Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Mar 24, 2018 at 8:58 AM
    #2881
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I might. Let me message Steve to see if the type I have will fit with the blower. He makes 2 styles for 1st gens and one will clear the blower.
    If i have the wrong ones, I'll sell them to you.
    You'd think the shock would show signs of failure if he was bottoming out the shock that bad..
  2. Mar 24, 2018 at 9:18 AM
    #2882
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Shocks and coilovers aren't particularly dainty though (most on TW seem to think they're made of glass), everyone I've talked to has said you'll break truck parts before you break the coilovers themselves.
    Reh5108 likes this.
  3. Mar 24, 2018 at 9:21 AM
    #2883
    Blackdawg
    Monte
    Wyoming/St. Louis
    you'd fuck up seals and shit though. It would show signs of leaking at least.
  4. Mar 24, 2018 at 5:10 PM
    #2884
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
  5. Mar 24, 2018 at 5:17 PM
    #2885
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Where is this at?
  6. Mar 24, 2018 at 5:23 PM
    #2886
    Squeaky Penguin
    Brett
    By the front core support/body mount.
    Reh5108[QUOTED] likes this.
  7. Mar 24, 2018 at 7:25 PM
    #2887
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    OH that explains a lot. Stop sending it! Check your motor mounts too. Make sure they are not bowing. For some reason that spot likes to bend inward on me too. But that's when my shocks where really stiff.
  8. Mar 24, 2018 at 7:38 PM
    #2888
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Can do!!!!
    Core support: Mine cracked at the same spot years ago plus many others on both sides. Thin sheet metal doesn't like to be used and abused. Weld that MF'er and send it!!!!
    Coil bucket: text me dimensions and I'll get some .25 or .375 steel cut for you. I need ID, OD, 3 Bolt circle. A nice overlay plate will keep the bucket together for a few more years.
    Speedytech7, Cid, SilverGhost and 2 others like this.
  9. Mar 24, 2018 at 7:45 PM
    #2889
    Squeaky Penguin
    Brett
    But sending it is fun!
    I'll check the motor mounts too. :thumbsup:
    Awesome! I'll get those measurements and text you tomorrow.
    SilverGhost[QUOTED] likes this.
  10. Mar 24, 2018 at 7:49 PM
    #2890
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I bet your motor mounts are as fucked as mine were many years ago. Build or buy some semi solid ones and Send it!
    I used some leaf spring bushings and some 4130 1.75 tubing and plate I had laying around to make my solid engine mounts.
  11. Mar 24, 2018 at 8:02 PM
    #2891
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    That's something to consider. If your motor mount are half way decent you can always box them in. A lot of LT guys just box them in. But if they are beat to shit do what Tim suggest and build new ones that are thicker. Plus the inner part of the frame of the motor mounts might be bent in if your motor mounts are bent so look for that too.
  12. Mar 25, 2018 at 7:57 AM
    #2892
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Your not going hard enough in your #bestgen if your frame hasn't caved in under the driver side frame perch.
    Circa December 2011 for me. A ton of 3/16 4130 patched it back up! I also had another on-lay plate going up the coil bucket.
  13. Mar 25, 2018 at 8:02 AM
    #2893
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    It's a bitch but worth it...
    I agree, but these aren't billsteins either... high quality shocks can take some serious abuse and cause other problems without damage to themselves first
  14. Mar 25, 2018 at 8:46 AM
    #2894
    Squeaky Penguin
    Brett
    Couldn't really get that great a look at the drivers side mount, but it looks fine.
    Here's the passenger side. :notsure:
    [​IMG]IMAG0519 by brettbjorgum, on Flickr
  15. Mar 25, 2018 at 12:43 PM
    #2895
    Blackdawg
    Monte
    Wyoming/St. Louis
    We are doing a group buy with bozen on his motor mounts if you want in. Not cheap but beef.
    I'd replace them no matter what with the mileage you have and the way you use the truck there is no way the rubber is going to be in good shape anymore.
    The trail gear bomb proof mounts are okay too but raise the motor up about an inch makes for a bitch to install. 4xi novation makes a nice tranny mount to go with it.
  16. Mar 25, 2018 at 1:40 PM
    #2896
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Cool, not to bad. That metal is thin. Consider beefing up the perches. Not a dier need but easier to get it now then when they do bend.
  17. Mar 25, 2018 at 3:06 PM
    #2897
    Speedytech7
    Could I tempt you to make another set perhaps. I'd like to avoid this issue and my Icons have a top hat design I could imagine doing damage like this over time.
  18. Apr 1, 2018 at 8:03 PM
    #2898
    Squeaky Penguin
    Brett
    First trip of the season was successful. It'll be the last trip with the topper. Few quirks to work out, but overall happy with how everything is working.
    More to come.
  19. Apr 1, 2018 at 10:00 PM
    #2899
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Utah?
    Or Colorado...
    when is your GFC gonna be ready?
  20. Apr 2, 2018 at 6:24 AM
    #2900
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Utah
    Deathbysnusnu[QUOTED] likes this.
