Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Jul 31, 2019 at 8:45 AM
    #3841
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    It could work. Or have the shackle mount go through the frame. You would probably also want to adjust it forward to get the proper shackle angle.
    You would also be shifting up the travel in relation to the frame. Not any real issue, but you would get less likes on your IG post as it would look like you have less droop.
    Also, are you prepared to move those shock mounts?
    Tim last weekend: "If I were to do it again, I would have just left it stock." :luvya:
    w.adventures and TMFF[QUOTED] like this.
  2. Jul 31, 2019 at 8:50 AM
    #3842
    cynicalrider
    cynicalrider #NFG
    Jersey
    Still seems like you are bumping the truck early by inflating them, and not fully taking advantage of the uptravel regardless the way I always have been looking at it.
    The lowers? Yeah of course. That's easy enough with some cutting and grinding. I don't care about the gram likes, I want a truck that fully takes advantage of my suspension. So if I need to redo bump height and the lower mounts I can technically do all of that with the bed still on the frame. The harder shit is already done with boxing the frame and the upper mounts. I honestly expected this setup to be V1 and not 100% perfect first go around.
  3. Jul 31, 2019 at 9:29 AM
    #3843
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I did say that, and still stand by it.
    But I'm years into my SC development and enjoy the power and whiny noises to much to go back to stock. Plus my cost of admission was 1/4 of what a SC kit goes for now and that included the fuel upgrade kit.
    w.adventures likes this.
  4. Jul 31, 2019 at 9:54 AM
    #3844
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Thats how I used to think of it too. But really your changing the spring rate. it does become progressive but with the right bags and if you use your pressures right, it works fine. It would changing the handling and you'd want shocks that are adjustable to cope with it. Not a simple solution really.
  5. Jul 31, 2019 at 12:07 PM
    #3845
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I have my airbags set up so that I don’t bump early or loose any down travel. The system works very well and gives the truck a versatility that no production parts could. The airbags do require more compression valving, so comp adjusters are a must. I planned on getting comp adjusters regardless, so that wasn’t a big deal for me.
  6. Jul 31, 2019 at 12:08 PM
    #3846
    austinmtb
    Austin
    Southern Oregon
    It is progressive, however the carli bags have so much volume that it’s not as noticeable as a normal airbag.
  7. Jul 31, 2019 at 12:16 PM
    #3847
    cynicalrider
    cynicalrider #NFG
    Jersey
    Sorry for the thread jack @Squeaky Penguin, thank's for the info on your leafs! Thank you @austinmtb for the info on your bags! If I need more airbag info I'll tag ya'll in my build. :cheers:
    jubei and austinmtb like this.
  8. Jul 31, 2019 at 12:29 PM
    #3848
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    @TMFF since I didn’t go with adjusters how should I valve my Kings when it’s time for a rebuild where it’s a good compromise for driving unloaded and when loaded up for #overlanding activities with the airbags inflated.
  9. Jul 31, 2019 at 12:50 PM
    #3849
    austinmtb
    Austin
    Southern Oregon
    Could always add adjusters when it’s time for a rebuild.
    w.adventures[QUOTED] likes this.
  10. Jul 31, 2019 at 4:13 PM
    #3850
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    it's about $150 in parts to add per shock.
    @w.adventures Don't over think it on your short bus, the current shim stacks are probably at the loaded/unloaded compromise.
  11. Jul 31, 2019 at 6:08 PM
    #3851
    w.adventures
    Nowheresville, SC
    Awesome thanks, going to save my money and spend it on other stuff I don’t need for the short bus. We shall see how it handles next week when it’s all loaded up.
    TMFF[QUOTED] likes this.
  12. Aug 9, 2019 at 7:07 AM
    #3852
    cynicalrider
    cynicalrider #NFG
    Jersey
    Are you happy with your spring rate Brett? It seems like you have the spring preloaded a bit, but I am assuming the valving got adjusted to compensate. What rate are you running currently?
  13. Aug 12, 2019 at 4:47 PM
    #3853
    Squeaky Penguin
    Brett
    Put a little under 2,000 miles on the truck last week to double my sticker collection and watch @Reh5108 outfish me in jorts. :cookiemonster:
    [​IMG]IMG_1950-2 by Brett Bjorgum, on Flickr
    [​IMG]IMG_20190811_092336 by Brett Bjorgum, on Flickr
    Engine's running perfectly. :notsure: Might send it a little longer.
    More to come.
    They're 650s. I just cranked them several turns more earlier this year, and think I went a little too much. Not quite enough downtravel. I know a shock guy, and he says no go to 700s on a 1st gen due to the leverage ratio. Valving is key. I think a lot of people are upping their spring rates to compensate for shitty valving. Speaking of which, my truck is riding so good right now, huge thanks to @TMFF and his magical valve stacks. Those ADS' were valved like garbage from the factory.
  14. Aug 13, 2019 at 5:23 AM
    #3854
    cynicalrider
    cynicalrider #NFG
    Jersey
    Good to know about the 650’s and the valving. I was going to send Tyler photos of your hose setup since I feel it’s the best location to protect the resi’s. I don’t have anyone local as far as I know who can valve shocks though. @TMFF is there anything I can tell ADS to adjust from the jump for a similar setup to Brett’s? We are weighted similarly except I have a tube bumper instead of plate, though my crossmember built out of mostly 1/4” probably gets us close.
  15. Aug 13, 2019 at 6:05 AM
    #3855
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i miss that spot...
  16. Aug 13, 2019 at 7:58 AM
    #3856
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. Unless your truck is setup just like Brett's. My ads shocks from Matt are valved pretty good. But if I had a winch...hell no. Or heavier skid. I'm right on the edge if them getting floaty.
  17. Aug 13, 2019 at 8:03 AM
    #3857
    cynicalrider
    cynicalrider #NFG
    Jersey
    Front end wise we are similar. 3.4 V6 Manuals, bunch of gusseted parts, both running synthetic winches, and heavy IFS skids. Only difference is an all pro plate vs an Addicted Offroad tube, which like I said I built a beefy 1/4" crossmember which adds quite a bit of extra weight to the tube setup. Our rear ends are completely different, yes, but front ends we are pretty damn close.
  18. Aug 13, 2019 at 8:06 AM
    #3858
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Spotted Brett's media guy back in action! Just look at the commitment from this guy! He's not afraid to get down and dirty for the shot. Rumor has it that he's seeking to photograph other "influencers". Act fast before his schedule is booked!IMG_20190809_125455.jpg
  19. Aug 13, 2019 at 8:07 AM
    #3859
    Reh5108
    Idaho
    Do you have the weight of your front axle? Could compare it to Brett's number.
  20. Aug 13, 2019 at 8:09 AM
    #3860
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Have them bump the compression to a Flutter 12 or 15, that would be a decent start. From what I have seen the piston's flow well and they run to light of comp shims to make them ride soft for the 90% that barely goes offroad.
