Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Feb 14, 2015 at 4:39 PM
    #521
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Collecting quite the pile of parts. Got my Energy Suspension LCA and UCA bushings in, to add to the upper and lower ball joints, and front shocks. Also, got some shock tabs from Ruff Stuff for the relocation, along with a crossmember mounting kit to begin fabricating my belly skid. I'm probably going to make one long skid that goes from the IFS skid to the new rear crossmemeber to replace my banana shaped All-Pro transmission skid.
    Also, headed to a pick and pull today and picked up some leaves to begin modifying my current pack:
    They came out of a '91 S-10. We'll see what ends up working, but hoping to get 1.5-2" more lift than I currently have. Truck is sitting pretty level right now. So, with swapping back to stock shackles going to have to get 3"+ more lift out of my packs. Hopefully I can make it work.
  2. Feb 14, 2015 at 5:11 PM
    #522
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    your going to hate the energy lca bushings. they require you to reuse the inner sleeve AND the outer sleeve from the oe bushings. worst design ever, i tried , gave up in an hour. if you some how miraculously get the bushings out of the arms in one piece, you then have to cut or melt the rubber out and reuse the 2 sleeves. i got my whitelines on Amazon.....
  3. Feb 14, 2015 at 7:15 PM
    #523
    Squeaky Penguin
    Brett
    Timmy didn't seems to have a problem. :notsure:
    Hoping the outer sleeve comes out when using the bottle jack, and I'm prepared to light them on fire. Whiteline bushings are backordered from the manufacturer until late March at the soonest. Didn't find anywhere else they were still in stock, checked Amazon.
  4. Feb 15, 2015 at 5:40 AM
    #524
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Looks like a good leaf pack. Are those the 63" that everybody talks about?
    mine are sagging just a bit now after hauling sandbags around for a second winter. I'm hoping to use you as the learning curve.
  5. Feb 15, 2015 at 7:40 AM
    #525
    Squeaky Penguin
    Brett
    No. Not the Chevy 63s, albeit I did walk past several of those. From my understanding, they came on a bunch of years of half ton trucks. They only have 2+overload or 3+overload configurations IIRC. Because of this, I don't think they would be good packs to pull leaves from. People use them as a complete replacement pack after welding in a new front hanger. I do know they are famous for flexing very nicely though. And, I only paid $44 for the junkyard leafs, so the swap could be done relatively cheap.
    Anyways, Doubt I'll need all the leaves out this pack. So you're welcome to what I don't use. Need to figure out getting my free labor out of Eric to help me build these things too. These were SUA and have a nice arch, so don't know how much rearching I might need.
  6. Mar 6, 2015 at 4:34 PM
    #526
    Squeaky Penguin
    Brett
    Got something fancy today:
    Well, at least I though I got a score when I found a pair of 10" 7100s brand new for $200. Turns out they have different valving. :censored: Already lined up to return them, unfortunately this was a one time thing and they can't be exchanged. Debating keeping them and re-valving them myself.
  7. Mar 6, 2015 at 4:36 PM
    #527
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just revalve them..
    Cost you Very little and you'll know how to do it to tune them to your truck.
  8. Mar 6, 2015 at 4:39 PM
    #528
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. Mar 6, 2015 at 4:59 PM
    #529
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  10. Mar 8, 2015 at 10:33 AM
    #530
    Squeaky Penguin
    Brett
    Big thanks to the other Brett (BDN) and Eric (TeamHypoxia) for helping me build a set of springs yesterday. Started like this:
    Did some of this:
    And some of this:
    To get this (full droop off jackstands, note: we purposely pushed the shackle inverted for testing purposes):
    End result was created with rearching the two main leaves off the Wheelers pack, and then using three Chevy leaves and one more Wheelers leaf to get a 6 leaf pack. Got exactly what I wanted with 1.5"ish more lift while dropping back to the stock shackles. Ride is much improved, if anything I lost vibes, way less body roll, and everything feels much more controlled.
