Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. May 11, 2020 at 12:13 PM
    #4541
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    He had a few on his gram post but not nearly enough.
  2. May 11, 2020 at 12:28 PM
    #4542
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Is that a charcuterie plate!?
  3. May 11, 2020 at 12:29 PM
    #4543
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Staged you say? I bet Leo snuck up on you and took that picture.
  4. May 11, 2020 at 12:43 PM
    #4544
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I would never drop a skid plate 1'' lower for reinforcement. You're eating away your ground clearance, its just not needed.
    If you wheel hard enough, skids just need replaced every now and then. Sucks, but even 1/4'' is gonna bend.
  5. May 11, 2020 at 1:22 PM
    #4545
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    yeah your probably right.
  6. May 11, 2020 at 1:53 PM
    #4546
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Nope I was taking pictures of people taking pictures.
  7. May 11, 2020 at 1:57 PM
    #4547
    w.adventures
    Nowheresville, SC
    Now that’s the Instagram way!
  8. May 11, 2020 at 2:04 PM
    #4548
    Reh5108
    Idaho
    Brett can't even escape the paparazzi out in the middle of nowhere. That overland life is real.
  9. May 11, 2020 at 2:24 PM
    #4549
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah... you're doing it right. :101010:
  10. May 11, 2020 at 5:15 PM
    #4550
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I haven't had AP skids in years. Make your own. Don't lower them. You can add gussets in strategic locations and make them way stronger the the AP skids and not loose clearance.
    Hey man, it was my first time. I'm trying.
    Yeah buddy! Only the fanciest for us overlanders. :rofl:
  11. May 11, 2020 at 5:23 PM
    #4551
    Squeaky Penguin
    Brett
    OK - actual truck stuff.
    -I have a nasty vibe above 70mph. Guessing driveshaft related. Going to replace the carrier bearing, check my ujoints, and maybe swap in my spare rear half.
    -Cruise doesn't work. Need to look into that.
    -And the bed mounts I tried to fix completely imploded. Going to need to pull the bed and attempt to fix it properly. :annoyed:
    Maybe I should get one of these instead.
    Madjik_Man and TMFF like this.
  12. May 11, 2020 at 5:27 PM
    #4552
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  13. May 11, 2020 at 5:30 PM
    #4553
    Blackdawg
    Monte
    Wyoming/St. Louis
    Easy test to see if it fixed the cruise. Lift the pedal all the way up. Might not be contacting the clutch cancel switch.
  14. May 11, 2020 at 6:51 PM
    #4554
    Night Eagle
    Leo
    2014 TDR Off Road
    He did that during the trip and that didnt seem to be the problem.
    Squeaky Penguin[OP] likes this.
  15. May 11, 2020 at 7:43 PM
    #4555
    Reh5108
    Idaho
    Did your welds fail or the rivets?
  16. May 12, 2020 at 4:45 AM
    #4556
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    Im diggin the GCI chair, wish mine had kings! :D
  17. May 12, 2020 at 7:16 AM
    #4557
    Squeaky Penguin
    Brett
    Mainly it's just cracking everywhere and collapsing now. Front of the bed is like 1/4" lower than the cab. I think at least one of the welds failed. Rivets seem to be holding, but didn't check the passenger side.
    I have a plan to hopefully fix it, just not looking forward to pulling the camper and bed off.
    I love that chair! Camp rocking chair FTW.
    Reh5108[QUOTED] and w.adventures like this.
  18. May 12, 2020 at 7:18 AM
    #4558
    w.adventures
    Nowheresville, SC
    Second this. Camp rocking chair is amazing.
  19. May 12, 2020 at 8:30 AM
    #4559
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Well this thread has officially jumped the shark....unsubbed :luvya:
  20. May 12, 2020 at 9:14 AM
    #4560
    w.adventures
    Nowheresville, SC
    Yep, there will be thousands of instagrammers in this thread shortly.
    slander and Bandido like this.
