Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Nov 30, 2018 at 8:25 AM
    #3261
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I was thinking that you’re probably running into the same thing, Mike.
    I think I’m going to form up some kydex sheet like Monte mentioned and double sided tape it to the top of the winch. Seems like it should work. If you design something for 3D printing, let me know!
  2. Nov 30, 2018 at 9:33 AM
    #3262
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    For what it's worth I rarely remove my cover completely. I just pull it off enough to reach the lever. Wouldnt be difficult to cut a hole for it either.
    Tacofire98 and jubei like this.
  3. Nov 30, 2018 at 11:32 AM
    #3263
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Never thought of that. Just cut a hole for the lever and the control plug. Might have to do that.
  4. Nov 30, 2018 at 12:11 PM
    #3264
    cynicalrider
    cynicalrider #NFG
    Jersey
    The only thing I would worry with any sort of cover is not having a quick view of how many wraps I have left on the drum. Ideally I would want to paint/mark the line some how when I am at the danger zone, wrap wise so it would be a non issue.
    jubei likes this.
  5. Nov 30, 2018 at 2:36 PM
    #3265
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Thats an easy fix.
    Put a piece of ducktape or Gafftape where you want to stop. Just wrap the cable with it.
    Its actually a recommended thing to do to winch line.
    No different that being in a plate bumper and the only way to look is through the fairlead. Could always do that too.
    Reh5108, Deathbysnusnu and jubei like this.
  6. Nov 30, 2018 at 3:08 PM
    #3266
    jubei
    NoCo
    Stuff. Also things.
    This is exactly what I was thinking of doing. Simple and easy.
  7. Dec 3, 2018 at 1:11 PM
    #3267
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Who knows about motor mount perches? @TMFF
    Have some TG engine mounts coming, along with a 4x trans mount, and think I should address the perches while I'm at it before I break them doing what I'm doing.
    Are DMZ perches the best option? Any way to weld those up aside from pulling the engine? :bananadead: I was thinking about putting in a nicer clutch anyways....
  8. Dec 3, 2018 at 1:23 PM
    #3268
    Blackdawg
    Monte
    Wyoming/St. Louis
    Can't do the DMZs without pulling the motor.
    That said, since you're just doing the TG ones Id just guesset the stock ones as you can do that with the motor still in. Not fun but should be doable.
    Otherwise, sell the TG ones when you get them. Buy Bozen's mounts, then do DMZs perches. That's my plan. Have the mounts. WAY better than the TG ones.
  9. Dec 3, 2018 at 1:35 PM
    #3269
    Squeaky Penguin
    Brett
    What's wrong with the TG mounts? And what exactly are you gusseting on the stock perches?
    Looks like the only benefit of the Bonzen ones is they replace the bracket that goes to the engine, but I've not heard of that presenting a problem. For the price I'm not sure it's worth it, so what makes the "WAY better"?
  10. Dec 3, 2018 at 1:53 PM
    #3270
    Blackdawg
    Monte
    Wyoming/St. Louis
    Depending on the mounts they can fail. Yours are likely just the stamped metal ones. I wouldn't put it past you to break them after beefing up the other parts. So yeah, replaces the entire mount, win for me. I got the tranny mount to match but I don't think that is really that much better than the 4xi one.
    Check out JDs build. From what I've seen you box the perch and if you can(really have to pull the motor at this point though) plate the sides and top. JD i believe just boxed his though. Doesn't help the actually mounting surface sadly.
  11. Dec 3, 2018 at 1:56 PM
    #3271
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Can you "kinda" pull the motor?
    Like drop the trans, unbolt the motor mounts, and lift the motor like 2 inches?
  12. Dec 3, 2018 at 4:26 PM
    #3272
    Squeaky Penguin
    Brett
    Not sure. I think the front diff would also have to be pulled for that to work.
  13. Dec 3, 2018 at 7:43 PM
    #3273
    Reh5108
    Idaho
    Might as well pull the oil pan and weld an oil return bung in for a turbo while the diff is out...
    m3bassman likes this.
  14. Dec 3, 2018 at 7:45 PM
    #3274
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ooo we turboing Brett's rig while we are at it?
    I approve of this stupid idea as much as the long travel one!!
  15. Dec 3, 2018 at 8:03 PM
    #3275
    Reh5108
    Idaho
    Everything needs a turbo, it's a fact of life
  16. Dec 3, 2018 at 8:13 PM
    #3276
    Squeaky Penguin
    Brett
    I like your thinking.
    And I like turbos.
    But this thing will stay NA. I want it to be as reliable as possible to get me to where I want to go.
    Reh5108[QUOTED] likes this.
  17. Dec 3, 2018 at 8:35 PM
    #3277
    Blackdawg
    Monte
    Wyoming/St. Louis
    Truer words haven't never been spoken
  18. Dec 4, 2018 at 8:06 AM
    #3278
    Reh5108
    Idaho
    I do worry about effecting reliability when I put mine on.
  19. Dec 4, 2018 at 8:19 AM
    #3279
    Blackdawg
    Monte
    Wyoming/St. Louis
    you should be..
  20. Dec 4, 2018 at 8:38 AM
    #3280
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I built my own mounts to replace the vulcanized OEM stuff many moons ago, similar to the Bonzen mounts. I had some frame perch repair at that time that I did with everything in place, huge PITA! A few years later the frame failed around the driver side engine mount and I pulled the front Diff to plate in with some 4130 3/16 plate that went from the cab to the radiator and 1/2 way up the coil bucket. I might have pics somewhere but that was.... 7-8 years ago?
    I would definitely replace and beef cake everything between the engine and frame, The motor doesn't have to come out to do so but will make it easier.
    I don't know what your all talking about with reliability and boost, My 150K stock engine LOVES 11-12psi at 5500ft. It's been supercharged with a 2.1, now 2.0, pulley for 80K. Now that I ditched URD for AEM and spent some time to dial on the fuel trims and fuel/ign maps it sucks gas and hauls ass!!!
