Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Jan 13, 2018 at 5:52 PM
    #2721
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Stig, Gramps, Wishbone Runner and 2 others like this.
  2. Jan 13, 2018 at 6:23 PM
    #2722
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  3. Jan 13, 2018 at 6:47 PM
    #2723
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Need to get some hours behind the wheel, which won't happen for a while. Think I'm really going to enjoy the support, just not sure about the bolster in the front. Might get annoying when clutching.
    I'm still going to pull the interior to sound deaden and clean. Just wanted to get this mount done.
  4. Jan 13, 2018 at 7:36 PM
    #2724
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    He still has to clean all of his legos out of the truck before vacuuming. :D
    Gramps, TMFF, Deathbysnusnu and 2 others like this.
  5. Jan 13, 2018 at 8:23 PM
    #2725
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    What about the passenger side?
    What are you gonna tell all your ride along bitchez....?
    Gramps and teamhypoxia like this.
  6. Jan 14, 2018 at 5:55 AM
    #2726
    cynicalrider
    cynicalrider #NFG
    Jersey
    Hard to tell from the photo, but assuming it's a one and done type of positioning? No forward or back movement?
  7. Jan 14, 2018 at 7:43 AM
    #2727
    Squeaky Penguin
    Brett
    It's got a slider. Still have good access behind the seat.
  8. Jan 14, 2018 at 1:00 PM
    #2728
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ah I see it now, I was confused since you welded the bracket the slider mounts to to the old slides. :oops:
  9. Jan 17, 2018 at 2:50 PM
    #2729
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    For your in cab winch switch, did you just T into the in/out wires at the socket? Run the blue and the yellow to the output from the switch? Do I need anything run to the red or black?
  10. Jan 17, 2018 at 2:56 PM
    #2730
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    What!? Finally getting a winch? Haha
    I just took apart my controller and fed the wires inside. Not ideal though because it would still be nice to have the remote.
  11. Jan 17, 2018 at 2:58 PM
    #2731
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I did, been sitting in the garage for a few months, doing some major overhauls in the engine bay and bumper mounting, so throwing it on at the same time. And yeah, I want to have ability for both.
    jubei and Reh5108[QUOTED] like this.
  12. Jan 17, 2018 at 2:58 PM
    #2732
    Squeaky Penguin
    Brett
    Mine is T'd into the wires at the solenoid. Came like that from the previous owner.
    He did provide a wiring diagram of how it was done I'll post when I get home.
    Edit - my solenoid is under the hood, so one set of wires goes to the in-cab switch, and another to the plug in the bumper.
  13. Jan 17, 2018 at 3:04 PM
    #2733
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Cool, based on the above diagram, not sure why the relays are there, the solenoid trigger doesn't draw much power does it? Haven't actually opened it up to see if the realys are there, i'll take a look.
  14. Jan 17, 2018 at 3:20 PM
    #2734
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Relays are there, wiring diagram is correct, so I think just running the hots from the incab switch to yellow/blue should do it.
    Dalandser likes this.
  15. Jan 17, 2018 at 3:29 PM
    #2735
    Squeaky Penguin
    Brett
    I don't have any relays, but based on the wiring diagram, you should be correct. Just tie into the yellow and blue at the relay, plug, or wherever works best.
    My switch is also powered from the winch solenoid power so it can be turned on anytime. Don't know if that's the best setup, just how it was. There is a winch power switch I have to turn on in the cab before I can use the in/out switch.
  16. Jan 27, 2018 at 5:10 PM
    #2736
    Squeaky Penguin
    Brett
    Took it back to the scale are weighed the rear axle. Came out to 2,360 lbs. So getting the process started to get some Alcans.
    Welded in a Vibrant ultra quiet resonator. Huge improvement. It got rid of all the annoying ricey sounds.
    [​IMG]IMAG0449 by brettbjorgum, on Flickr
    Then started ripping apart the interior.
    [​IMG]IMAG0450 by brettbjorgum, on Flickr
    Cleaning and sound deadening to come.
  17. Jan 27, 2018 at 5:48 PM
    #2737
    cynicalrider
    cynicalrider #NFG
    Jersey
    :woot:! Gonna feel like a luxury automobile.
  18. Jan 27, 2018 at 6:58 PM
    #2738
    Squeaky Penguin
    Brett
    Hope so. Should be a huge improvement in comfort.
    Also happy that after this, welding up some limit straps, and tossing on the new Springs, that I'll be ready to go for the spring.
    jubei and Deathbysnusnu like this.
  19. Jan 27, 2018 at 7:08 PM
    #2739
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    You need a better sound system....
    Cleanest I've ever seen it. Looks good. :thumbsup:
    SilverGhost likes this.
  20. Jan 27, 2018 at 8:20 PM
    #2740
    Squeaky Penguin
    Brett
    I have a good sound system. By the time I made it loud enough to cover all the other noises than I really couldn't hear anything.
    :brianr:
    It'll just be super dirty again after the first trip, don't know why I bother.
    Also, who in here knows about HAM radio antennas and mounts? I'll be going that direction eventually, but thinking about drilling a hole in my roof and adding an antenna mount while it's super easy to pull the headliner and run the coax.
    jubei and Deathbysnusnu[QUOTED] like this.
