Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Nov 7, 2019 at 11:14 AM
    #4201
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Oh my offer was on me for testing them and posting pics for other 1st geners to check out
    Wishbone Runner likes this.
  2. Nov 7, 2019 at 11:15 AM
    #4202
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I set my shock at full extension then made the bump to protect them from full compression. I still had to extend the wheelers bumps a bit. Can't remember how much.
    ARCHIVE[QUOTED] likes this.
  3. Nov 7, 2019 at 12:40 PM
    #4203
    cynicalrider
    cynicalrider #NFG
    Jersey
    I think I need to shorten mine. After some real world use I put zip ties on the shocks to see how much actual shock travel I am using by seeing where the zip tie ends up. Currently I see the zip tie resting on the rubber shock bump on the drivers side and about a 1/2” from hitting the rubber bump on the passenger side. My biggest fear has been bottoming the shock out but I think I’d like to remove 1/2” from the left side bump stop and 1” from the right side bump stop. Going negative is less of a concern for me.
    Reh5108[QUOTED] and ARCHIVE like this.
  4. Nov 7, 2019 at 12:45 PM
    #4204
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Is that with flexing, or hard bottom outs?
    You'll never use all the travel if all you're doing is flexing (and shocks were setup properly).
    Reh5108 and ARCHIVE like this.
  5. Nov 7, 2019 at 12:56 PM
    #4205
    cynicalrider
    cynicalrider #NFG
    Jersey
    Both, it was for the entire trip of 4 days in NH. Bombing rocky roads, flexing, etc. And since I was basically almost on my bumps the entire time because my pack can't handle my weight, it was a pretty good test as far as I could tell anyway.
  6. Nov 7, 2019 at 2:51 PM
    #4206
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    What spring rate are you using on your coilovers?
  7. Nov 7, 2019 at 5:17 PM
    #4207
    Reh5108
    Idaho
    I haven't compressed mine all the way yet either. I'm waiting until the truck see air and completely bottoms out both springs before I make any adjustments.
  8. Nov 7, 2019 at 5:20 PM
    #4208
    Squeaky Penguin
    Brett
    Well in that case, and given you don't care about negative arch - shorten the bump stops.
    650
    I wouldn't go to 700s on a 1st gen.
  9. Nov 7, 2019 at 9:09 PM
    #4209
    Dan8906
    Daniel
    Concord, California
    Yeah I fucked up and went 700 haha I’m ready to swap it out for a 650
  10. Nov 7, 2019 at 9:12 PM
    #4210
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    unless your rig weighs a metric shit ton 650s are plenty.
  11. Nov 7, 2019 at 9:15 PM
    #4211
    Dan8906
    Daniel
    Concord, California
    Yeah, I’m trying to find someone local that will trade before I buy another set. But haven’t had any luck yet
  12. Nov 8, 2019 at 11:53 AM
    #4212
    Oside7even6ixty
    Oside7even6ixty Well-Known Member
    650’s are good
    Dan8906 likes this.
  13. Nov 8, 2019 at 12:05 PM
    #4213
    Reh5108
    Idaho
    Idk how I'm getting buy with my 882s with a 500lb spring rate :rofl:
    m3bassman likes this.
  14. Nov 14, 2019 at 7:48 AM
    #4214
    Squeaky Penguin
    Brett
    When I weighed mine it was 2,500lbs front axle and 2,360 rear.
  15. Nov 14, 2019 at 10:58 AM
    #4215
    Blackdawg
    Monte
    Wyoming/St. Louis
    How were you so heavy up front? Did you add a front skid recently??
    And yeah there is likely some over lap. Not sure what that would be exactly honestly. If you're actually at 2700 front Id want 650s though. Do your icons have 600s now? Hows your preload look?
  16. Nov 14, 2019 at 1:34 PM
    #4216
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  17. Nov 14, 2019 at 1:40 PM
    #4217
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    You photoshopped the Parachute out right? :D
    Man, I have dangled out of a helicopter at 14,000ft but I was harnessed in.
  18. Nov 14, 2019 at 2:31 PM
    #4218
    Squeaky Penguin
    Brett
    That's it! :cheers:
    Good thing I had my safety sandals on. :rofl:
    That was sketchy - not recommended.
  19. Nov 14, 2019 at 3:06 PM
    #4219
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    A little breeze would have blown your toothpick self right over the edge.
    w.adventures likes this.
  20. Nov 14, 2019 at 3:11 PM
    #4220
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I forgot about the rock bench!
