Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Apr 30, 2017 at 7:15 AM
    #2281
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Revalve would still probably help.
    Don't know, but think it had a little more. Just barely on the bump there. Shocks/bumps were setup for vertical travel, don't really care about articulation. Being they're inboard slightly, they'll never move as much flexing as Durring vertical travel.
    Based on the dirt, you can tell I used more of the shock travel previously.
    BYJOSHCOOK[QUOTED] likes this.
  2. Apr 30, 2017 at 9:37 AM
    #2282
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I am curious about what you would change on the valving on the ADSs. Add some rebound? Or more than that? It does look like the front comes up a lot after landing. The back looks pretty composed. :thumbsup:
    What coil are you running?
  3. Apr 30, 2017 at 11:17 AM
    #2283
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    agreed.
    Looked like aadding a touch of comp and rebound would help. But no idea what is in there now. I have no idea what my ADS are valved at either.
  4. Apr 30, 2017 at 7:48 PM
    #2284
    Squeaky Penguin
    Brett
    650lb coils.
    Not a clue what's in there now, but would need to defer to @TMFF for valving advice. Not an expert in that field. Thinking more rebound, and a flutter stack if there isn't one already.
  5. Apr 30, 2017 at 8:05 PM
    #2285
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    You're running a flutter stack in the rear, aren't you? Did the rear seem better behaved over washboards?
  6. Apr 30, 2017 at 8:20 PM
    #2286
    Squeaky Penguin
    Brett
    Rear has a flutter stack. The coilovers have always performed well on washboards, which I drove quite a bit of yesterday. Rear wasn't noticeably better for those.
    jubei[QUOTED] likes this.
  7. May 1, 2017 at 4:59 AM
    #2287
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Just curious because it looks like the shock was about done, just a little bit left before it hits
  8. May 1, 2017 at 8:59 AM
    #2288
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I would just add medium speed rebound. Too much comp valving for what you don't do often (jumps) can make everything else rattle your fillings out even with a flutter stack. Hell your fronts just might be low on charge so the shock isn't working 100% like it should.
  9. May 14, 2017 at 6:53 PM
    #2289
    Squeaky Penguin
    Brett
    Hit 270K miles on this pile above the North Rim.
    Power steering pump sounds like it's about to explode.
    Poly bushings in the front sound like a group of seals.
    Stick smashed an ebrake bracket and smoked the brakes.
    My favorite Wilson flex CB antenna broke.
    Trip was awesome!
    [​IMG]Alstrom by brettbjorgum, on Flickr
    Now that I figured how to stitch those together, I need to read how to actually use lightroom. Will be a bit before I can go through my pics.
  10. May 14, 2017 at 7:12 PM
    #2290
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    :popcorn:
  11. May 14, 2017 at 7:47 PM
    #2291
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sounds like a good trip!
    In for pics!
    Lemme know if you need any tips in LR
    jubei likes this.
  12. May 14, 2017 at 7:48 PM
    #2292
    jubei
    NoCo
    Stuff. Also things.
  13. May 17, 2017 at 5:42 PM
    #2293
    Squeaky Penguin
    Brett
  14. May 17, 2017 at 5:48 PM
    #2294
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    looks pretty damn good for giving up, nice pics dude. :thumbsup:
    jubei likes this.
  15. May 17, 2017 at 5:50 PM
    #2295
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Looks like part of the Southern Utah Traverse if I'm not mistaken?
    Planning a trip for this in August and seeing these pictures has me even more excited!
  16. May 17, 2017 at 6:01 PM
    #2296
    Squeaky Penguin
    Brett
    We made our own route, but looks like a lot of the same area.
    We ran Hole in the Rock Trail - Crossed the Ferry - Burr Trail - Hole in the Rock Road - didn't read the Trail Damage report on the new start of Left Hand Collet and missed it - Smokey Mountain Road - Grand Bench - Alstrom - before heading to the North Rim.
    If you have time, I wouldn't worry about following the predetermined route just so. There's tons of awesome stuff out there without having to complete a certain route someone else laid down.
  17. May 17, 2017 at 6:05 PM
    #2297
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Forgot Escalante :smack:
  18. May 17, 2017 at 6:10 PM
    #2298
    Squeaky Penguin
    Brett
    Escalante and back again.
    Read the 2nd paragraph:
    https://www.traildamage.com/trails/index.php?id=480
    Should have only been there twice. Probably only once if we pushed the spare gas going from the end of HITR to Big Water. Oh well, at least we have stories of how lovely Escalante and all three gas stations there are.
  19. May 17, 2017 at 6:15 PM
    #2299
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    "Meet at the Phillips 66 next to Nemo's at 40 East Main Street in Escalante."
    We did that part....
    Squeaky Penguin[OP] likes this.
  20. May 17, 2017 at 6:24 PM
    #2300
    Squeaky Penguin
    Brett
    Now I want another shake.
    And to go back here:
    [​IMG]Alstrom moonrise (1 of 1) by brettbjorgum, on Flickr
