Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Jul 19, 2017 at 12:08 PM
    #2361
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That seems like a solid idea. :thumbsup: Need to see if I can find washers that work on McMaster.
    Don't have a lathe, but I'm sure I'll find a way to shorten the bushing and sleeve the width of a washer.
    Speedytech7 likes this.
  2. Jul 19, 2017 at 12:10 PM
    #2362
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can use oil impregnated bronze washers/bushings too, they work very well for applications like this.
  3. Jul 19, 2017 at 12:19 PM
    #2363
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
  4. Jul 19, 2017 at 12:33 PM
    #2364
    Squeaky Penguin
    Brett
    Wonder why TC says to skip the outside washers with the coil bucket gussets? Seems like it would have made me life easier if I kept them and just moved the gussets out a smidge to fit the washers.
    Going to figure out the size of that through bolt and then order some of those washers and give it a try.
  5. Jul 19, 2017 at 4:46 PM
    #2365
    Oside7even6ixty
    Oside7even6ixty Well-Known Member
    When I had my tc coilbucket gussets installed, the washer was left out.
  6. Jul 19, 2017 at 5:10 PM
    #2366
    Squeaky Penguin
    Brett
    Exactly. That's what the instructions say, and that's what I did, but it's causing serious squeaking. Can't keep grease between the outer edge of the bushing and the gusset.
  7. Jul 19, 2017 at 5:21 PM
    #2367
    Oside7even6ixty
    I haven't had any squeaking with mine, but I always greased the shit outta mine. An you def off road your truck more than me ha, so that's prob contributing
  8. Jul 19, 2017 at 7:06 PM
    #2368
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    When I put mine together I used a black moly grease and I greased all suffaces of the bushing and so far I haven't had any squeaking. I only hit my zerks once since the install.
    What kind of grease are you using? If you can get a hold of black moly grease I say give that a try. Good luck buddy. Hope everything is well.
  9. Jul 19, 2017 at 7:48 PM
    #2369
    Squeaky Penguin
    Brett
    I'm doing good Ray! :thumbsup:
    I exclusively use SuperLube for the poly bushings, which is suppose to be the best for those. Petroleum based grease can be harmful for poly, so I've stayed away from those.
    SilverGhost[QUOTED] likes this.
  10. Jul 20, 2017 at 4:10 AM
    #2370
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    So that's what I've herd. Whatever floats your boat. I look at the bushings like a wear and tear item. At least that's what I tell myself. The grease was free so that's the main reason I use it. I've heard of the horror stories of the UCA squeaking. I'm glad I don't have the issue. That's all. Well good luck figuring it out. Peace.
  11. Jul 20, 2017 at 8:18 AM
    #2371
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    really any lithium based grease is good for poly.
    I use lithium based moly grease and have never had squeaking issues either.
  12. Jul 26, 2017 at 7:18 PM
    #2372
    Squeaky Penguin
    Brett
    So, ordered these after confirming the bolt was 14mm, should have read more, but they I don't think they'll work as the OD is not nearly enough. Now I have $20 of useless fancy washers.
    Put some grease in the zerks which helped slightly, then swapped the nuts for nylocks. Keeping them slightly looser seems to help. Half-ass/temporary solution at best.
    Put it together and noticed the lower bearing on the shock is creaking. A little Boeshield stopped the noise, but guessing it's on it's way out.
    Oh, and blew a P1135 code pulling it into the garage. Reset it and it came right back.
    So tired of working on this damn thing. :annoyed:
  13. Jul 26, 2017 at 8:10 PM
    #2373
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    :popcorn:
    What's the P1135 code mean?
  14. Jul 26, 2017 at 8:20 PM
    #2374
    Squeaky Penguin
    Brett
    Looks to be upstream O2 sensor.
    Never replaced either, and have 272k on the clock. I have had the infamous P0420 pop up, or at least pending, very infrequently the last couple years too. Probably should replace both up and downstream sensors.
  15. Jul 26, 2017 at 8:21 PM
    #2375
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I think I have the same code. Haven't looked into it yet though. I need to fix some exhaust leaks before I start worrying about sensors.
  16. Jul 26, 2017 at 8:49 PM
    #2376
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    My UCA bushings seem to need to be greased about every 1000 miles or so, otherwise they sound like monkeys fucking. Or at least what I imagine monkeys fucking might sound like.
    I've been using super lube like you have, and I have been torquing the through bolts down to OEM spec like the AP instructions called out. Seems to work great right up until they abruptly start squeaking. I might try some red and tacky next time and see if that lasts a bit longer.
    rngr and BYJOSHCOOK like this.
  17. Jul 26, 2017 at 8:55 PM
    #2377
    Squeaky Penguin
    Brett
    My issue is solely because of the coil bucket gussets. Never had a problem before that.
  18. Jul 26, 2017 at 9:18 PM
    #2378
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    You could make your own out of some Oil impregnated Bronze sheet or I can cut on the WaterJet if I have dims.
    .125 Might be a little thick for a wear washer.
    https://www.mcmaster.com/#8933k11/=18o9vjo
    Or this that is closer OD than what you bought. But carbon steel, Might be just enough to stay greased and take the noise out.
    http://www.superiorwasher.com/washer/515-2522/515-2522.html
  19. Jul 26, 2017 at 10:25 PM
    #2379
    Blackdawg
    Monte
    Wyoming/St. Louis
    Must be the super lube. I've never had squeaks with moly grease.
    SilverGhost likes this.
  20. Jul 27, 2017 at 7:25 AM
    #2380
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Spit on it.
    fiziks and BYJOSHCOOK like this.
