Squeaky Penguin's (Trip Reports) Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Squeaky Penguin, Feb 3, 2013.
  1. Apr 27, 2015 at 11:24 AM
    #621
    Squeaky Penguin
    Squeaky Penguin [OP] Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'm a broke and starving college student and need to do it as cheap as possible. Plus I like to learn.
    There definitely will be a learning curve with me never having done a clutch, but I am fairly handy with a wrench. Hoping to knock it out in a day.
  2. Apr 27, 2015 at 1:17 PM
    #622
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    QFT
    Deathbysnusnu likes this.
  3. Apr 27, 2015 at 1:35 PM
    #623
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I might not be scheduled to heckle anyone this weekend. I'll check and see.
  4. Apr 27, 2015 at 1:43 PM
    #624
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Clutch isn't bad. The worst part is getting the top bell housing bolt and the harness all unplugged and plugged back in that's on top of the tranny.
    Of you go through the shifter hole from in the cab with extensions then getting that top fly wheel bolt isn't bad. I think I have photos of it when I did mine I'll look. Was my first clutch job and wasn't bad. But I had a lift too.
    Also resurface your flywheel while its out too.
    I didn't do my real main seal. Jace kept that info to himself when I did mine :luvya: haha but barely 115k on the truck when I did mine.
  5. Apr 27, 2015 at 1:47 PM
    #625
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    How much of a job is it to replace the rear seal? Any special tools required?
    Is it simple enough that the success rate is high?
  6. Apr 27, 2015 at 1:54 PM
    #626
    Blackdawg
    Monte
    Wyoming/St. Louis
  7. Apr 27, 2015 at 2:03 PM
    #627
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'm sure you were talking to the young one but I may be heckling him that day, is it really necessary to separate the exhaust?
  8. Apr 27, 2015 at 2:03 PM
    #628
    odomandr
    Andy
    Fort Collins, CO
    Yeah I'd definitely resurface the flywheel
  9. Apr 27, 2015 at 2:06 PM
    #629
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It may be easier to replace it as he needs it done in a day...I'm not sure where he can get it done quickly on a weekend. But I agree, it needs a smooth surface to start.
  10. Apr 27, 2015 at 2:06 PM
    #630
    Blackdawg
    Monte
    Wyoming/St. Louis
    I was but posted for all haha
    I can't totally remember why I did that..I think it just made it much easier to get to a few of the bellhousing bolts. And was easy to take off so I did.
    Sadly I did this before I really did the write up style of working on Frank so I don't have near the details Id like now :(
  11. Apr 27, 2015 at 2:07 PM
    #631
    Blackdawg
    Monte
    Wyoming/St. Louis
    Should be able to at any machine shop. Took ours 4 hours and we had it back same day. Id call around before the day you do it and ask though for sure.
  12. Apr 27, 2015 at 2:09 PM
    #632
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    4 hours to re-surface it? or 4 hours total for the whole clutch replacement?
  13. Apr 27, 2015 at 2:18 PM
    #633
    Blackdawg
    Monte
    Wyoming/St. Louis
    no took like 6 hours to do the clutch. maybe it was an hour or hour and half. We literally called them, dropped it off. Ate lunch. I helped Tim work on one of his cars and then we went and got it. sorry. Was a while ago and i don't remember it super well...:eek: but shouldn't take long. easily within the day you are doing it.
  14. Apr 27, 2015 at 2:19 PM
    #634
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    im sorry! You didn't ask! but yeas always a good idea. I actually removed my seal holder and resealed it to the block/oil pan while I was in there....
    not bad. flat screw driver pops the seal out after you remove the flywheel. Like Monte said, definitely get the FW resurfaced. Clean the seal holder surface and crank shaft seal surface up with a little scotch brite and brake clean, wipe clean with rag. then throw a little lube or oil on the inside of the seal and slide it on. tap it in slowly and evenly with a hammer (and a 3/8" 3" extension works great) go til its flush with the seal holder. done:)
    Deathbysnusnu[QUOTED] likes this.
  15. Apr 27, 2015 at 2:21 PM
    #635
    Blackdawg
    Monte
    Wyoming/St. Louis
    whelp...hopefully it doesn't die on me then..haha
    But the way i drive Frank, he will need a new clutch before 200k so, whatever. haha
  16. Apr 27, 2015 at 2:24 PM
    #636
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  17. Apr 27, 2015 at 2:28 PM
    #637
    lotsoftoys
    Jace
    Denver
    bunch of crap
    Brett, we use a company called clutch dr. they come to you with a big box truck and machine it in the truck. pretty sweet, not sure if they do house calls though:)
  18. Apr 27, 2015 at 2:29 PM
    #638
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    That would be awesome!
  19. Apr 27, 2015 at 3:51 PM
    #639
    Squeaky Penguin
    Brett
    Lots going on in here, trying to wrap my head around everything.
    Trying to get all my ducks in a row to knock this job out quickly. Found somewhere fairly close that will resurface a flywheel in an hour or two on a Saturday. Also might pick up a cheap flywheel to have around just in case.
  20. Apr 27, 2015 at 4:02 PM
    #640
    odomandr
    Andy
    Fort Collins, CO
    May I also suggest second clean pair of gloves for the install so not to contaminate said flywheel after its resurfaced.
