Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Mar 23, 2018 at 7:46 AM
    #2861
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Someone else mentioned the top plate spacer on top idea in the mid travel thread. I no enginerd, but I don't see that making a huge difference. :notsure: Maybe I should just do it right and tie the coil buckets togeather...
    Anyways, will weld it up this weekend regardless. Getting into wheeling here soon, so I need at least a temporary fix.
    jubei and SilverGhost like this.
  2. Mar 23, 2018 at 7:55 AM
    #2862
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Your a sharp fella. You’ll figure it out :thumbsup: later.
  3. Mar 23, 2018 at 8:11 AM
    #2863
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I know a fix!
    Cut out the stock towers and put in a new tower for a 10'' shock..add long travel. Go faster..break more shit.
    Repeat.
    SilverGhost, jubei and BYJOSHCOOK like this.
  4. Mar 23, 2018 at 8:15 AM
    #2864
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Definition of insanity right there
    Prayn4surf likes this.
  5. Mar 23, 2018 at 8:56 AM
    #2865
    Squeaky Penguin
    Brett
    Not going to go long travel. Happy with where the truck's at, pretty much at the end of this build. Little mods here and there, and some fixes along the way, but there's nothing major I could see doing to it in the foreseeable future.
    Even with where it's at now, I think I'll be chasing down stupid shit like this continuously. Don't need to be breaking any more than I already am. Need to double check on how the front crossmember I welded up last year is doing.
  6. Mar 23, 2018 at 9:02 AM
    #2866
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know you never will. That was the joke..haha
  7. Mar 23, 2018 at 12:13 PM
    #2867
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Is it possible that there is something about the ADS top hat that is contributing to this?
    [​IMG]IMAG0502 by brettbjorgum, on Flickr
  8. Mar 23, 2018 at 12:28 PM
    #2868
    Squeaky Penguin
    Brett
    Doubt it. They're pretty solid.
    It did occur to me, however, that when I added the spindle gussets two years ago, there was this issue:
    I did some clearancing, but it was mostly to the spindle gusset, but there was a little bit to the outside edge of the coil bucket.
    Speedytech7 likes this.
  9. Mar 23, 2018 at 12:33 PM
    #2869
    Blackdawg
    Monte
    Wyoming/St. Louis
    huh don't think I've ever seen that. TC gussets right?
  10. Mar 23, 2018 at 12:40 PM
    #2870
    Squeaky Penguin
    Brett
    Yes. TC.
    It was just the very front corner of the inside piece causing that problem, and only on the one side. Might have to do with how we welded it on, or something else being bent, who knows.
  11. Mar 23, 2018 at 1:51 PM
    #2871
    Blackdawg
    Monte
    Wyoming/St. Louis
    huh interesting.
  12. Mar 23, 2018 at 5:11 PM
    #2872
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Shit happens when you jump it. Just saying. Don't over think how it happen add some steel, beef it up and call it a day. Once you add a crossover tube you won't have to worry about it.
  13. Mar 23, 2018 at 5:20 PM
    #2873
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've got some dirt designs crossover top hats sitting in Wyoming. Was going to use them on frank but I don't think it'll work with the blower.
  14. Mar 23, 2018 at 5:35 PM
    #2874
    Squeaky Penguin
    Brett
    Yep. Definitely the cost of having fun.
    I'll take em if you're not going to use them.
    Anyways, can't really figure out what's going on here.
    [​IMG]IMAG0512 by brettbjorgum, on Flickr
    Hardly any room to weld around where the bolt and washer need to go, but I did put a little weld in the front and back. Will be keeping an eye on it.
  15. Mar 23, 2018 at 5:40 PM
    #2875
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Wow, that's bad. What a strange place to crack too, you'd think the coilover tophat would be supporting it there. How do the coilover tophats look?
    Digiratus likes this.
  16. Mar 23, 2018 at 5:44 PM
    #2876
    Blackdawg
    Monte
    Wyoming/St. Louis
    wow. Thats worse then I thought.
  17. Mar 23, 2018 at 6:44 PM
    #2877
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Dam man. Wish I was around to fix it for ya.
  18. Mar 23, 2018 at 7:17 PM
    #2878
    Squeaky Penguin
    Brett
    Doesn't make sense to me either.
    [​IMG]IMAG0511 by brettbjorgum, on Flickr
    Fine.
    Yeah, so you going to sell me those top hats?
    We'll see how my half-ass fixing holds up.
    Also super annoying working in there. Couldn't hardly get in there with the welding helmet.
    SilverGhost[QUOTED] likes this.
  19. Mar 24, 2018 at 8:37 AM
    #2879
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Is there any chance you are bottoming out the coil over and the shock of the sudden pressure is causing that to crack? Bumps set too high?
  20. Mar 24, 2018 at 8:58 AM
    #2880
    Squeaky Penguin
    Brett
    It's conceivable, but I don't think that's what's happening.
    I've never had a chance to cycle the front coilovers without the coils, but based on what I see on the shock shaft, I'm not bottoming them out. Heading to @TMFF in a couple weeks to get them rebuilt, so I'll see if I can cycle one after we pull the coil.