    Cleaned them up with a quick coat of paint this morning, so here's what I'm left with:
    Supper happy with the results, and really happy to be rid of the shackles. They were a learning experience though, but now I don't see any reason to add longer shackles to any direct replacement pack. Screws up a lot of things to get you a little more downtravel.
    jubei likes this.
  11. Mar 8, 2015 at 7:41 PM
    #531
    capturecolorado
    capturecolorado Well-Known Member
    Alex
    Grand Junction, CO
    01 4Runner SR5 with some things attached
    I haven't seen a shackle angle like that since I had my jeep... Very nice.
  12. Mar 9, 2015 at 5:16 AM
    #532
    cynicalrider
    cynicalrider #NFG
    Jersey
    Looks good! Mod days are the best days.
  13. Mar 9, 2015 at 1:21 PM
    #533
    Squeaky Penguin
    Brett
    Yeah, shackle angle came out perfect. Curious to fully flex it and see what they look like.
    Thanks! And yes, always fun to hang out and BS with other members.
  14. Mar 10, 2015 at 5:52 AM
    #534
    capturecolorado
    Alex
    Grand Junction, CO
    I'm a little jealous of that shackle angle.. The angle I got with my expos and extended shackles is *just* within the "correct" angle range for a truck, but I'd prefer an angle like yours, smoother ride and better articulation...
  15. Mar 10, 2015 at 9:45 AM
    #535
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Well done, decide what you are going to do with those shocks?
    Serious question, how many times a year do you swap wheels/tires?
  16. Mar 10, 2015 at 2:36 PM
    #536
    Squeaky Penguin
    Brett
    Place I bought them from is sending me the 255/70 valve stacks for free. Would like to mess with tuning them eventually, but this will work for now. Need to find a local place to fill them with nitrogen too. Also need to figure out how to mount them correctly with the spherical bearings and the ruff stuff tabs. I'll take a picture when I get home of my confusion.
    Think this was the forth swap this year :D Wanted the big tires on when I worked on the springs.
  17. Mar 10, 2015 at 8:18 PM
    #537
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Have you thought about shock towers and running them inside the frame? The thing about running taller shocks outside the frame on our 1st gens is that you get tire rub on the bodies when you flex. They do look thinner so you might be able to get away with it. Your best bet is to cycle them in your suspension to find the right hight to mount them. You don't want them to limit your bump and droop. When you cycle them do it without the nitrogen. Your pretty witty I'm sure you'll figure it out. You can shoot me a PM if you need a hand. Good luck bud. :)
  18. Mar 10, 2015 at 8:43 PM
    #538
    Squeaky Penguin
    Brett
    Thanks Ray. Have thought through the mounting, my question is related to me being a fabrication and fancy shock noob.
    Not going to bother messing with trying to mount outside of the frame. Was planing on running a simple crossmember, and mounting the shocks angled back slightly, maybe inline with the stock driver side mount, maybe slightly forward of it, and a bit below it. Will be mounting them inward slightly of the stocks mounts as well. They will be kept vertical and not angled though for my purposes. Anyways, will have to tweak mounting heights to get the most out of the shocks, but I think that should be fairly straight-forward.
    My noob question is this, and might need to take it to the MT threat et. al.
    Can't put the mounts tight against the shocks mount, as that will defeat the purpose of the spherical bearing. So looks like I need some sort of spacer between the mounts and bearing I believe. Don't know if there is something specific for this application?
  19. Mar 10, 2015 at 8:49 PM
    #539
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  20. Mar 10, 2015 at 9:11 PM
    #540
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    :yes: misalignment spacers.
    http://www.polyperformance.com/Synergy-Shock-Bungs
    Or something like this
    To be honest I never set anything up before. I only done a lot of reading on how to set up triple bypasses. But it all works the same. You do have the right idea. And to get the best performance out of the shock you want to be close to vertical as possible. I can forward you a pm from one of the LT guys that's been helping me out that explains in detain how to set up the shocks. I'll send it tomorrow.
