Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Apr 2, 2018 at 7:05 AM
    #2901
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Couple weeks by the sound of it. I'm expecting a more accurate date here shortly as they get in touch to sort out colors and options.
    Deathbysnusnu[QUOTED] and jubei like this.
  2. Apr 3, 2018 at 5:28 PM
    #2902
    Squeaky Penguin
    Brett
    Finally trying to track down a nasty vibe at highway speed. One of the last things I need to address.
    Found my slip joint has all sorts of play. You can rotate it a degree or two and move it side to side. Picking up a new used driveshaft this weekend. Also has a small dent and have hit it several other times, you can see it at idle in 1st gear.
    https://youtu.be/yafIhkFvkjw
    Also found a have a bent axle shaft. :annoyed:
    https://youtu.be/eD1pK7EuJrs
    Dalandser likes this.
  3. Apr 3, 2018 at 6:25 PM
    #2903
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Is that the driver side? How much runout is there?
  4. Apr 3, 2018 at 7:07 PM
    #2904
    cynicalrider
    cynicalrider #NFG
    Jersey
    Look at @jubei its not just you now. :p
  5. Apr 3, 2018 at 7:12 PM
    #2905
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Dude.... can u not break stuff???
  6. Apr 3, 2018 at 7:31 PM
    #2906
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    :rofl:
    Brett probably bent his doing some epic @SilverGhost shit, though! I still don’t be know how the hell I did it on my truck :rolleyes:
    SilverGhost likes this.
  7. Apr 3, 2018 at 8:20 PM
    #2907
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Mine is bent too.
    9'' time?
  8. Apr 3, 2018 at 8:44 PM
    #2908
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Chicks dig bent axle shafts tho.
    BYJOSHCOOK, jubei, Prayn4surf and 2 others like this.
  9. Apr 3, 2018 at 9:33 PM
    #2909
    Squeaky Penguin
    Brett
    Yes. I figured that weeble wobble you pointed out at RT had to do with the broken leaf spring and the axle sitting crooked.
    Didn't measure the runout. That's a horrible freight gauge so I just used it to get a rough idea.
    Squeaky Penguin's 'What's broke this time' build?
    Trying to figure out where it might have happened, but not sure. Jumping certainly didn't help.
    Looking into my options, but a new axle isn't in the cards right now.
  10. Apr 3, 2018 at 9:51 PM
    #2910
    Squeaky Penguin
    Brett
    @jubei what did you determine on axle shafts? The Trail Gear ones clearly will not work with the elocker ABS housing. Looks like Yukon will be my best bet.
    jubei likes this.
  11. Apr 3, 2018 at 9:53 PM
    #2911
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I might ask @Matic
    Matic likes this.
  12. Apr 3, 2018 at 10:22 PM
    #2912
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Correct. The trail Gear chromoly shafts will not work with abs.
    Theres a guy selling some yukon shafts but I would suspect they are they same as the TG shafts.
  13. Apr 3, 2018 at 10:25 PM
    #2913
    Blackdawg
    Monte
    Wyoming/St. Louis
    Huh wonder why they won't work with ABS housings.
  14. Apr 3, 2018 at 10:27 PM
    #2914
    Matic
    Tricky Dick
    Easley, SC
    Something about that flange and tone ring.
    I cant understand for the life of me why my 02 has a non abs housing. Its a wierd fuck.
  15. Apr 3, 2018 at 10:37 PM
    #2915
    Blackdawg
    Monte
    Wyoming/St. Louis
  16. Apr 3, 2018 at 10:42 PM
    #2916
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  17. Apr 3, 2018 at 10:43 PM
    #2917
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah, phone call could clarify that.
    Plus. I don't care, I'll put mine in a t100 axle haha
  18. Apr 4, 2018 at 5:39 AM
    #2918
    jubei
    NoCo
    Stuff. Also things.
  19. Apr 4, 2018 at 8:00 AM
    #2919
    Squeaky Penguin
    Brett
    Yukon shafts ordered.
    New OEM wheel bearings ordered. Feels like I just replaced those.
    Headed back to Utah next weekend and I'm determined to get everything together and hopefully rolling without vibes before then.
  20. Apr 4, 2018 at 9:19 AM
    #2920
    jubei
    NoCo
    Stuff. Also things.
    Kick ass!
    Did you end up getting the ones from LROR? Sounds like you got both sides.
