Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Jun 5, 2017 at 10:11 AM
    #2341
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Do you have welded rod ends? If not, consider swapping out for them. Will save you an inch.
    I haven't measure exactly, but I don't think my lower mounts are any more than 2" below the axle.
    snowboard704[QUOTED] likes this.
  2. Jun 5, 2017 at 10:32 AM
    #2342
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I am curious how you feel about your Hankook MTs? Would you buy them again? Yours are 295/75R16s correct?
  3. Jun 5, 2017 at 11:38 AM
    #2343
    Squeaky Penguin
    Brett
    I'm on my second set, very happy with them. I feel they were an improvement over the KM2s in road noise and handling, and just as good if not better offroad. No complaints on traction, and never had a sidewall issue even aired down to 10 or less. Load range D with 3 ply sidewall is nice too. Just don't expect the same tread life, they're softer and wear a little quicker. My first set was a bad example as I messed them up with a bad alignment. Current set has like 8k miles on them and look excellent.
    Yes 295/75r16
  4. Jun 5, 2017 at 12:58 PM
    #2344
    Digiratus
    Roaming the PNW
    The RedHead
    These are one of several I'm looking at. These seem to be the least expensive of the group. I am not so concerned with tread life as I am with durability and traction. Everything else seems to be load range E too which I am not used to.
    This size would also be a bit larger than the 33x10.5s I've been running so I sure there will be a lot of clearancing required. You did not have to tub correct?
  5. Jun 5, 2017 at 1:04 PM
    #2345
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Here is that exact tire, 295/75-16 next to a 285/75-16 in case you need a visual.
    These are the Nitto Terra Grappler G2, not the Hankook, but the size should be similar.
  6. Jun 5, 2017 at 1:13 PM
    #2346
    Squeaky Penguin
    Brett
    True 33" and maybe a smidge more. Probably about an inch bigger than the 33x10.5s
    No tubbing, but everything short of it. Lots of cutting and smashing involved. It's not your regular pinch-weld mod.
  7. Jun 5, 2017 at 1:42 PM
    #2347
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for the visual.
    I'm not sure this is true. There's a lot of inconsistancy between brands.
    Hankook says 33.6" and tiresize.com says 33.4 so they are not 33s in the typical sense. New BFG 33x10.5 are lucky if they are 32.5s.
    Thanks for the feedback. All good information.
  8. Jun 5, 2017 at 2:10 PM
    #2348
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    They are king 2.5 10s.. they already have the small rod ends on
  9. Jun 5, 2017 at 3:30 PM
    #2349
    Squeaky Penguin
    Brett
    :thumbsup:
    And yeah, tire sizes are such a can of worms. Based on what most people consider a "33" the 295s are a "34".
    Mine are 2.5x10 Kings. You're build shows the regular aluminum rod ends. You could still save another inch with the welded ends.
  10. Jun 5, 2017 at 5:45 PM
    #2350
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Hmm okay I'll definitely look into it then
  11. Jun 5, 2017 at 5:58 PM
    #2351
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Essentially, the size a manufacturer stamps on the sidewall is only loosely related to the size of the tire.
    :rofl:
  12. Jun 5, 2017 at 6:58 PM
    #2352
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Yeap. My Cooper say 315/75/R16 which their spec sheet states is 34.6" and on the other side they say 35x12.50OD. :facepalm:
  13. Jul 18, 2017 at 9:03 PM
    #2353
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is your topper bolted or clamped down? I can't seem to keep the rear from walking outward and I'm thinking about bolting it down instead of the clamps.
  14. Jul 18, 2017 at 10:07 PM
    #2354
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    I'd use both. Bolts as pins to hold it in location though not really clamp it down. Clamps for the clamping force. The bed is 2 layers thick with about 1/4" between the 2 layers on the top of the rail
    Reh5108[QUOTED] likes this.
  15. Jul 19, 2017 at 7:45 AM
    #2355
    Squeaky Penguin
    Brett
    Just 4 clamps. Topper has never moved, although it's a lot lighter than yours.
    It does have some foam double stick tape on the bottom, probably not very sticky anymore from taking it on and off all the time, but guessing it helps a little.
  16. Jul 19, 2017 at 7:52 AM
    #2356
    Squeaky Penguin
    Brett
    Oh, and not much going on in here. Tossed a Huster antenna on a hood mount to replace my broken Wilson. Bushings still squeak. Napa power steering pump is working well.
    I've only put like 500 miles on it since the Utah trip.
  17. Jul 19, 2017 at 8:06 AM
    #2357
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
  18. Jul 19, 2017 at 8:54 AM
    #2358
    Squeaky Penguin
    Brett
    I thought about that, but not confident how well it will work.
    After I met up with you, I pulled the arms and greased them really well. Put as much grease as possible on the surface that contacts the gusset. It moved freely and was squeak free for about half a day of wheeling, and then got progressively worse as the grease works its way out.
  19. Jul 19, 2017 at 10:46 AM
    #2359
    Reh5108
    Idaho
    My previous topper did the same thing though it didn't have the foam. Now I have the foam but it still moves. I think I'll try what @thefatkid suggested
  20. Jul 19, 2017 at 11:24 AM
    #2360
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Find a lathe, make the outer lip thinner and add a thin bronze washer between the gusset and bushing with grease. Or turn up the tunes and let everyone else hear the sounds of your people!
