Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Nov 2, 2018 at 2:39 PM
    #3221
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Probably be cheaper to sell my coilovers and buy new ones. :notsure:
    Still:
    LT kit
    might at well get heimed uppers so I can align it
    axles
    fenders
    loose the dorkel :(
    etc. etc.
    break my truck doing even more stupid shit than I do now
    eventually want to do the rear...
    :spending:
    TMFF[QUOTED] and jubei like this.
  2. Nov 2, 2018 at 2:42 PM
    #3222
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Don’t forget the crawl box!
  3. Nov 2, 2018 at 2:49 PM
    #3223
    Squeaky Penguin
    Brett
    That was a given...
    ...along with the turbo.
    TMFF and jubei[QUOTED] like this.
  4. Nov 2, 2018 at 3:38 PM
    #3224
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    There is never an end to a build... But when you get to that point put a cage and 35's and compete in the stock class in Ultra 4.
  5. Nov 2, 2018 at 7:29 PM
    #3225
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    can't do a shock tower brace with a snail in the way. Do a blower, more reliable anyways.
    You could figure out how to keep the snorkel. Just need to cut up a new fender.
    It is worth the trouble. I freaking love it.
  6. Nov 4, 2018 at 8:48 AM
    #3226
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Actually I am driving the GX a lot faster. That damn V8. :D
  7. Nov 5, 2018 at 10:23 AM
    #3227
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    How does the wheelers bumpstops work with the 4" lift. I have 3.5" on my rear with Alcans and i feel like they might not be enough to actually work.
  8. Nov 5, 2018 at 10:32 AM
    #3228
    Squeaky Penguin
    Brett
    I welded up my own mounts to work for my application. They work perfect.
    I think the mounts wheelers sells are too short for most applications.
    Reh5108 and Dan8906[QUOTED] like this.
  9. Nov 5, 2018 at 10:35 AM
    #3229
    Dan8906
    Daniel
    Concord, California
    I was looking at the toyotabumpstop.com 5.25" bumps. do you have pictures of yours? what was your overall height?
  10. Nov 5, 2018 at 10:50 AM
    #3230
    Reh5108
    Idaho
    Measure your remaining shock travel and measure the distance from the shoulder of the bump to the strike plate. Also double check that the bump will hit the strike plate. My factory one was too far forward so I cut it off and made my own.
  11. Nov 5, 2018 at 10:52 AM
    #3231
    Squeaky Penguin
    Brett
    I don't recall the measurement. Here's a pic.
    The 5.25" bumps would still be too short for me, but keep in mind bump height also depends on shock setup.
    Half-ass way without cycling - go measure the distance between your leafs/flip plate and you bump stop pad. Compare that distance to your remaining shock shaft. Hard part is accounting for how much the bumps compress.
    jubei and Reh5108 like this.
  12. Nov 5, 2018 at 10:52 AM
    #3232
    Squeaky Penguin
    Brett
    Beat me by a minute.
    I also offset my bumps forward so they hit the pad.
    Reh5108[QUOTED] likes this.
  13. Nov 7, 2018 at 10:51 AM
    #3233
    jubei
    NoCo
    Stuff. Also things.
    Hey Brett, do you recall what lengths you ended up using for your front and rear limit straps?
    I’m about to dive in to a bunch of front suspension work and I’d like to add the straps while I’m in there.
    Thanks.
  14. Nov 7, 2018 at 11:00 AM
    #3234
    Phessor
    Phessor Well-Known Member
    Where did you get your hood decal? I need to paint mine or a really big decal to cover up the faded paint.
  15. Nov 7, 2018 at 11:16 AM
    #3235
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Phessor[QUOTED] likes this.
  16. Nov 7, 2018 at 11:20 AM
    #3236
    Squeaky Penguin
    Brett
    8" in front 16" in back.
    In hindsight, not sure if I would have messed with the rear straps. They were a pain to fit with the ebrake cable and everything else going on. They also are only used when the entire axle droops out, and I'm not sure how often that happens. They aren't needed for flexing as the bind caused by the leaf pack twisting stops the downtravel first.
    Can't hurt though. :notsure:
    jubei[QUOTED] likes this.
  17. Nov 9, 2018 at 10:53 PM
    #3237
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    I probably sound dumb, but why do you need limit straps...?
  18. Nov 10, 2018 at 8:27 AM
    #3238
    Squeaky Penguin
    Brett
    Don't necessarily need them, but they prevent the shocks from topping out.
    Without them, your shock is what limits downtravel, and when you start driving faster, you end up topping out your shocks very frequently. Especially true with the front ifs setup. It's cheap insurance to put that force of the shock unloading onto a strap instead of your expensive shocks. Also prevents a loud clunk when they top out suddenly.
    Gramps and jubei like this.
  19. Nov 11, 2018 at 9:46 PM
    #3239
    NcTaco27
    Brenton
    East Tennessee
    ok I got yah now, makes more sense.
  20. Nov 26, 2018 at 12:17 PM
    #3240
    Squeaky Penguin
    Brett
    Reference material? ;) I just dive into most all my projects.
    Loosen the belt, the high pressure line is a banjo bolt, the low pressure line has a spring clamp, and then there's like 2 mounting bolts. Should take you 30 minutes to remove the pump.
    If all your doing is cleaning the reservoir, you don't have to pull the pump. There's two bolts that hold it on, one on the front and one on the back, pull the low pressure line, and it pulls out.
    jubei likes this.
