solution I like, I'll come visit you. Thinking the 45° piece of tubing and resi mounting will work, and Ray's right, another gusset can't hurt. Don't think I can get them on the shock crossmember. Bottom of the bed would work if I completely run out of options.
  16. Apr 13, 2017 at 9:10 AM
    #2156
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    But the laminar flow will be shit with 13 90's to get the resi in the tire rub zone!!!! BUt I can get it done!!!
    :rolleyes:
    Mine are in the center on the tube I mounted my shocks to directly under the bed. I do have 90's at the shock body with swivels that helps with hose routing. I also had to dent the bed up to clear the 90 and the top if the shock.
  17. Apr 13, 2017 at 9:23 AM
    #2157
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    That's not denting, that is custom fabrication with a hammer
    Deathbysnusnu likes this.
  18. Apr 13, 2017 at 9:29 AM
    #2158
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
  19. Apr 14, 2017 at 12:14 PM
    #2159
    Madjik_Man
    Colorado Front Range
    I'm digging the last 5 pages of this thread.
    So ummmm, how are we looking? Will this beast be trail ready by 4/24?
  20. Apr 14, 2017 at 12:30 PM
    #2160
    Squeaky Penguin
    Brett
    13 90°s? Isn't that the same as turning your clickers up?
    Still hoping to be rolling this weekend. Depends on if anything else decides to give me trouble. Will still have some finishing touches like mounting stuff back to the swingout that probably won't get done right away though.
